Too much tongue weight?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Sprarm33, Mar 29, 2011.
  1. Mar 29, 2011 at 8:12 PM
    Sprarm33
    Sprarm33 [OP] New Member
    Erie, Pa
    10 Tacoma 4WD
    Hi all! New to this great forum. 2010 Taco, 4.0 with towing package. Have had a Coleman Yukon pop-up since 96. Looking to move up to a Rockwood Mini-Lite 2304. Dry weight 3519 seems OK, but this model has the Murphy Bed(which the wife likes), that makes the tongue weight on the heavy side, 551#. Truck is rated for 6500# with a tongue weight of 650#. Planning on an Equalizer WD hitch. Any comments will be appreciated.
    Sprarm33
  2. Mar 29, 2011 at 8:16 PM
    mjp2
    Milton Juevos Portimous II
    NJ
    '06 TRD Access Cab, v6, 6-speed
    Scaffolding and a painted grill
    Welcome to TW! You should be fine with the equalizer hitch, although you may want to beef up the rear springs from the stock 3-leaf packs as they tend to bottom out when loaded.
    "Harsh ride" is the term you'll want to use when visiting the dealership to address the problem. Toyota has a 4-leaf TSB pack specifically to address harsh ride complaints. Just a matter of finding a dealer that's willing to work with you to get your case covered under warranty.
  3. Mar 29, 2011 at 8:17 PM
    spares
    spares Canadian Bacon
    New Brunswick, Canada
    06 DCSB TRD Sport
    is it unrealistic to just offset the tongue weight by putting some bikes or somthing at the backside?
    just tryin to think outside the box a bit
  4. Mar 29, 2011 at 8:55 PM
    Beerrun
    Beerrun Well-Known Member
    Jon
    Spokane WA
    10 Sedan Sport LB
    Fog light rewire- debadge- front window tint- 5100's @ 1.75- Toytec 1.5 AAL- Avid sliders- 4x4 lighted switch- Sockmonkey decals- Truxedo low pro QT cover- Weather Techs- Back up light Mod. Diff. breather mod. OEM roof rack-Yakima bars. HomerTaco grill. Hella Black Magic Lts. WT vent visors.
    Shouldn't this be in the UG?
