Took some big shots yesterday on the trail
Discussion in '1st Gen. Tacomas (1995-2004)' started by Madjik_Man, Aug 14, 2011.
  1. Aug 14, 2011 at 8:16 AM
    Madjik_Man
    Madjik_Man [OP] The Rembrandt of Rattle Can
    Colorado Front Range
    Gotta make it brief... and yes pics/vid will be coming soon but:
    The trail is not what I remembered it to be. Last time I was on it I was driving a full size Bronco with a 4" suspension lift and 33" tires. No problem.
    Also, I think with the record snow and run-off this year, a lot has changed. That and 15 years later I didn't remember it being so gnarly in spots. That said I took some big shots from rocks under Ol' Red yesterday....
    1. I feel as though a lot of them were on that flimsy skid plate, but I also feel as though my front diff caught a couple, as well as my frame. I checked for any kind of obvious damage but laying on the trail I didn't see much. I'm going to get it on my friend's lift to further examine things. He can help, but it there anything in particular I should look for? More so than just the diffs... any other common areas that get hit I should look out for?
    2. My passenger side rocker panel got abused... kinda like me if I ever landed in a federal penitentiary.... it has about a softball sized dent/crunch from a big hit after trying to slowly creep off a 3-foot (approx) rock - it was the only way to get past this spot. Fixing it is way down the line, if ever at all, so is there any kind of "magic potion" I can spray on it to prevent rust or further damaging of the body/paint?
    3. See #2. Let's talk sliders :eek: I am looking for that perfect intersection of cost effectiveness, durability and performance. From an aesthetics point of view, I really dig the square tubing(?) look. And I'm pretty sure I want these puppies welded onto my frame, right? I live in Colorado's front range, so if there's anything local anyone recommends, I'm all ears.
    Thanks.
    MM
  2. Aug 14, 2011 at 11:50 AM
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    Same thing with all the trail here
    well once its on a lift, you'll be able to see plenty and just look around
    not really..paint over it i guess.
    check out 4xinovations vendor page. They sell pretty cheap sliders. Also Elite offroad, Relentless offroad...there are tons of vendors. Not many make all square tubbing tho. I have heard they aren't hard to make if you can weld yourself. And yes, weld them to the frame.
  3. Aug 14, 2011 at 3:17 PM
    MowTaco
    MowTaco Well-Known Member
    Kansas
    16 Chevrolet Silverado
    If the paint isn't chipped off in huge chunks and is just little specks (like rock chip size) I usually steal my sister's clear nail polish (I think it might be called top coat? we need one of our wonderful female members to confirm) and paint over the spot. It doesn't look as bad as if you try to use touch up paint IMO and it is much easier than trying to color match a spot if you're gonna go back and fix it later
  4. Aug 14, 2011 at 3:23 PM
    Rebel Taco 22
    Rebel Taco 22 mall crawler
    man you shouldnt be playing on that trail without sliders. It sounds difficult. That damage will be very expensive if you decide to get it fixed and could have been easily prevented with sliders :cool:
  5. Aug 14, 2011 at 4:02 PM
    Madjik_Man
    About 30 minutes before sustaining the rocker panel damage I was telling my wife about the wonderful functionality of sliders.
    And I've had Ol' Red for 12 years. About time he started showing his age.
  6. Aug 14, 2011 at 4:05 PM
    Madjik_Man
    The paint is chipped, ripped, scratched and any other adjective you can think of :eek:
    Maybe... and this is a doubtful maybe... I get Ol' Red fixed up (body wise) and give him a new paint job. But that is so far down the road.
    Eh... I think I just have to train myself to "get over it"
  7. Aug 14, 2011 at 10:15 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    2002 XtraCab TRD 4x4 SCv6 AutoTrans With Lots of Mods ADS COs w/Compression Adjusters Camburg Uniball UCAs Whiteline Lower Control Arm Bushings Kartek 7" Limit Straps Plastics Guy Front Bumpstops Custom Alcan Springs +800 lbs +3" ADS 10" Stroke Triple Bypass w/Resi Rear Shocks Custom Rear Shock Relocate All-Pro U-bolt Flip w/Timbren Bumpstops 4.88 Nitro Gears ARB Front Locker ARB Twin Compressor Black 17x8 Konig Countersteer Type X 285/70r17 Falken A/T3w Gunmetal 16x8 SCS Ray10s 255/85r16 Maxxis Bighorns Limited Edition (Relentless) Elite Front Bumper Smittybilt X2O 10K Winch Diode Dynamics SS3 Sport Selective Yellow Fog Lights in the Bumper Diode Dynamics SS3 Pro 4,000 Kelvin SAE Driving Lights with Clear Lenses on the Bumper Morimoto D2S Projectors XB35 Ballasts + 4300K Bulbs Badland Sliders FrankenFab Tire Carrier Swingout bumper w/kitchen BudBuilt Front & Bellypan Skids BAMF Rear Diff Skid Dometic CFX 55im Fridge/Freezer Alpha II Hardshell RTT Badland Custom Bed Rack Denso 210-0461 105 amp alternator Dual Northstar 24F AGM batteries BlueSea 7622 ML-ACR Battery controller Peak DBI Dual Battery Voltage Monitor Magnuson MP62 Supercharger w/2.37" Pulley Haltech Elite 2000 Standalone ECU Denso 650cc Fuel Injectors Doug Thorley Headers Aeromotive Stealth 340 Fuel Pump TransGo A340F Reprogramming Shift Kit Magnaflow Hi-Flow CAT, Magnaflow 18" Muffler w/Vibrant Resonator 13WL Brake Calipers Braided Steel Brake Lines ScanGauge II OBDII Scanner Kenwood TM-71A Dual Band Ham Radio Larson 70CM/2M Antenna Uniden 520xl CB radio 3' Firestik Adjustable tip antenna Pioneer DEH-P9400BH HU Alpine Amps & Type R components (F) and coaxials (R) Wet Okole Seat Covers Weathertech Digital Liners Deck Plate Mod 1" Diff Drop Carrier Bearing Drop
    Sorry to hear about the trail damage Buddy! I've been in that situation, it's tough no matter the outcome.
    Sliders will prevent further damage and to an extent will cover up what happened to the rocker panel this weekend. Definitely go with weld on, both for cost and for strength.
    On inspection, look closely on the bottom of both lower control arms and also around the alignment cams. Another area to inspect is the transfer case. The stock skids on our trucks will absorb some rock impacts but not a whole lot of big hits.
  8. Aug 15, 2011 at 10:02 AM
    kmok
    kmok Plastidipped ma Hootus!
    Kyle
    Columbus, Ohio
    2005 Subaru Outback XT 5MT
    4xinnovations sliders! They are the best sliders you can get for the price imo.
  9. Aug 15, 2011 at 10:06 AM
    Madjik_Man
    So the hit on the rocker panel is definitely messing with the door opening and closing. Not that big of a deal but surely noticeable.
    I think the rocker panel being pushed up is causing the door (which did not incur damage) to angle ever so slightly upwards. I believe this is causing a bit of unwanted pressure on the latch and the bar it latches to. Now, you have to give the door a little extra "oomph" or else it won't fully close. And when fully closed, the door doesn't line up (again ever so slightly) with the body of the truck to the rear of that seam.
    I wonder if I bang on the rocker panel dent... bang it downwards to alleviate that pressure if things will be better.
    Please... for the love of God... if this is a bad idea, chime in now
  10. Aug 15, 2011 at 10:08 AM
    x2468
    x2468 Well-Known Member
    '02 TRD 4wd V6 Xcab Sr5
    Im considering sliders as well.
    I have a stock skidplate that covers the front diff. The front diff seems pretty recessed from the skid so id be surprised if I could damage it. If u have the same plate Idk if id worry about that.
    However. I always worry about my t-case cuz that thing looks pointy and exposed. Looks like it would take a bike, expensive skid to protect that.
  11. Aug 15, 2011 at 10:09 AM
    SupraT
    SupraT Tacoma Lover
    Tony
    Columbia Falls
    98 TRD SR5 4x4
    3" Lift Three leaf add and Bilstin 5100"s in back and Donahoe coilovers in front, Tinted Windows, Blackened parking light, tinted brake lights, clear bumper lights, Blacked out turn signals, AVS vent visors, Electric Fan mod, K&N CAI
    Sucks to hear about the damage..Lets see the video:rolleyes:
  12. Aug 15, 2011 at 10:09 AM
    Digiratus
    Roaming the PNW
    The RedHead
    Do you have a pic that shows the impact area on the rocker panel? Or maybe one that shows the line along the full length of the bottom of the door?
  13. Aug 15, 2011 at 10:10 AM
    x2468
    I mean.... a door isn't that complex. Eye it up and if it passes most common sense tests give it a shot. Gotta do wat u gotta do.
  14. Aug 15, 2011 at 10:11 AM
    Madjik_Man
    I've been told... I have big thumbs
  15. Aug 15, 2011 at 10:15 AM
    97yota4wd
    97yota4wd Well-Known Member
    Eric
    Mesa, AZ
    alot of metal, small engine, decent travel.
    caged, camburg long travel, 50t leafpack (soon to be installed) light rack over cab, 5pt harnesses etc
    ouch! looks your in line for some sliders:).
    i did that same thing pretty much, but i couldnt open my door, i had to kick it open then beat it back down with a hammer.
  16. Aug 15, 2011 at 10:16 AM
    Digiratus
    Roaming the PNW
    The RedHead
    Yeah, just to take pressure of the door to allow it to close, might try pounding down that "high" point. I wouldn't hit the metal directly though. Might try a placing a small 2x4 over it and pounding on that. Based on what I see in the pic, it doesn't look like it would take much.
  17. Aug 15, 2011 at 10:17 AM
    kmok
    Kyle
    Columbus, Ohio
    :rofl:
  18. Aug 15, 2011 at 10:29 AM
    Madjik_Man
    :eek:
  19. Aug 15, 2011 at 10:29 AM
    Madjik_Man
    That's exactly what I was thinking.
    Thanks
  20. Aug 15, 2011 at 10:30 AM
    Madjik_Man
    The one nice thing is my wife pretty much just said, "buy whatever the f**k you need"
    :D
