Took truck to dealer to check on Engine noise...
Discussion in '2nd Gen. Tacomas (2005-2015)' started by overhill, May 15, 2015.
  1. Nov 2, 2015 at 1:39 PM
    #101
    SkyHighTacoma
    SkyHighTacoma Josh
    Josh
    Brazoria County Texas
    15 DCSB SR5 MGM
    Ah well. I'm not too worried over it, I'll drive it until it gets worse and take it to the dealer or when I find a low mileage dc 1st gen..
  2. Nov 2, 2015 at 1:43 PM
    #102
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    Try the next weight up of oil, and or some Lucas Heavy Oil Stabilizer. See if it helps.
  3. Nov 2, 2015 at 3:40 PM
    #103
    TRD4x4offroad
    TRD4x4offroad Active Member
    Calgary, AB
    2015 Tacoma TRD Offroad V6 4x4
    Unbelievably, this cold startup noise is getting much quieter since I posted a few weeks ago. The temps have dropped considerably since that time hovering around the freezing mark today. It used to be quite loud and distinctive during those morning starts and it was much warmer at that time. The last couple of days I can still hear it but have to really listen for it to notice. Strange.... I thought it would get worse the colder it got outside.
  4. Nov 2, 2015 at 3:51 PM
    #104
    Thomas Jefferson
    Thomas Jefferson Keyboard Warrior
    Sacramento,CA
    '13 SR5 DCSB 4x4
    One can never have too many light bars.
    It could be a case of the motor breaking in.
  5. Nov 2, 2015 at 4:02 PM
    #105
    epa4wd
    epa4wd Well-Known Member
    Eduardo
    2019 SR
    Clazzio Seat Covers OR Wheels 40% tint Side Steps KC Fog Lights
    doubt it, the 2014 I had did it for 15k miles until toyota replaced the oil pump... and then eventually had to give me a new 2015...
  6. Nov 2, 2015 at 4:15 PM
    #106
    epa4wd
    Eduardo
    2019 SR
  7. Nov 2, 2015 at 4:24 PM
    #107
    TRD4x4offroad
    Calgary, AB
    It'd be nice if this issue actually corrected itself. :rolleyes: I think I'll take it back to the dealer and get them to check it out anyways to document it. The thing that bothers me is that I don't believe they are competent enough to replace the oil pump properly. I've heard far too many horror stories about the hack jobs these dealer techs can perform on your truck. The last thing I want is for them to open up my brand new motor. I would rather just leave it but then who knows what other problems may occur down the road due to the bad oil pump. How did you end up getting a new truck out of this? Does your new 2015 make any noises at all? I wonder how many new Tacomas are actually affected, this really sucks.
  8. Nov 2, 2015 at 4:27 PM
    #108
    ZachPrerunner
    ZachPrerunner Sometimes she goes, sometimes it doesn’t
    Southeast TN
    ‘07 TRD Offroad / ‘19 TRD Offroad 4x4
    Calm down. Like every post you make is the exact same thing. FIY not every engine noise is piston slap. And no I do not advise walking into the dealership demanding a new engine.
    Arailt likes this.
  9. Nov 2, 2015 at 4:32 PM
    #109
    epa4wd
    Eduardo
    2019 SR
    I agree, their incompetence when fixing the truck is what cause them to have to buy back my 2014 and give me a 2015, they actually broke the radiator in the process and did not tighten the new one.
    This was the next issue that they were unable to solve
    http://youtu.be/Rn7Y0vwFcXM
  10. Nov 2, 2015 at 5:22 PM
    #110
    SkyHighTacoma
    SkyHighTacoma Josh
    Josh
    15 DCSB SR5 MGM
    Sounds good to me?
  11. Nov 2, 2015 at 5:56 PM
    #111
    LEBM
    LEBM Thread Killer
    Eleanor, WV
    2021 TRD PRO 6MT Midnight Black
    Can't wait to see the results. Thanks bc. I'll send one in on the next change, but that will be a couple months. Got the kit already.
  12. Nov 2, 2015 at 6:59 PM
    #112
    epa4wd
    Eduardo
    2019 SR
    Result will most likely be okay. These were the results for mine:
  13. Nov 2, 2015 at 7:31 PM
    #113
    Skywalker
    Skywalker Set the gear shift to the high gear of your soul
    Englewood
    2023 TRD Offroad Doublecab
    Stock
  14. Nov 2, 2015 at 8:25 PM
    #114
    LuvTacos
    LuvTacos Well-Known Member
    Oh I'm calm, none of my vehicles sound like that. I would not be calm if I went to the dealer and they said "that's normal, they all do that". These trucks are expensive, who wants one that sounds like a POS? Oh what a feeling!
  15. Nov 2, 2015 at 8:56 PM
    #115
    Littlemule1
    Littlemule1 Well-Known Member
    2015 SuperWhite Tacoma DCSB TRD Sport
    Mine sounds this way:facepalm:
  16. Nov 2, 2015 at 11:24 PM
    #116
    bigcrab
    bigcrab Well-Known Member
    2014 DCSB 4x4 TRD OR
    Awesome, thanks for the info. My truck has 20k so will be interesting to compare
    LEBM likes this.
  17. Nov 3, 2015 at 2:51 AM
    #117
    billybob50
    billybob50 Well-Known Member
    Bob
    05 Basic Gold Tacoma Automatic
    Dog friendly, with dog snot on inside windows, with of course a/c! Mag 16 inch wheels from a Mazda.
    Looks like my wife's blood results, stop taking those calcium tables!
  18. Nov 3, 2015 at 5:10 AM
    #118
    SkyHighTacoma
    SkyHighTacoma Josh
    Josh
    15 DCSB SR5 MGM
    Not meaning to thread jack, just posting a video of the way my truck sounds. Anyone else have that knocking sound? If you listen carefully you can hear a knocking sound. This is a cold start early am, 60 degrees outside.
  19. Nov 3, 2015 at 5:33 AM
    #119
    ZachPrerunner
    Southeast TN
    Yeah I'm not saying it sounds "normal". I was referring to your statement about piston slap. It seems like every post you make about engine noises deals with this "piston slap". There are other things out there that could be producing that noise, so I wouldn't be blaming piston slap everytime. Just because an engine is making an abnormal noise, doesn't mean you need to replace the entire thing. To me, you're being over dramatic about the whole ordeal. Let the techs do their testing before anyone jumps to conclusions.
  20. Nov 3, 2015 at 6:16 AM
    #120
    Lester Lugnut
    Lester Lugnut Well-Known Member
    N of Mex-S of Canada-E of LA-W of NC
    '15 Tacoma PreRunner V6 SR5 Auto
