Took truck to dealer to check on Engine noise...
Discussion in '2nd Gen. Tacomas (2005-2015)' started by overhill, May 15, 2015.
  1. Nov 13, 2015 at 7:09 AM
    #161
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
  2. Nov 13, 2015 at 7:14 AM
    #162
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Oil pump.
  3. Nov 13, 2015 at 7:17 AM
    #163
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    For reference. Cold start with my 5w-50, oil pressure is 90psi. Then lowers as engine warms up and idle settles. Down to ~26psi.
  4. Nov 13, 2015 at 7:33 AM
    #164
    LEBM
    LEBM Thread Killer
    Eleanor, WV
    2021 TRD PRO 6MT Midnight Black
    Have you ever done a UOA on that 5w-50 oil?
  5. Nov 13, 2015 at 7:42 AM
    #165
    Ulysiss
    Ulysiss Well-Known Member
    Ulysiss
    La Puente, SGV
    2013 Long Bed, PreRunner, TRD Sport
    So I dropped of my truck last night started it this morning with the service mangers and a tech the knocking noise is there they said a lot of there trucks do the same thing he said he wasn't going to okay anything but since it under warranty he was going to schedule a Toyota tech to come down and inspect it. He said the inspector might say it's normal nothing to worry about or he can say that he wants to take the engine apart rebuild it if he does decide to do that and the noise is still there after he rebuilds it he might not know what it is and it the truck could be better or worse the service manager did not recommend it. I told him when the tech comes I will speak to him about what he might think it is and what my options are. I'm scheduled to drop it off next week
  6. Nov 13, 2015 at 7:42 AM
    #166
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    No. Why do you ask specifically? Looking for a comparison?
  7. Nov 13, 2015 at 8:13 AM
    #167
    LEBM
    LEBM Thread Killer
    Eleanor, WV
    Well, obviously, the 50 is not your traditional grade. I'd also be interested in seeing what it sheers down to in a standard OCI.
  8. Nov 13, 2015 at 8:22 AM
    #168
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    I think we can get it done. It won't be the same as the previous sample though. As the engine has long since been broken in, has more miles on this oil than in the posted sample, my engine has a small boost related head gasket leak, has a bit of JB weld holding the thrust washers in (might or might not show up in the test), and I use considerably more antiwear additive than most people.
    Would be quite interesting to see those results. Lol.
  9. Nov 13, 2015 at 9:16 AM
    #169
    ruggedT
    ruggedT The Sticker Guy
    Stan
    Midlothian, Va
    2016 Ford F250
    Diesel on 35's
    I just read another thread on this sound. Dude got his truck lemmoned after they changed everything including a new short block
  10. Nov 13, 2015 at 9:24 AM
    #170
    Chris24
    Chris24 Well-Known Member
    Greensboro, NC
    09 Black DCSB TRD Sport, V6, 6sp
    My 09 V6 sounds exactly like the OP's truck when its cold out and i start it. Goes away after a few minutes...
  11. Nov 13, 2015 at 9:25 AM
    #171
    LEBM
    LEBM Thread Killer
    Eleanor, WV
    Well that's interesting... first '09 I've heard of.
    Like I said... could it be the oil pumps are fine... just noisy?
  12. Nov 13, 2015 at 9:45 AM
    #172
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Could also be to thin an oil weight and not nearly enough anti wear additive. Which is the going trend now.
  13. Nov 13, 2015 at 10:08 AM
    #173
    Littlemule1
    Littlemule1 Well-Known Member
    2015 SuperWhite Tacoma DCSB TRD Sport
    are pressure readings stable or erratic?
  14. Nov 13, 2015 at 10:09 AM
    #174
    Littlemule1
    LINK ?
  15. Nov 13, 2015 at 10:16 AM
    #175
    Littlemule1
    Thank you everyone for pics,info,everything !:thumbsup:
  16. Nov 13, 2015 at 10:29 AM
    #176
    LEBM
    LEBM Thread Killer
    Eleanor, WV
    There's another thing to keep in mind here: in general, it looks like a '13 and newer noise. Acknowledging that it could take more miles/time for a problem to develop, I have not seen one post or heard one thing about it actually being a problem. And as long as the UOAs look on track, I'll tread water with this noise. No one's lost an engine. (Yet.)
    Hope it stays that way.
  17. Nov 13, 2015 at 10:45 AM
    #177
    Maximus
    Maximus Well-Known Member
    North Bay
    11 Tacoma TRD OR 4x4
    Icon Suspension with CDCV, SPC Light Racing UCAs, Wheeler's 3 Leaf AAL, Wheeler's Superbumps, sPod SE BAMF Sliders, All-Pro Skids, AFE Drop in filter, Magnaflow Exhaust, RCI Aluminum LCA Skids, BAMF Bed Brackets, 4X Innovations Rear Bumper, FX-R Retrofit Headlights with Philips 4300k, Custom Nestah Edition Firestik AM/FM Antenna, Famous Fab Hood brackets, FrontRunner SlimLine 2 Roof Rack, Mob Town Offroad tailgate reinforcement plate, Ram A pillar mount, Anti-Dark hood lights, Lots of LED lights,
    OP, your vehicle was checked out at Toyota Marin?
  18. Nov 13, 2015 at 10:52 AM
    #178
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Mine as stable.
  19. Nov 13, 2015 at 10:57 AM
    #179
    ruggedT
    Stan
    Midlothian, Va
    2016 Ford F250
    Diesel on 35's
  20. Nov 13, 2015 at 3:13 PM
    #180
    Gincoma
    Gincoma Special Edition Member
    Salt Lake City UT
    RIPieces 2005 Tacoma, adios 2011 :'(
    Factory Monster Truck Package with reverse gear.
    I think this thread is scaring the shit out of people now hundreds of people are coming forward with this noise is ridiculous. I've had the same ticking noise on my 05' 11' and my current 13' its a normal characteristic of the 4.0L engine. Its funny now everyone saying they have the same sound...well duh its normal!
