Tool box with Undercover Tonneau Cover + 3 ?'s
Discussion in 'Tonneau Covers, Caps and Shells' started by TAC1, Aug 19, 2011.
  1. Aug 19, 2011 at 11:46 AM
    TAC1
    TAC1 [OP] Well-Known Member
    Petros "Peter" AGE: 44
    Miami, Florida
    DCSB 4.0 Auto PreRunn
    FRONT: OEM PreRunner coils, 5100's @ .85, MaxTrac Spindles, 1/4" Taco lean spacer. ground to fender base: LF & RF: 40"'s hub to fender base::::: LF & RF: 25"'s REAR: 2012 OEM 3/1 leafs, Wheelers 3 leaf AAL, 2" Tapered steel block. Bilstein F4-BE5-B110-T5 ground to fender base: LR & RR: 41"'s hub to fender base::::: LR & RR: 26"'s All mud flaps trimmed 4"'s shorter.
    Hello Forum'
    I would like to know if its possible to have a tool box (in bed, under the rails, against the rear bed wall) that I can still open enough to access the tools even with the undercover tonneau raised up but still attached to the truck.
    Also, how does the Undercover tonneau attach to the truck? Is there a hinge back there? Does it clip on some how? I have never seen how it is attached so if anyone has pics I would appreciate it.
    Finally, If I am carrying something that is about a foot or so taller than the top of the bed can I still drive the truck as long as I tie down the tonneau cover? I read somewhere on this forum that some one did drive the their truck while the tonneau was raised but I can't find the post now.
    I plan to buy a 2nd gen double cab Tacoma by the end of the year so I want to prepare myself for what I want for the bed. I appreciate your time, pics, & reponses.:)
