Tool Question....
Discussion in 'Garage / Workshop' started by Pster, Jul 7, 2009.
  1. Jul 7, 2009 at 11:14 AM
    SC4333
    SC4333 Well-Known Member
    Grant
    FL
    SOLD - 2016 TRD Off-Road 4x4 DCSB
    I've seen a buddy of mine use this method a while back and it turned out great. He used an air drill and a wire brush like you mentioned. It took quite a while to cover the piece of metal he was working (about 4x6) but was worth the work IMO.
    The wire brushes can be picked up @ just about any hardware store.
  2. Jul 7, 2009 at 11:16 AM
    SC4333
    Grant
    FL
    If it makes any difference the piece he was working on was stainless.
  3. Jul 7, 2009 at 11:16 AM
    Pster
    Pster [OP] Well-Known Member
    Charlotte, NC
    2006 Tacoma 4x4
    Bak Flip bed cover, shorty antenna, Peripheral iPod interface, Garmin 750 mount, add'l bed tie down rings, Westin nerf bars, hitch safe, tailgate lock, Ideal 1 3/4" turn-key clamp to secure tailgate from removal, Spare tire security cable, spare tire stainless air hose extender, Fumoto oil drain valve, Amp Research Bed X-Tender w/Schlage Cable Lock, bed mat, Redline hood struts
    Yes, it will take some work. I bought cheap and didn't want to pay up for more expensive stainless, etc. Here is some good info on Hot Rolled:
    http://www.metalreference.com/INFO_Hot_Rolled_Steel.html
    I intend to practice and test what will work the best, but I am thinking steel paper on a metal polisher, working to smaller and finer grit, ending in a paste polishing compound with the final finish in clear lacquer. The 1/4" metal sheet will be on top of a 1 1/2" thick MDF table top so I think the steel may not even need to be glued or bolted down. The MDF top has a metal brace screwed into the underside to add rigidty and prevent sagging.....it's pretty damn strong already, withour adding the metal plate on top.
    (I have found that spraying on enamel/lacquer with the plate in the full sun so it heats up really hot results in an extremely smooth finish which cures fast. The paint, due to the heat, spreads out very nicely and hardens well. Rustoleum works extremely well.)
  4. Jul 7, 2009 at 11:18 AM
    98tacoma27
    Ben
    Not Beech Creek
    I am aware of Hot Rolled. To do engine turning properly and effectively, the metal surface needs to be flat. I don't think it will work on the hot rooled steel.
  5. Jul 7, 2009 at 3:05 PM
    Pster
    Charlotte, NC
    2006 Tacoma 4x4
    Ok, here are some pics. Just got it out of the truck and set it on the workbench. This thing is HEAVY. Wife could hardly lift one end....but she's a wuss grrrl. Had to wear her apron so she wouldn't get doity. You can see in the last pic some of the the "bluing" color inherent to hot rolled steel. I think this will clean up very nicely. Perfect fit, no need to affix it to base at all. I am going to LOVE this thing!!!!! Tacoma Mods #1, Garage Mods #1.5. Edges have been ground and deburred.
  6. Jul 7, 2009 at 6:57 PM
    98tacoma27
    Ben
    Not Beech Creek
    Pster, I don't think you are going to get the desired result with that surface finish.
  7. Jul 7, 2009 at 7:13 PM
    SaltySteve
    SaltySteve Well-Known Member
    Denver
    2012 4runner
    I think it would be possible to but only if you ground off all that scale first. My $.02.
  8. Jul 7, 2009 at 7:14 PM
    98tacoma27
    Ben
    Not Beech Creek
    I would agree.
  9. Jul 8, 2009 at 5:46 AM
    Pster
    Charlotte, NC
    2006 Tacoma 4x4
    I intend to sand the scale off.....if possible. I realize it is a rough finish and needs lots of work. NO WORK = NO FUN!!!!
  10. Jul 8, 2009 at 5:48 AM
    98tacoma27
    Ben
    Not Beech Creek
    Haha, atta boy!! Here I will help
  11. Jul 8, 2009 at 6:04 AM
    Pster
    Charlotte, NC
    2006 Tacoma 4x4
    I love a challenge!!!!!!!!
  12. Jul 8, 2009 at 7:52 AM
    Hotdog
    Hotdog My hair is all natural Moderator
    Hotdog
    2007 PreRunner SR5 Double Cab
    Wet Okole Underwear
    Make sure to use safety glasses if you use a wire brush attachment. Those bristles fly off too easily.
  13. Jul 8, 2009 at 7:59 AM
    Pster
    Charlotte, NC
    2006 Tacoma 4x4
    Thanks, in fact I just bought a new pair......I need to sand all the scale off and then I'll start working on a finish. I never expected I could get it to look as good as the engine turned swirls, but I should be able to get it looking tons better than it does now!
  14. Jul 9, 2009 at 11:36 AM
    Pster
    Charlotte, NC
    2006 Tacoma 4x4
    I went at the metal plate yesterday with an orbital sander and 80 grit silicon carbide paper just to see the effect. It cleaned it about 80-90%, but man is this going to take a while. I need to find something much rougher for the first pass. I read also that muriatic acid would take off the scale, but I am assuming I would need to practically immerse the damn think in it for a day....I think I am just going to grind and grind and grind.....going to try paint stripper paper as I also read it can work well.....need tight grit.
  15. Jul 9, 2009 at 11:43 AM
    #35
    98tacoma27
    Ben
    Not Beech Creek
    :popcorn:
    Do you know any machine shops locally?
  16. Jul 9, 2009 at 12:19 PM
    #36
    Pster
    Charlotte, NC
    2006 Tacoma 4x4
    No, I really don't. I just think I need to find the right tool/sandpaper....hence the name of this thread.....
  17. Jul 9, 2009 at 12:24 PM
    #37
    98tacoma27
    Ben
    Not Beech Creek
    It you want to rough cut the slag, a belt sander will work. Just keep it moving. Then you could finish cut with the orbital.
  18. Jul 9, 2009 at 12:35 PM
    #38
    Pster
    Charlotte, NC
    2006 Tacoma 4x4
    Yeah, I thought the belt sander might be a good choice, but I don't have one and wouldn't use it for anything else if I bought one. I was thinking maybe one of those round sander/polishers?
  19. Jul 9, 2009 at 12:47 PM
    #39
    98tacoma27
    Ben
    Not Beech Creek
    Do you mean one that is used on vehicles? Sort of a big angle grinder with a large pad?
  20. Jul 9, 2009 at 12:50 PM
    #40
    Pster
    Charlotte, NC
    2006 Tacoma 4x4
    Yes. let me find a pic
