Tools for lift kit
Discussion in '2nd Gen. Tacomas (2005-2015)' started by JeffBoyardee, Jun 26, 2019.
  1. Jun 26, 2019 at 8:01 PM
    JeffBoyardee
    JeffBoyardee [OP] Well-Known Member
    Jeff
    Seminole, FL
    2011 TRD Off-Road Tacoma DCSB
    I'm putting a lift on in the next few weeks, as soon as my Dobinson's order gets here. Dobinson's shocks/struts/coils/leafs, jba UCA's, diff drop, pinch weld flattening, and CMC. However I'm in FL, and have access to a warehouse to do this lift in. Problem is, I don't wanna be making tool runs because i forgot to bring this or that.
    So my question is, aside from normal hand tools, (ratchets, wrenches, sockets, screwdrivers, etc) can anyone think of anything special I might need? Already got prybar, sledge, angle grinder, PB blaster, etc on the list.
  2. Jun 26, 2019 at 11:24 PM
    reidkm
    reidkm Does lifting my truck increase my boto size?
    Reid
    Hilo, Hawaii
    2015 Tacoma, 4.0V6, 4x4 SB
    6" RC Lift Kit, Bilstein 5100 Full length shocks front and rear, OME 883 Coils, SPC UCA's, 285/70/17 Cooper STT Pro's
  3. Jun 26, 2019 at 11:50 PM
    Uphillshunter
    Uphillshunter El Taco Diablo
    Matt - KN6DZP
    Hughson, CA
    Impulse Red 02 TRD Tacoma Prerunner "now it's 4x4 muthafukas" DC 5vz-fe
    Swapped 4x4, Twin sticks, Tundra Brakes, FOX Resi, AllPro leafs, Pro-Comp 17x8.5, Transgo shift kit, Dual batteries
    If you're ordering the front shocks pre-assembled you don't need a sping compressor... if you didn't order them pre-assembled you need one.
    I pop the outer tie rods lose to allow room to get the front shocks out. This is the tool I use.
    https://www.harborfreight.com/tie-rod-and-pitman-arm-puller-63684.html
    As mentioned above, you'll need a jack that will lift high enough. Normally 22-24 inch max height will work. 6 ton jack stands are best (height) to support the truck at a managable height (4 to could probably work) but, you'll also need 2 ton or something to help you support the rear axle while you have it lose from the leafs.
    A good sized alignment punch helps lining up the eyes on the leafs and on the shocks as well. I use one similar to this.
    https://www.homedepot.com/p/Mayhew-5-16-in-x-12-in-Line-Up-Punch-44202/100157822
    And not sure on the torque specs on the JBA UCAs, but it's over 150 ft lbs for the ball joint nut on SPC UCAs. So I'd figure on needing a Torque Wrench that will go up to 200 ft lbs.
  4. Jun 26, 2019 at 11:52 PM
    reidkm
    Reid
    Hilo, Hawaii
    You're fancy with that puller. I prefer the ghetto style, a 2lb hammer lol.
    Bebop and JeffBoyardee [OP] like this.
  5. Jun 27, 2019 at 2:16 AM
    JeffBoyardee
    Jeff
    Seminole, FL
  6. Jun 27, 2019 at 4:05 AM
    Wattapunk
    Wattapunk Stay lifted my friends !
    Uncle K
    TX
    2005 DCLB 4WD
    If you don't have an air impact gun, I highly recommend looking into either a 20V cordless Dewalt impact or Ryobi. I rarely even use my air impact anymore since I invested in a 20V dewalt impact gun for the house and have a Ryobi one in the truck for tire changes. It will make your life much easier to do your lift. Make sure you go with a high capacity battery 4ah or higher.
  7. Jun 27, 2019 at 4:15 AM
    JeffBoyardee
    Jeff
    Seminole, FL
    The Milwaukee 20v is already on the list! Thanks!
  8. Jun 27, 2019 at 5:55 AM
    Uphillshunter
    Matt - KN6DZP
    Hughson, CA
    Fancy? It's a 15 dollar tool. And it takes litterally no effort to pop the tie rod ends off with it... and, about the last thing I want to do is bend/brake/damage someone's outer tie rod end, while I'm doing their lift.
  9. Jun 27, 2019 at 7:04 AM
    stickyTaco
    stickyTaco Fuck Cancer
    Zack
    Reno
    '12 DCSB TRD-OR
    Fox/Dakar with Relentless goodies and stuff
    In addition to what has been listed you are going to need a welder for the cab mount chop.
    A set of large channel locks is helpful for bending the sheet metal so you can r/r the UCA bolt.
    Breaker bar and some penetrating oil.
    A pry bar can be helpful in lining up the leaf packs.
  10. Jun 27, 2019 at 7:07 AM
    JimboAnz
    JimboAnz #OldNorm
    Jimbo
    Charlotte (Cornelius) NC
    2020 Ford F'in Ranger
    couple ratchet straps may come in handy on the rear leaf install. might have to persuade the rear axle a little bit to get the new leaf pack to line up with the centering pin
  11. Jun 27, 2019 at 7:09 AM
    Ccrames2018
    Ccrames2018 Jack of some trades.
    Caden
    Nor Cal
    07 AC 4x4 V6 6MT
    -Bilstein 5100s @1.75" -16x8 SCS Ray10s with 305/70R16 General Grabber AT -CMC -URD Short Throw Shifter -Bed stiffeners -Bed mat -Aftermarket head unit -AFE Rebel exhaust -ME-SO Customs dome/map lights -Window tint with eyebrow -OEM LED 2015 tail lights -GTR Lighting headlight bulbs -Husky floor liners -Camper shell -Sumo Springs -Air intake -Aftermarket Volkswagen key fob -Aftermarket A/C knobs -Aftermarket LED license plate lights -Console organizer -JBA High Caster UCAs
    You should not need to remove the tie rods to install new coilovers in a 2nd gen Tacoma. I have redone my UCAs, LCAs, and coilovers, all without difficulty of tie rods getting in the way, and without removing any steering related parts.
    reidkm and stickyTaco like this.
  12. Jun 27, 2019 at 7:17 AM
    Uphillshunter
    Matt - KN6DZP
    Hughson, CA
    The fact that he's replacing UCAs would make it easier to replace the Shocks without popping the tie rods. But otherwise, you're working harder than you have to, if you're not popping them.
  13. Jun 27, 2019 at 7:21 AM
    Ccrames2018
    Caden
    Nor Cal
    07 AC 4x4 V6 6MT
    Yeah I guess, as long as you're fine paying a little to use the tool. To each his own:cheers:
  14. Jun 27, 2019 at 7:41 AM
    Uphillshunter
    Matt - KN6DZP
    Hughson, CA
    A little used tool? LMFAO :rofl:(definitely not a little used tool for me)
    It's a 15 dollar tool. It's not only a good tool to have for doing lifts, I also keep it with my trail tools in case I need it.
  15. Jun 27, 2019 at 8:33 AM
    Ccrames2018
    Caden
    Nor Cal
    07 AC 4x4 V6 6MT
    Not a little used tool, I only said you have to pay a small amount to use the tool, which in my case specifically wasn't necessary. That said, it is just $15 so it couldn't hurt. Also if you're using it occasionally on the trail it would 100% be worth having. I usually don't wheel hard enough to break parts so I'm not worried about it for myself.
    Uphillshunter likes this.
  16. Jun 27, 2019 at 8:44 AM
    Uphillshunter
    Matt - KN6DZP
    Hughson, CA
    Admittedly, I'm in a different situation. It really makes having the Pittman Arm puller handy. Thankfully I've never needed it on the trail, but it doesn't take up much room, and if I ever do need it, it would be a lifesaver. (Ball joints are a weak point for us 1st genners), so it's bast to be prepared).
    I also host a lot of Mod Days. It has happened where I've lifted 2 or 3 Tacomas on the same day. So, anything I can do to speed up the process (and eliminate the chance of fucking up someone else's truck) is highly welcomed.
    Ccrames2018 likes this.
  17. Jun 27, 2019 at 8:49 AM
    Ccrames2018
    Caden
    Nor Cal
    07 AC 4x4 V6 6MT
    Well good on you for helping out with the mod days, I always wanted to do a few around my area but there's not many TW guys here. I'm sure it makes everything way easier having a few more hands and brains to tackle stuff with.
  18. Jun 27, 2019 at 8:57 AM
    Bebop
    Bebop Old fashion cowboy
    Nick
    Castle rock Colorado
    2012 Toyota Tacoma baja
    6inch lift sitting on bilstein coilovers. Lexus is300 studs in front to keep stock wheels, general grabber red letters, nfab front bumper.
    Never failed me in over 10 years of auto service
    reidkm likes this.
  19. Jun 27, 2019 at 8:59 AM
    PCTaco
    PCTaco 36 hour Build
    Adam
    New Columbia, PA
    '18 Access Cab TRD Offroad RIP '13
    Working on it
    Why would you pull tierods when you can just pop the ball joint any time you want to do work on the struts?
  20. Jun 27, 2019 at 9:12 AM
    JeffBoyardee
    Jeff
    Seminole, FL
    I plan to cut the cab mount, then drive it to a friends place to weld the plates on after.
