Top console gone bad
Discussion in 'Technical Chat' started by tacomavol87, Oct 30, 2012.
  1. Oct 30, 2012 at 5:11 PM
    tacomavol87
    tacomavol87 [OP] Member
    Caleb
    Tennessee
    05 Speedway Blue Base TRD Off-Road
    Hey guys, the top console (where the thermometer and compass are) in my 05 Taco has quit working. My first thoughts are either a fuse is blown, or the bulb is bad. However, I can't figure out which fuse is the correct one, even with a Chilton-Haynes manual. Also, if it is a bulb, is this a simple DIY fix, or one that I should have done at a dealer?
  2. Oct 30, 2012 at 5:16 PM
    beaver_scott
    beaver_scott Well-Known Member
    scott
    renton, wa
    2015 inferno trd pro
    vent shades, tinted windows, clear bra, pop n lock tail gate lock, anytime fog light mod.
    there is a write up on the overhead compass temp fix. there are two soldered resistors and one of them has most likely broken off. it is a common problem and it has happened with my tacoma too. i bought some resistors at frys and soldered a new one in place of the old resistor. works like new. type in overhead compass fix in the search tab and you should find a detailed write up.
  3. Oct 30, 2012 at 5:17 PM
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
