Top plate spacers to Bilstein 5100 shocks for extra lift?
Discussion in 'Suspension' started by Bayou2coma, May 13, 2008.
  1. May 13, 2008 at 2:28 PM
    Bayou2coma
    Bayou2coma [OP] Active Member
    Can I add 1/2" or 3/4" top plate spacers to my Bilstein 5100 shocks for extra lift to make it 3" in the front? I have it adjusted to 2.5" but i would like to go higher to be able to put some 33's!
  2. May 13, 2008 at 3:11 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    I guess you "can", but it would be horrible on your ball joints.
  3. May 13, 2008 at 5:15 PM
    TACOMAN22
    TACOMAN22 Well-Known Member
    agoura hills
    Debadged TRD offroad, bhlm, black surround grill,
    K&N drop in air filter,flowmaster 40 series, blue interior neon, bhlm, color matched grill, alpine head unit w/ infinity reference series speakers, insane driver.....
    couldnt new uca's fix that?
  4. May 13, 2008 at 5:21 PM
    RCNG FAN
    RCNG FAN Active Member
    Don't they specifically say not to do that?
  5. May 13, 2008 at 5:26 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Yes it would. But, what about the lower joint?
  6. May 13, 2008 at 5:27 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    I think they do. :)
  7. May 13, 2008 at 5:29 PM
    rick
    rick `
    no you cant. mine are on the top notch and im runnin 33s
  8. May 14, 2008 at 4:03 AM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    You could run a 1/4" spacer (1/2" lift) and that's about as far as you'd wanna go.
    If you get any bigger, your coil springs can come in contact with the steering knuckle because your upper a-arms are sitting down too far.
  9. May 14, 2008 at 7:08 AM
    Bayou2coma
    How much triming did u have to do to fit those 33's?
    BTW I probably can adjust the shocks to the lowest setting and put a 3" spacer.
  10. May 14, 2008 at 8:15 AM
    nd
    nd Radical Town. It's a hell of a place!
    Nate
    Greenville, SC
    07 TRD Off-Road 4x4 debadged
    De badged, 5100's, Black Toyota Baja wheels
    yes, it's highly recomended that you not do that. you can fit 33's with 2.5" lift, you will just have to trim the wheel well, but you probably have to do that with a 3" lift anyway.
    yes, you can do that and you will have superior shocks to the factory billies. the 5100's ride very well
  11. Sep 29, 2008 at 2:46 PM
    Bayou2coma
    On this 3" toytech lift it comes with the 1/2" spacer which adds 3/4" of lift.
    Sorry I just don't understand why it would be damaging I couldn't put this
    1/4" spacer on my 2.5" lifted 5100's (which would make it 3" of front lift all together) ...Which this part was made to correct the drivers side ride height.
    What I'm trying to know is whats the difference in this and a regular 3" lift???
    Please help! Thanks
    Elix
  12. Sep 29, 2008 at 7:43 PM
    sooner02r1
    sooner02r1 Well-Known Member
    You can fit 285/75-16 or 285/70-17 which is a fraction of an inch under 33" tall with minor trimming. So just run 2.5" in the front, mount the tires, and don't do crap that the suspension designer told you not to.
  13. Sep 29, 2008 at 8:00 PM
    Janster
    Jandy
    Lancaster, PA
    I never hear the 2nd gen guys talk about body lifts...why is that?
    I don't like body lifts either but 1" body lift isn't all that bad and can make that extra room instead of 'trimming'
    Back when I had my 96 tacoma...the 1st gen guys were putting 2.5" front suspension lifts & 2" body lifts to fit 33's....
  14. Sep 29, 2008 at 8:02 PM
    Khaos
    Khaos Big Member
    Bryant
    Jacksonville, Florida
    2011 DC TRD SPORT Prerunner
    3” spacer lift, 285/75/17 KO2, Spidertrax 1.25” spacers
    Convert the 5100s to Toytec adjustable C/O's. Then you will get a better ride and be able to have over 3" of lift if you want...
    Bilstien/Toytec/Everyone/Jesus says not to run the 5100s with spacers (if the 5100s are set above 0).
  15. Sep 30, 2008 at 2:30 PM
    KMADA
    KMADA Well-Known Member
    Long Beach, CA
    08 prerunner trd sport
    15% tint, 6k HIDs, K&N intake
    so with a 3" spacer and 5100s at stock settings..
    How would that be?
  16. Sep 30, 2008 at 2:46 PM
    KMADA
    Long Beach, CA
    Even if the guy does no off roading at all?
    I was just wondering..
    I'm actually going with the ome setup with 5100s rear
  17. Oct 1, 2008 at 8:11 AM
    nd
    Nate
    Greenville, SC
    its not a waste, the 5100's are better heavier duty shocks with a better ride than the factory bilstiens.
  18. Oct 1, 2008 at 8:59 AM
    nd
    Nate
    Greenville, SC
    I guess if you wanted the 3 in lift and a better ride. i dunno, i didnt say it made a ton of sense but i dont think it would be a waste. you get heavier duty shocks out of the deal
  19. Sep 19, 2010 at 11:06 PM
    ColtsTRD
    ColtsTRD Well-Known Member
    Scott
    AZ
    I was thinking of getting toytecs 1/2" spacers too but after reading this I think instead I'll just get the one 1/4" plate to counter the lean...I know I can still run 285s for sure! :cool:
  20. Sep 20, 2010 at 7:23 AM
    tacobox
    tacobox Evasive Maneuvers PMKMS
    You could also run. OME 885s and a spacer with the 5100s @ 0. That would prob be the best, cheapest and the most correct way to go.
    jross20 likes this.
