Top Plate Spacers
Discussion in 'Suspension' started by HSmith_11, Dec 11, 2017.
  1. Dec 11, 2017 at 5:10 AM
    HSmith_11
    HSmith_11 [OP] Tacoma Enthusiast
    Hunter
    Madison, Va
    2001 Ext Cab SR5 4x4 MT
    5100/OME 881s 1.5" Progressive AAL 33x12.50X15 KO2s
    I'm currently running Bilstein 5100s on stock coils set at the highest setting (2.5"). I was going to get new coils (OME 881) + a 3/8" top plate spacer to get closer to a full 3 inches.
    However, I would rather not spend $220 right now on such a small amount of extra room in my wheel well (also to level my truck out some more).
    So, would a top plate spacer work on my current setup with the pre-loaded stock coils? I'm not too worried about ride stiffness because I like how it is now. Thanks
  2. Dec 11, 2017 at 5:19 AM
    MadRiverTaco
    MadRiverTaco Join TW, they said. It's free, they said.
    Brenden
    Waterbury, VT
    2012 Black DCSB TRD OR "Caroline"
    King 2.5 Ext. w/ Compression Adjusters (Front & Rear), Dakars w/ D29XL, TC UCA's & LCA's, ARE CX, 17" SEMA Pro's, 265/70/17 Falken Wildpeaks, BORA spacers, Rigid Side shooter ditch lights, ATHF bedside reinforcements, OME carrier bearing drop bracket, extended rear brake lines, Northstar 27F battery, Yakima Jetsream crossbars, OEM roof rack, OEM skid plate, TRD Pro grill, URD TCAI, 5.7L Throttle Body, BensonX bedside tool mounts, fire extinguisher bedside mount, AMP research bed step, Redline Tuning hood struts, ECGS needle bearing mod, CV Boot slide mod, Differential breather mod, U-Bolt Flip Kit w/ Timbren Bumpstops, A-pillar RAM mount w/ cell phone holder, ProFX tow mirrors with turn signals and heat, "Raptor" lights, DEPO taillights, motorized Pop n' Lock
    A top plate spacer will get you to 3" but IMHO you should get new coils and let them do all the lifting to help preserve your suspension over the long run.
    Dhannah likes this.
  3. Dec 11, 2017 at 6:45 AM
    HSmith_11
    Hunter
    Madison, Va
    That was my plan for awhile, but I've been convinced by my wallet and mother that it would be better to not spend almost $300 right now because I don't wanna run out of money. Also, after this school year is over, I won't have my truck for year (college) so that would be a good time to do some major saving and modding.
  4. Dec 11, 2017 at 7:07 AM
    MadRiverTaco
    Brenden
    Waterbury, VT
    In that case I'd say get the top plate spacer to net the 3" up front but don't do any serious wheeling with it. You'll cause irreversible damage to your suspension that will run you much more than $300 to fix. If you're getting exactly 2.5" now you only need a 1/4" top place spacer to net you the 1/2" of lift.
  5. Dec 11, 2017 at 7:08 AM
    HSmith_11
    Hunter
    Madison, Va
    Thanks. Do you have any knowledge about installing the spacers? Do I have to compress the coils or anything?
  6. Dec 11, 2017 at 7:20 AM
    MadRiverTaco
    Brenden
    Waterbury, VT
    I don't believe that you have to compress the coils again because the top hat can remain intact. The spacer sits on top of the coil. Like this:
  7. Dec 11, 2017 at 8:32 AM
    HSmith_11
    Hunter
    Madison, Va
    Thanks for the pic. I'll take a look at my stuff after school.
  8. Dec 11, 2017 at 9:22 AM
    MadRiverTaco
    Brenden
    Waterbury, VT
    No problem. Not my truck but this is a helpful pic because the spacer is red.
