Top Radiator hose part number? V6
Discussion in '1st Gen. Tacomas (1995-2004)' started by Taylor, Jan 4, 2013.
  1. Jan 4, 2013 at 6:46 AM
    Taylor
    Taylor [OP] Wants to learn all about his Taco.
    Taylor
    Sterling, Virginia
    03 4x4 TRD SR5 College build
    Extra badges, painted skidplates, grey wire mod, Kenwood double-DIN headunit, pioneer amp, 12 inch MTX sub, playstation 2 under seat, Uniden CB with 5 foot Wilson 1000 antenna, deckplate mod, 4xinnovations sliders, diff breather mod, bilstein 5100s at all 4 corners, OME Dakar Leaves, BAMF BPV bracket, Wheelers greasable shackles,
    Hey guys, what's the part number for the Radiator hose that connects to the top of the radiator and goes through the timing belt cover to the block? Mine's starting to leak and I guess I need to replace it.
    Also, will the new one have the flanged end like mine does now, or will I have to heat and stretch it to get it over the tip?
    And will I need to drain the radiator if it's just the upper hose? I really don't have to money to do this.
  2. Jan 4, 2013 at 10:47 AM
    LexusIS808
    LexusIS808 Well-Known Member
  3. Jan 4, 2013 at 10:51 AM
    LexusIS808
    it will have a flange end. Just buy the premixed coolant from toyota. Thats about 40 bucks for the hose and coolant.
    drain radiator
    remove clamps for upper rad hose and remove hose.
    put new upper hose on and clamps into position
    fill radiator up and overflow to full line.
    DONE!!!
    I changed my top and bottom and they werent even leaking.
  4. Jan 5, 2013 at 1:01 PM
    Taylor
    Taylor
    Sterling, Virginia
    Thanks, guys!
