top speed governor
Discussion in '3rd Gen. Tacomas (2016-2023)' started by toyota16, Apr 11, 2016.
Thread Status:
Not open for further replies.
  1. Apr 11, 2016 at 9:48 PM
    toyota16
    toyota16 [OP] Well-Known Member
    2016 Inferno TRD Off Road 4x4 Double Cab 5' Bed w/JBL Premium Sound & and Technology Package
    Warn Semi-Hidden Kit Winch Mounting Systems 100044 DOBINSONS 2.0″ LIFT KIT DSSKIT22 Coils (C59-352 2" 110-240 front end load) Falken Wildpeak at3w 265/75r16 10 ply knurled radio knobs, machined aluminum, black anodize finish Dash top Multi-Mount with Ram Mount X-Grip Husky Liners Front 13951 & Rear 14951 N-Fab wheel to wheel T1580CC Toyota Black Out Emblem Overlay Kit PT948-35180-02 Toyota Bed Cover F-44x9-1200-ahxx Toyota Bed Mat PT580-35050-SB Toyota wheel locks PTR27-35100 Toyota Chrome Tip PT932-35162 Toyota Bed Divider PT767-35051 K&N Air Filter 33-5017 weather Tech Mud Flaps 110055 - 120055 Avs Bug Shield 25681 Avs Window Vents 94768 Cali Raised Led Light Bar 31.5" light bar in the lower bumper Suntek Window Tint on the front to match the factory rear
    Does anyone know if it is possible to remove the 116mph top speed governor through coding? If so, please help?
    Pussyslayer likes this.
  2. Apr 11, 2016 at 9:56 PM
    BrettsMac08
    BrettsMac08 Well-Known Member
    Kansas
    2016 DCSB TRD Sport | 2002 Camaro SS
    KDMax Tuned | MagnaFlow Exhaust | OEM Audio Plus Reference 450Q | TRD Pro Wheels | AT Tires | LED Interior Lighting
    Wait, you got to 116? I've yet to top 110 :rofl:
    Really though, this may end up :locked:
    Any particular reason to exceed 116 in a midsize V6 truck? I mean, a supercharged X Runner revival would be neat and all. Or you could pick up an older Mustang GT or Camaro SS and go fast with that while having some stability and on a track...
  3. Apr 11, 2016 at 9:56 PM
    Snowman
    Snowman I have a problem for your solution…
    Craig
    Somewhere in Canada
    Check out my build
    hahaha wow
  4. Apr 12, 2016 at 6:10 AM
    SilverII
    SilverII Well-Known Member
    DFW
    2016 Tacoma Limited 4x4 Blue
    wow... I havent gone past 90 in mine... Guess I am a slow driver
  5. Apr 12, 2016 at 6:12 AM
    4x4Runner
    4x4Runner Sam’s gone, man. Moderator
    Drunken Sailor
    Not north, not south, not west, mostly east
    1WD
    nuttin fancy
    Oh hello fella's. Anything of interest going on?
    Lukass and Large like this.
  6. Apr 12, 2016 at 6:15 AM
    dexterdog
    dexterdog My pee parts itch
    Oly WA
    2012 F150
    I am sure the OP is using his truck on a track or out in the desert and would like to exceed the governor if possible.
  7. Apr 12, 2016 at 6:21 AM
    DustStorm4x4
    DustStorm4x4 BBC 2020
    U S A
    04 Jeep LJ
    116? I got to 120 in a 13' Altima (closed course of course) 116 isn't bad for a truck. I say be happy with it, you shouldn't really go that fast anyways. :locked:
  8. Apr 12, 2016 at 6:25 AM
    mwc273
    mwc273 Nothing is as it seems.
    I believe the only way to defeat the limit(er) is to rewrite or flash the ECU. Since our ECUs are encrypted, the short answer is.... No.
  9. Apr 12, 2016 at 6:25 AM
    Joe D
    Joe D .
    I'm sure there's programmers or "chips" that either are or will be available.
    Most manufactures, when setting up electronic speed limiting, use tires that are only designed & rated for whatever the Vne is preset at... In other words the trucks top speed is probably set where it is because it's all your tires are designed to take.
    I gotta ask, under what circumstances would having something higher be used?
    ON EDIT: Nevermind that question I just remembered my avatar.
    arkywally and Large like this.
  10. Apr 12, 2016 at 6:27 AM
    splitbolt
    splitbolt Voodoo Witch Doctor
    NW Arkansas
    2016 TRD OFFROAD DCSB MGM
    Curious, as to what tire OP plans on running at those speeds...
    Large likes this.
  11. Apr 12, 2016 at 6:30 AM
    127.0.0.1 AKA ::1
    /etc/hosts
    2013 NBM AC 4.0 4x4 Auto OR
    are you sure there is a limiter ? or just physics ? going 116 in these boats requires massive horsepower at or beyond the limit
    of the motor
  12. Apr 12, 2016 at 6:31 AM
    DustStorm4x4
    U S A
    04 Jeep LJ
    There's definitely a limiter. When you go to that speed, there's plenty of momentum and a bit of horse to push it past 116.
  13. Apr 12, 2016 at 6:35 AM
    Xperivent
    Xperivent Well-Known Member
    ‘24 Supersonic ORP & '04 Impulse Red DC OR
    To speed up the ECU, therefore increasing the top speed limiter, you need to replace Microsoft Windows with Linux on your Tacoma. Make sure you get the 64-bit version.
    mwc273 likes this.
  14. Apr 12, 2016 at 6:36 AM
    DustStorm4x4
    U S A
    04 Jeep LJ
    Or instal iOS 7.
  15. Apr 12, 2016 at 6:39 AM
    mwc273
    And quit asking "WHY". He want's to go fast, that's why. When you're out in the middle of nowhere, all by yourself with 2 or 3 lanes of smooth pavement, it's fun! I used to have a Nissan Quest minivan that wouldn't shift into overdrive until 105 MPH if you kept the pedal to the floor... :eek: (most people wouldn't know that. but I do!)
  16. Apr 12, 2016 at 6:42 AM
    robssol
    robssol If it ain't broke, leave it the eff alone!
    Rob
    S. Wisconsin
    06 Tacoma, TRD Sport, SR5, 4X4, AC
    Frame 2.0, Fog lights anytime, Seatbelt reminder delete, Secondary air filter delete, LED bed lights, Running boards, 2017 Rims, Devil Horns by Andres, Ultra gauge, Cup holder/consol/glove compartment lights, Interior LED conversion, Blue Sea aux. fuse panel, fuse panel mounting plate by Yotamac, ProEFX heated towing mirrors, LED engine bay lights, Redline Quicklift Elite hood struts, Wet Okole Heated Seat Covers, Pop and Lock tailgate theft deterrent mod 2.0, Plasti-dip rear bumper. Decal free visors, Washable cabin air filter, Overhead consol auto dimming override switch, BulletProof Fabricating Skid plate, 2lo module.
    Not iOS 9.3 :puke:!!!
  17. Apr 12, 2016 at 6:42 AM
    psc199333
    psc199333 Well-Known Member
    Phillip
    2016 Trd off road
    Someone who isn't me(swim), borrowed my truck and drove over to a part of Germany's unrestricted autobahn. Swim reported back to me that truck will do about exactly 100 in 3rd and hits the limiter in 4th.
  18. Apr 12, 2016 at 7:36 AM
    UrbanT@co
    UrbanT@co Taco FANatic
    Craig
    Bay Area
    '16 DCSBOR 4x2
    * BAMF Grille *50% tint driver/passenger front window * NFAB steps * Bakflip F1 tonnaeu * Bed extender * Bed mat * Weathertech digital floor mats * Black reflective Tacoma tailgate decal
    I wonder if my ban hammer get out of jail free card is still valid?
    I wanna hear about what reinforcement and suspension upgrades are planned to support Evel Knievel's quest to push 116mph.
    This thing is going to be so fast it's going back to the future.
    Project Marty Mcfly.
    :popcorn:
  19. Apr 12, 2016 at 7:39 AM
    Large
    Large Red
    It's reckless.
  20. Apr 12, 2016 at 7:46 AM
    4x4Runner
    Drunken Sailor
    1WD
    nuttin fancy
    Because it's against TW's Code of Conduct.
Thread Status:
