Topher's build
Discussion in '1st Gen. Builds (1995-2004)' started by presto, Nov 21, 2013.
  1. Mar 5, 2015 at 12:08 PM
    #241
    presto
    presto [OP] Well-Known Member
    Topher
    san francisco
    2000 T4R 4x4
    Fully armored on 33’s
    Yea that's a good idea about the 10mm spacers. I already have some 3/8" spacers sitting in my garage but those might be too big lol.
    I was wondering why you didn't go w/ 883's actually? Maybe because you have the tube trail gear bumper? I'm pretty sure I remember reading that my AP tube bumper weighs in close to most plate bumpers. I'll just make sure to ask the dudes at wheelers and I'm sure I'll be fine with whatever they recommend.
  2. Mar 10, 2015 at 8:59 PM
    #242
    presto
    Topher
    san francisco
    2000 T4R 4x4
    Alright! Tacoma is back in action. Got some good ol wrenching done today. I'm pretty happy with the shocks toytec sent me, they are basically brand new except for the springs! Even gave me free shipping! They also got rid of the heim joints and just put rubber bushings in their place which I like actually. (Less moving parts less shit to brake..) also re booted my passenger side CV axle. Installed the cbi hood mounts and put my antenna on for shits and giggles lol.. Then I banged out my fender wells a little so my tires wouldn't rub on the way home. Got a lot done today!
    Pictures will come tmrw.
  3. Mar 10, 2015 at 9:13 PM
    #243
    johnboyTRD
    johnboyTRD Well-Known Member
    South SF bay
    2003 Tacoma Double Cab TRD
    Full ome lift, nitro charger sports all 4 corners (rear shocks relocated), Dakar pack w/ AAL, 882 coils, diff drop, toytec 1" shackles, trail gear low profile front bumper, Tuff Stuff winch, bamf sliders, RAT skids, BAMF Bed Rack, Tepui Kukenam RTT, RAT rear bumper,
    Sick, how's power loss?
  4. Mar 10, 2015 at 9:25 PM
    #244
    presto
    Topher
    san francisco
    2000 T4R 4x4
    Haha it's not that bad actually.. For some reason my speedometer is spot on perfect now though. Definitely foresee a regear w/ ARB locker in rear coming within a few months.
    I'm hoping the 04 exhaust manifold I swap in will help a little bit and the new vapor canister.
  5. Mar 11, 2015 at 10:43 AM
    #245
    presto
    Topher
    san francisco
    2000 T4R 4x4
    pictures!! lol..
    Heres me trying to figure out how the hell to get the new cv boot on..
    Heres the new shocks from toytec, will be greasing these tonight for rust prevention.
    Heres how i mounted my antenna/ran the cable, i like how it uses the old antenna hole..
    and here it is with the new tires on
  6. Mar 13, 2015 at 9:55 AM
    #246
    presto
    Topher
    san francisco
    2000 T4R 4x4
    Got some nice stainless pipe clamps on my intake instead of those crappy wire clamps.. Also got most of my blue silicone vacuum lines on, don't think any of those actually made a difference but it looks/feels cleaner in the engine bay now.
    Thinking I'll do the deck plate tonight if I can find some silicone/gasket sealer type stuff in my tool buckets.
  7. Mar 23, 2015 at 12:45 AM
    #247
    SnowroxKT
    SnowroxKT Well-Known Member
    Kyle
    Anchorage Alaska
    2008 TRD OR
    Were you able to do the deck plate? I'm curious if that will help your acceleration noticeably.
  8. Mar 23, 2015 at 8:14 AM
    #248
    presto
    Topher
    san francisco
    2000 T4R 4x4
    i bought the wrong size deck plate hahah.. opps.. new one should be arriving today so i will let you know.. i haven't put on my 04 exhaust manifold yet either, still kind of in the process of porting them (its taking forever)
    some updates of things I've done:
    finished redoing all my vacuum lines with blue silicone lines.
    redid a lot of my old stereo wiring/test fitted CB radio
    cleaned up a ton of little rust spots
    fixed the passenger door lock
    vacuumed the carpet
  9. Mar 23, 2015 at 8:26 PM
    #249
    presto
    Topher
    san francisco
    2000 T4R 4x4
    Got my cb radio mounted today and the coax cable is connected. Only thing I'm waiting on is the switch for it. I kinda put a little hole in my heater duct but nothing a little duct tape can't handle lol..
    Also does anyone know where to get rubber grommets or something to prevent water from getting in the hole I put the cable through?
  10. Mar 23, 2015 at 8:30 PM
    #250
    Delta00
    Delta00 ᕕ( ᐛ )ᕗ
    Troy
    Chandler AZ
    2002 Toyota Tacoma 4WD
    Check Build
    Wow, that looks great! Super flush!
  11. Mar 23, 2015 at 9:00 PM
    #251
    presto
    Topher
    san francisco
    2000 T4R 4x4
    Thank you! Yea once I poked a hole through the heater duct I was like screw it midswell go as far back as I want at this point. Haha..
  12. Mar 23, 2015 at 9:24 PM
    #252
    johnboyTRD
    South SF bay
    You gotta help me with my cb man, that is pretty slick!!!
  13. Mar 23, 2015 at 9:27 PM
    #253
    presto
    Topher
    san francisco
    2000 T4R 4x4
    Yea man no prob, next time I see you. Thanks!
  14. Mar 23, 2015 at 10:21 PM
    #254
    johnboyTRD
    South SF bay
    Hopefully soon, maybe slick rock?
  15. Mar 23, 2015 at 10:49 PM
    #255
    presto
    Topher
    san francisco
    2000 T4R 4x4
    I might come for the camping this run, but my girlfriend doesn't get off school(every Saturday) until around may 16th ish. After that I will probably be coming to a lot more trips. Plus I should have locker/gears around then too.
  16. Mar 24, 2015 at 12:29 AM
    #256
    SnowroxKT
    Kyle
    Anchorage Alaska
    2008 TRD OR
    How big is the whole you need to seal? I like to split fuel line hose long ways and use that to protect wires (by using the rubber hose as a sort of ring type grommet or sharp edge covering), but that might not seal as good as you want. Did you drill a hole or use a factory hole?
  17. Mar 24, 2015 at 6:22 AM
    #257
    presto
    Topher
    san francisco
    2000 T4R 4x4
    Used the factory antenna cable hole, just had to enlarge it slightly for the coax to fit through. I found a nice grommet made by firestick for the exact purpose of what I want.
  18. Mar 24, 2015 at 8:23 PM
    #258
    presto
    Topher
    san francisco
    2000 T4R 4x4
    Deck plate mod (check)
    Also soldered some wires up. Soldering in the wind sucks, I think it was also cause the wires were not super clean..
  19. Mar 25, 2015 at 8:21 AM
    #259
    presto
    Topher
    san francisco
    2000 T4R 4x4
    not really sure if i noticed anything after installing the deck plate, it did seem a little bit smoother/easier to accelerate. Hopefully i can get this 04 exhaust manifold on soon.
  20. Mar 25, 2015 at 9:18 AM
    #260
    SnowroxKT
    Kyle
    Anchorage Alaska
    2008 TRD OR
    That's about what I noticed around town, but it helped on sustained freeway climbs (or passing).
