Topped off coolant with non-OEM...Drain immediately?
Discussion in 'Technical Chat' started by jlleiber, Mar 27, 2013.
  1. Apr 11, 2013 at 5:48 AM
    jlleiber
    jlleiber [OP] Well-Known Member
    Justin
    Indiana
    2009 TRD Sport
    Coming soon!
    So it definitely drained out while just sitting there on vacation. Found a pink pool on the ground directly below where the reservoir sits. However, I can't for the life of me find any pink residue in the engine compartment anywhere. Also, I removed the radiator cap and the liquid under there is yellow?? I would assume this is from the previous owner putting whatever coolant in there he had. So, any ideas as to where it may be leaking while the truck IS NOT running? Any thoughts is appreciated. I'm on the verge of just taking it to the dealership now
  2. Apr 11, 2013 at 5:59 AM
    KenLyns
    KenLyns 8-in. Third Member
    Belly of the Beast
    4x4 TRD Off Road Full-Auto
    All-Pro Bumper, CBI Sliders, Icon Coilovers, BudBuilt Skids, aFe Intake, Icon VS Rear Shocks, Timbren Bumpstops, All-Pro UCAs, JDM Steering Wheel, ViAir Compressor, Klearz LED 3rd Brake Light, Pop-N-Lock Tailgate Handle, Husky Front Flaps
    Take it to a shop and ask them to pressure test the cooling system. This should expose most leaks.
  3. Apr 11, 2013 at 9:02 AM
    jlleiber
    Justin
    Indiana
    2009 TRD Sport
    Coming soon!
    Called my local dealership and the lady told me they typically do a die of some sort, which makes little sense to me since the stuffs already pink? And I asked if they pressure tested cooling systems and she sounded clueless. Also, just to LOOK at the truck, it'll be $75. Beyond me.
    Any recommendations as far as shops to go to?
  4. Apr 11, 2013 at 9:06 AM
    maxamillion2345
    maxamillion2345 Make Nevada Great Again, build the wall
    Max
    Nevada
    80 series LC
    Tons and 40s
    UV dye, you add it to the system and then when it leaks out you can use a blacklight and some yellow glasses to trace it back to the source of the leak. Comes in a nifty little kit for like 25 30 bucks or something.
  5. Apr 11, 2013 at 9:13 AM
    jlleiber
    Justin
    Indiana
    2009 TRD Sport
    Coming soon!
    Ahhh nice! Just found the 3 parts to the kit on Amazon for $20. Might give that a go.. Thanks :thumbsup:
  6. Apr 11, 2013 at 5:27 PM
    chriss
    chriss Well-Known Member
    chris
    Check the drain fitting on the bottom of the reservoir.
  7. Apr 11, 2013 at 9:03 PM
    jlleiber
    Justin
    Indiana
    2009 TRD Sport
    Coming soon!
    Yep checked that first. Ended up crawling under the truck tonight and pulled off the skid plates to get a better look and saw pink residue on multiple bolts on the water pump, so I'm afraid that the seal and water pump itself have gone bad :/
  8. Apr 11, 2013 at 9:05 PM
    maxamillion2345
    Max
    Nevada
    80 series LC
    Tons and 40s
    Are the bolts tight :p
  9. Apr 12, 2013 at 5:20 AM
    jlleiber
    Justin
    Indiana
    2009 TRD Sport
    Coming soon!
    haha, well it's on 3 of them so hopefully not all of them rattled loose...
    here's a pic.
  10. Apr 12, 2013 at 10:03 AM
    maxamillion2345
    Max
    Nevada
    80 series LC
    Tons and 40s
    Definitely looks like it's running down from above.
  11. Apr 12, 2013 at 10:16 AM
    medusa1066
    medusa1066 Well-Known Member
    Jonathan
    Morgantown, WV
    2007 4x4 TRD Sport
  12. Apr 12, 2013 at 10:23 AM
    jlleiber
    Justin
    Indiana
    2009 TRD Sport
    Coming soon!
    Would that be a bad seal then? It looks like it's coming from behind the water pump, which I can't see at all. Is the only option to take it off and check?
    Also, the pic I took is a little misleading - I was crawled under the truck so I think it's sort of upside down. The direction that the leak appears to be coming from actually wraps around the bottom of the water pump
  13. Apr 12, 2013 at 10:24 AM
    jlleiber
    Justin
    Indiana
    2009 TRD Sport
    Coming soon!
  14. Apr 17, 2013 at 12:12 PM
    93civEJ1
    93civEJ1 Well-Known Member
    09 DC TRD OR
    Procomp 6" Stage 1, Bilstein 5100's in front, flowmaster 40 series
    This.
    You cant really mix with Toyota Red from what I have read, but water has better cooling propertys, thats why its ok to top off with water.
  15. Apr 17, 2013 at 12:26 PM
    #35
    jlleiber
    Justin
    Indiana
    2009 TRD Sport
    Coming soon!
    Perfect thanks!
    For now I have a bottle of distilled water and a jug of Toyota Pink sitting in the back. And alternating adding each one until I get to replacing the water pump here in the next couple weeks.
