Torn between leaf springs!! Help!!
Discussion in '2nd Gen. Tacomas (2005-2015)' started by abqnurse80, Aug 22, 2017.
  1. Aug 22, 2017 at 4:29 PM
    abqnurse80
    abqnurse80 [OP] Well-Known Member
    Nic
    ABQ, NM
    2012 FJ Cruiser
    Bilstein 5100 all around, first clip front. AVS window visors, BFG AT KO2s. JBL.
    So about to pull the trigger on some new leafs. Currently 2012 Baja sitting on some brand of a 3 pack aal. Squeaks, like rusty, and over all stiff. Occasionally carry loads of a few hundred pounds, but mostly just some tools and a spare in the bed, maybe about 150lbs. Plan on steel bumper rear, and currently have steel rci sliders. Will be upgrading to fox 2.5 ex coils with dsc in the front, already have icon ucas, rear will have fox 2.0 ex res with compression adj 985-26-117. Deciding between skyjacker softride, wheelers 8 pack, darkar el095r, or custom alcan 8 pack. Looking for a softer ride and flex. 80 road, 20 offroad. Mix of high and low speed . Would want around 2.5 inches of lift,zoya's give or take. Just asking for recommendations, advice, thank you for any info!!!
  2. Aug 22, 2017 at 10:00 PM
    TacoZim
    TacoZim Well-Known Member
    Bay Area, CA
    2008 DCLB
    Just kind of briefly skimmed your post, but have you looked into All Pro's leaf packs? I bring them up cause I think they're still running a 25% sale now. Just another option to throw in the mix.
  3. Aug 22, 2017 at 10:45 PM
    desertrunner24
    desertrunner24 Well-Known Member
    Jake
    Fresno , CA
    2011 TRD offroad 4x4
    Some
    All pro expo or Dakar are your best option. If you want a soft ride though deavers j66 pack but won't give you a full 2.5" of lift without different shackles
    Ritchie likes this.
  4. Aug 23, 2017 at 12:29 AM
    Buckwheat893
    Buckwheat893 Well-Known Member
    Cody
    Tucson, AZ
    2011 AC
    Love my dakars. They ride like a dream, no bucking over bumps, no violent jarring, they seem to soak everything up and have awesome travel. Loaded they feel more like a factory leaf on a full size truck, but seem to maintain height instead of sagging. I got exactly 2.5" out of mine, they are the el095r you mentioned.
    Yager78 and musher like this.
  5. Aug 23, 2017 at 12:51 AM
    crazysccrmd
    crazysccrmd Well-Known Member
    Alaska
    Aprilia Tuareg 660
    You'll want to go with the EL096R kit if you decide on Dakars. The 95Rs will only give their full rated value with no weight on the truck. With a load of about 200lbs in the bed and 125lbs in the backseat and roofrack I got 1.5" of lift from the 95R kit. If you intend to regularly carry 150lbs and add a steel bumper you will want the heavier spring rate of the 96R kit.
    musher likes this.
  6. Aug 23, 2017 at 5:58 AM
    abqnurse80
    Nic
    ABQ, NM
    2012 FJ Cruiser
    Can you not get the 95s then the additional leaf to basically make it the 96?
  7. Aug 23, 2017 at 6:07 AM
    Pigpen
    Dan
    Northwest Montana
    That's what I did. I wish I hadn't. I regularly carry 500-600 pounds in my bed. It rides nice, but sits higher than I would like.
    I have a 3" lift up front. With all that weight in the rear, I still have over 2" of rake. I have driveline vibes too. Even with the CB drop. I'll be buying a single piece drive shaft. Lifting these trucks is like throwing a gremlin in a pool.
    charcharias, TRDSport10 and smw62891 like this.
  8. Aug 23, 2017 at 6:13 AM
    abqnurse80
    Nic
    ABQ, NM
    2012 FJ Cruiser
    That it is.. forgot about the Allpro springs... 3 inches seems a bit higher than I want to go... Really leaning twords the darkars... But are they flexible enough?
  9. Aug 23, 2017 at 6:27 AM
    VangaSTL
    VangaSTL Well-Known Member
    Garrick
    St. Louis, MO
    2016 TRD Sport 4x4
    Agreed, I have the 95s and it's great for me because my bed is usually empty, sometimes I have a tool bag but not much. If you plan on getting steel bumper and still hauling, you'll definitely want the 96s.
    Yes, if you purchase the 95r and then the EL46XL, it would be the same as the 96r but it would be cheaper to just buy the 96r up front. I also recommend investing in a good bushing set. I got the Energy Suspension bushing kit and have been very happy with it.
  10. Aug 23, 2017 at 6:29 AM
    ChadsPride
    Sponsored by TacomaWorld.com
    Yes, offloading enthusiasts like them for their ability to handle a load and have the desired flex.
  11. Aug 23, 2017 at 6:31 AM
    geekhouse23
    geekhouse23 The "Liftman" - @DrFunker
    2GMGMDCSB4WDTRDFTMFW!! TL;DR
    mostly stock, grocery gettin' Prius
    Dakars with the AAL shackle flip and 12" shocks. GREAT setup for lots of weight and flexes like crazy. Rear steer bumper soon!
  12. Aug 23, 2017 at 6:35 AM
    3pooches
    3pooches Well-Known Member
    VA & WV
    15 tacoma dcsb Sc Linked, 2014 reg cab locked
    I have 95s and love them. Carry an occasional load and pull a 12' trailer with toys and they have been great. Figured I'd insert the extra leaf if I do a bed rack and gear in the future
  13. Aug 23, 2017 at 6:38 AM
    Coot83
    Coot83 DORKEL NATION
    Scottsdale, Az
    2012 Baja TX
    TC 3.5 LT, RCV axles, Demello sliders, BD light bar/fogs, LP6, DMZ rear, SOS skids, custom bumper, King 16" triples, Locked-on hydro rear bumps...
    My buddy @90yota just swapped out his dakars for some all pro leafs. From what I have heard, dakars are solid, but All pro leafs might be the better option.
    90yota and Lord Helmet like this.
  14. Aug 23, 2017 at 6:40 AM
    VangaSTL
    Garrick
    St. Louis, MO
    2016 TRD Sport 4x4
    BLASPHEMY! BURN THE WITCH! :bananadance::bananadead::bananadance::oldglory:
    Yager78, 3pooches and abqnurse80[OP] like this.
  15. Aug 23, 2017 at 6:40 AM
    abqnurse80
    Nic
    ABQ, NM
    2012 FJ Cruiser
    Don't you have to do the shock relocate with this? Looks awesome!!
    3pooches likes this.
  16. Aug 23, 2017 at 6:41 AM
    Coot83
    Scottsdale, Az
    2012 Baja TX
    I will be honest here, SUA is my game, but hopefully my buddy can chime in on his thoughts.
  17. Aug 23, 2017 at 6:41 AM
    geekhouse23
    Yes. I have the BAMF kit
  18. Aug 23, 2017 at 6:41 AM
    abqnurse80
    Nic
    ABQ, NM
    2012 FJ Cruiser
    Yeah, allpro vs darkar... Hmmmmmmm
  19. Aug 23, 2017 at 6:42 AM
    Coot83
    Scottsdale, Az
    2012 Baja TX
    Yep, which he likely has the BAMF brackets. I would recommend getting the archive relocation brackets as they are bolt on so no guessing in the bracket to get them to fit. When I got my 12s on, Bamf had jack shit for references and half of the install was understanding what was the proper angle. Also with the archive you can jam 14s in there I believe although that might require a shackle flip as well.
  20. Aug 23, 2017 at 6:42 AM
    greeneggsnspam
    greeneggsnspam ಠ_ಠ
    Houston, TX
    .gif
    Too poor to list anything interesting.
    Dakars are great with a load in the bed.
    If you're into DIY and handy with some tools, how about the Chevy 63 swap?
    https://www.tacomaworld.com/threads/how-to-chevy-63-leaf-spring-swap.377756/
