tornado air system?
Discussion in 'Performance and Tuning' started by victorye3, Nov 11, 2007.
  1. Nov 11, 2007 at 3:05 PM
    victorye3
    victorye3 [OP] Western Alliance-NorCal
    Fresno/Tulare, CA
    06 PreRunner SR5 TRD Off Road
    Has anyone installed a tornado air system in there taco? I was told that it gives you an extra 5 to 8 hp.
  2. Nov 11, 2007 at 4:23 PM
    Sizzler
    Sizzler Member
    Will do no good, waste of money.
    But, If you want to try it.
    Dyno before and after install.
  3. Nov 11, 2007 at 5:17 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    dont waste your money..........it will not do anything for you.
  4. Nov 11, 2007 at 8:27 PM
    victorye3
    Fresno/Tulare, CA
    yah it sounded like just a piece of metal! But someone told me it work but maybe for there type of truck.
  5. Nov 11, 2007 at 8:45 PM
    TuRDTACO
    TuRDTACO Carolina Alliance: Midwest Firearms Division
    joliet, il
    HAD 07 TRD OFFROAD PRERUNNER
    small dent on the hood, new foglight bulb, roughed up bedliner, been smoked in, suspicious stains on the passenger seat, boogers on the drivers seat, dirty floor mats, girl doodles on the dirty windows, loose wiring
    i've seen them tested on a few cars/trucks, it actually decreases HP on most because of this...
    The idea behind the Tornado intake mod was that swirling the air will cause it to be more turbulent, supposedly being a more effective burn when mixed with the fuel sprayed in by the injectors. While the idea looks good on paper, the reason that it actually DECREASES power is that the intake air is slowed down because it has to work it's way around the Tornado thing, so your engine isn't getting as much air as it would if the intake was unrestricted like it was before the Tornado installation.
    The surfaces inside the intake manifolds and plenums within the manifolds ARE NOT smoothed out or polished, because the rougher surface moves the air and makes it more turbulent as it passes through the intake. If you were to polish and smooth out the inside surfaces of the intake, you would also lose power because the intake air is just flowing straight in and doesn't have enough turbulence(sorry for using the word so much but i can't think of a synonym haha) to properly mix with the fuel. The more the air and fuel move around before entering the cylinders, the better the mix, therefore you get more power, better MPG and less emissions because a better mix is a better, more thorough burn.
    To sum it up, the Tornado was a good idea but it acts as a restriction in the intake, and the inner surfaces of the manifold and plenum is plenty enough to get the air moving around as it passes through on the way to the cylinder.
    Buy an intake kit instead lol, a k&n 63-series aircharger will only be $200, won't throw CEL codes and i hear your MPG won't go down by an overcompensation in fuel from the MAF, which usually goes hand in hand with a CEL.
