Torque converter
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Brooker813, Dec 16, 2021.
  1. Feb 23, 2022 at 3:34 PM
    gearcruncher
    Canadain bumper technician
    OK
    so we can confirm that when the converter locks directly to your engine , you get shaking.
    Im going to recommend spark plugs to start . This will eliminate the possibilty you are feeling a rough running engine at low rpm .
    A rough running engine can be seen very easy with a lab scope .
    Do the 6 Denso spark plugs first and a throttle body cleaning with your battery post removed then test drive when the truck is warm .
    Then go after Toyota for damaging the SLU circuit in your valve body for not performing a transmission service correctly .
    Dont care where you take the truck for a transmission service but you DO NOT FLUSH without removing the pan first
    If you do indeed have a converter shudder , replacing all the fluid and adding 10 ounces of Lubeguard platinum is your best chance at adressing the issue .
    ejl923 likes this.
  2. Feb 23, 2022 at 10:50 PM
    burrito782
    burrito782 Shit Throwing Ape
    08 TRD Off Road
    Any update (been a couple months now)?
    Keep us posted on what you end up doing and end result(s).
    auskip07 likes this.
  3. Apr 3, 2022 at 7:33 AM
    ejl923
    ejl923 Well-Known Member
    Eric
    Western Mass
    15 DCSB TRD Off Road
    Ok, did the tune up, maf, tb, plugs, air filter, and oil while I was at it. My idling is smoother, that’s noticeable. Hard to say if the shuddering got better as it seems to come and go. If I had to guess with my current information, I would say the shudder lessened.
    I still plan on doing a drain and fill, it’s time. If it’s only a drain and fill should I not add the lubeguard platinum? I know it’s better on a full fluid change, but I already have the lubeguard and I have to be in there anyway. Other than shuddering, I might get a couple hard shifts every now and then, but it’s certainly not normal for me. I would prob be ok with just the drain and fill, but if then LG platinum wouldn’t hurt anything I don’t mind trying it.
    thanks again
  4. Jun 7, 2024 at 3:47 PM
    scully
    scully Well-Known Member
    San Diego, CA
    06 TRD Doublecab
    Rear TSB FJ Cruiser TRD anthracite wheels Bilstein 5100's allround Tint
    Any updates on if it was the torque converter?
    Jgould1 likes this.
  5. Mar 12, 2025 at 10:25 AM
    BoiMeatWonder
    BoiMeatWonder Some idiot with a truck
    Central Florida
    2008 Indigo Ink Tacoma Pre Runner
    -Rocktrix wheels on 33” Arturo mt’s -2.5 level in front, 1.5 rear -Prinsu roof rack with cali raised 40”light bar -MBRP dual exit exhaust -Alpha Rex headlights -Aftermarket grill (forgot what brand) -Sound system
    Considering your the transmission expert around here, I tried the break tap test on my truck with the same issues and it was still shaking after pressing the break, what would that be indicative of? Thank you in advance.
    Mike Z likes this.
  6. Apr 30, 2025 at 4:50 AM
    ejl923
    Eric
    Western Mass
    I’ve since got rid of it, but I had the shimmy from basically 40k-150k, no real change and that includes plowing and towing from 80k on. I drove around in 4th a lot rather than D, unless I was on the highway.
    Jgould1 likes this.
  7. Apr 30, 2025 at 6:07 AM
    ejl923
    Eric
    Western Mass
    I added the additives, with no real change, but it never got worse
