Torque specs lug nuts
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Trucko, Apr 29, 2017.
  1. Mar 22, 2018 at 8:48 AM
    MolonLabeTaco
    MolonLabeTaco Well-Known Member
    Dude
    N. Texas
    '12 DC 4x4 OR
    I think mine says 76lbs & I feel the 76lbs. is too light. I do mine w/a torque wrench and it takes very little effort to get to 76lbs. I've upped it to 85lbs.
  2. Mar 22, 2018 at 9:33 AM
    cliffyk
    cliffyk Well-Known Member
    Cliff
    Saint Augustine, FL
    2009 DCSB SR5 TRD Sport 145k miles
    The 2nd Gen FSM, in several sections, states lug torque as "Torque: 113 N*m (1,152 kgf*cm, 83 ft.*lbf) [sic], should be lbf·ft or lb·ft.
    But let's back up a little--lug nuts are torqued to specific values in order to achieve a desired clamping/retaining force to keep the wheel on. tightening the lug nut does this by stretching the lug stud (within it's range of elasticity) to pull the wheel and hub against each other--at that point the wheel/hub are clamped together as intended and there is (per the design engineers's calculations) sufficient remaining tensile strength in the stud to withstand externally applied forces wishing to separate the wheel from the hub (hitting curbs/rocks/etc.).
    However once that desired clamping force has been achieved, and while further tightening of the nut does increase the clamping force, it also increases the tensile load on the stud, moving that load closer to the stud's yield point, meaning less external force would be required to load the stud to it's yield point.
    So while should be no immediate problem with torquing them to 96 lb·ft (a15% overtorque), nothing will be accomplished anything other than to increase the tensile preload on the studs by 25% to 30%--i.e. 25 to 30% closer to their yield point and more susceptible to yielding (failure) via externally applied forces.
    Going to 100 lb·ft (20% over-torqued) is ill-advised as it will increase the tensile preload on the stud by 35%+...
    It is best to stick to the design engineer's recommendations, as neither they nor Toyota have anything to gain by specifying a too low a torque value--and quite a bit to lose should wheels start falling off...
    BC Hunter, Jurist, Biscuits and 4 others like this.
  3. Mar 22, 2018 at 10:16 AM
    MurderedTacoV2
    MurderedTacoV2 Booty Admirer
    Adam
    Hudson, New Hampshire
    06 Taco TRD OR
    3 inch lift, B110’s, Dakars, Dirty5’s, Dual Locked
    TIS does state 76. Personally i prefer 85 ish with an extra little turn. So probably like 90.
  4. Mar 22, 2018 at 4:39 PM
    michael roberts
    michael roberts Well-Known Member
    san diego
    07,4x4, white, AC.
    powder coated hood support.
    Discount Tire used 300 lbs on two of the rear lugs, one on each side, last time they rotated the tires - genius.
    4x4cajun likes this.
  5. Mar 22, 2018 at 4:41 PM
    lynlan1819
    lynlan1819 Well-Known Member
    Tacoma
    Lifted
    83 ft lb
  6. Mar 22, 2018 at 4:49 PM
    ARB1977
    ARB1977 It’s a beaut Clark
    North Texas
    15 DCSB Prerunner 4.0L Blue Ribbon Metallic
    Black TRD Fj Cruiser wheels, TRD catback exhaust.
    German spec...good’en tight.
  7. Mar 22, 2018 at 6:45 PM
    cliffyk
    Cliff
    Saint Augustine, FL
    I an surprised they did not shear--or did they?
  8. Mar 23, 2018 at 1:22 AM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    And how did you measure the 300 lbs? Because I'm not buying that value. In my opinion the studs would snap off long before you reached that value. Even if they did over torque the lugs there is no way to measure what it was torqued to after the fact.
    Break away torque is a whole different animal and cannot be used to determine the tightening torque.
  9. Mar 23, 2018 at 2:24 AM
    cliffyk
    Cliff
    Saint Augustine, FL
    I was going to stay away from this, but now that you bring it up...The only way to check the tightening torque on freshly torqued (see comments re: heat below) fasteners is to tighten them more and then guesstimate the original torque (typically 5%t o 10% less than what it took to tighten it more. Once it has cooled all bets are off.
    Breakaway torque on a freshly tightened, still warm fastener is generally 80% or so of the tightening torque. Once the heat generated by the act of tightening has dissipated 100% to 120% is not uncommon...
    Jimmyh[QUOTED] likes this.
  10. Mar 23, 2018 at 4:21 AM
    ARB1977
    North Texas
    90 ft-lbs
  11. Mar 23, 2018 at 4:34 AM
    Jimmyh
    SC
    2012 Prerunner SR5
    Sometimes I just can't help myself... :)
    But as you said guesstimate.
  12. Mar 23, 2018 at 6:43 AM
    MolonLabeTaco
    Dude
    N. Texas
    '12 DC 4x4 OR
    I took it as he was simply implying they torqued the shit out of them, not actually torqued to 300lbs.
  13. Mar 23, 2018 at 4:14 PM
    Jimmyh
    SC
    2012 Prerunner SR5
    OK
  14. Mar 24, 2018 at 5:54 AM
    PzTank
    PzTank Stuck in the Well
    Above the Notches
    ‘15 AC SR5 4X4 4.0 Auto
    ‘07 OR leather shift knob
    Jimmyh likes this.
  15. Mar 24, 2018 at 6:10 AM
    #35
    cliffyk
    Cliff
    Saint Augustine, FL
    A great link, I have bookmarked it. He does not appear to delve into derived units such as torque (lb·ft)--not to criticize however, as that would be another whole can of worms...
    PzTank[QUOTED] likes this.
  16. May 4, 2018 at 5:33 AM
    #36
    fjrmurph
    fjrmurph Well-Known Member
    i just bring them as tight as i can get them , then a half a turn !!!!!!
    Boyk1182 likes this.
  17. May 4, 2018 at 5:40 PM
    #37
    michael roberts
    san diego
    07,4x4, white, AC.
    Back to this old post: they torqued them tight enough to strip them, then did not even tell me about it, just let me drive away. We all make mistakes, - especially if you are in a hurry, just tell me about it. Discount tires "free rotation" ended costing me money and time and a big headache. I am very wary of bringing it back there.
  18. Jun 21, 2018 at 6:35 AM
    #38
    PzTank
    Above the Notches
    Bump.
    After getting my steelies rebalanced twice due to horrible shakes, I raised and re-torqued all four wheels to 83 ft-lbf as indicated in my manual. I could tell by the force needed to break the lugs loose they were not consistently torqued.
    In retorquing, I used three steps to get to the 83 - first was 43, then 63 and then the final value 83.
    (The truck rides much better now but not perfect..)
    My question is, “how many steps do folks take to get to the final torque value?”
  19. Jun 21, 2018 at 7:05 AM
    #39
    WSW3
    WSW3 @willwitecki
    Will
    Connecticut
    '08 Tacoma DCSB TRD Sport
    Scratches, dents, and a lot of miles
  20. Jun 21, 2018 at 7:07 AM
    #40
    WSW3
    WSW3 @willwitecki
    Will
    Connecticut
    This guy engineers.
    Seriously though, thanks for posting this. Did the heavy lifting for me :thumbsup:
    Don't want these people to end up like the guy that broke all of his lug nuts yesterday...
    BC Hunter likes this.
