Torque specs lug nuts
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Trucko, Apr 29, 2017.
  1. Jun 21, 2018 at 7:22 AM
    #41
    cliffyk
    cliffyk Well-Known Member
    Cliff
    Saint Augustine, FL
    2009 DCSB SR5 TRD Sport 145k miles
    He must have cranked the piss out of those when he out them on with his shiny new impact wrench--that likely overstressed/fractured each nut's tower; removing them was the coup de' grâce...
    Horribly designed lug nuts BTW--with that necked down section between the tower to which torqued is applied and the seating segment of the nut. It's almost as though they were designed to break-away upon over-torquing....
  2. Jun 21, 2018 at 7:27 AM
    #42
    PzTank
    PzTank Stuck in the Well
    Above the Notches
    ‘15 AC SR5 4X4 4.0 Auto
    ‘07 OR leather shift knob
  3. Jun 21, 2018 at 7:33 AM
    #43
    cliffyk
    Cliff
    Saint Augustine, FL
    Not necessary, just snug 'em up by hand then torque to the final value (in a "star",criss-cross pattern)
    kidthatsirish and PzTank[QUOTED] like this.
  4. Jun 21, 2018 at 7:36 AM
    #44
    coopcooper
    coopcooper certified youtube mechanic
    alberta canada
    black on black on black 05 trd off road
    stickers and sticker accessory's
    three ugga duggas
  5. Mar 24, 2019 at 5:12 AM
    #45
    Sidponcho
    Sidponcho Well-Known Member
    Dan
    Switching over to summer tires today.....going with blue-torque
  6. Mar 24, 2019 at 6:18 AM
    #46
    kidthatsirish
    kidthatsirish Well-Known Member
    2006 Tacoma Access Cab, 2.7L, 4x4, Manual Transmission
    President McKinley w/KLM 203P and threw the roof antenna, ICON RXT leaf spring packs (position 2), Bilsteen 5100s, ARE Camper Shell, Pop & Lock tail gate, Dash Cam
    83...85....were are literally talking a difference of less than 5%.
    I think they will be fine.
  7. Dec 30, 2020 at 4:20 PM
    #47
    AJ112
    AJ112 Member
    AJ
    2013 Prerunner
    Just reviewing this post... it is actually “Pounds-feet”. Not Ft/lbs. I need to rotate tires, but am afraid of breaking studs. What is the conversion from Pounds-feet to Ft/lbs. My brother says to multiply Pounds-Feet by one but I keep getting the same number.
    BC Hunter and 5RickB like this.
  8. Dec 30, 2020 at 4:49 PM
    #48
    gotblika
    gotblika Well-Known Member
    Maui
    2015 DCLB Sport 4X4
    5100'S 887 SPC B110 EL096R
    :rofl:
    BC Hunter likes this.
  9. Dec 31, 2020 at 8:41 AM
    #49
    4x4cajun
    4x4cajun Well-Known Member
    Fredericksburg, VA
    2014 Limited 4x4
    CHEVERLY my service dog! Lol
    We don’t need no stink’n lugs:)
  10. Dec 31, 2020 at 11:00 PM
    #50
    MurderedTacoV2
    MurderedTacoV2 Booty Admirer
    Adam
    Hudson, New Hampshire
    06 Taco TRD OR
    3 inch lift, B110’s, Dakars, Dirty5’s, Dual Locked
    80 ft lb torque stick with 3-4 ugga duggas per lug. If you wanna be proper 90 ft lbs has never failed me.
  11. Nov 8, 2021 at 5:27 PM
    #51
    Ryuguyu51890
    Ryuguyu51890 Member
    2014 spruce mica limited
    So I accidentally put mine at 120lbs multiple times. Do I need to worry about the strength of the studs now? And should I continue to go to 120 since Iv already done it
  12. Nov 8, 2021 at 5:45 PM
    #52
    Rick's 2012
    Rick's 2012 Well-Known Member
    Rick
    Costa Rica
    2012 Double Cab 4x4 Grey with leather
    Stock
  13. Nov 8, 2021 at 5:54 PM
    #53
    Ryuguyu51890
    Ryuguyu51890 Member
    No I shouldn’t worry or no I shouldn’t keep putting them to 120 lol
    mikkydee likes this.
  14. Nov 8, 2021 at 6:06 PM
    #54
    JJ Customs
    JJ Customs Supreme Leader!
    Jay
    NV
    Sierra Denali Ultimate, 6.2
    A few additions to make me feel cool.
    I consider myself anal but y’all need to be in a group home or some shit! LOL…
  15. Nov 8, 2021 at 6:25 PM
    #55
    Rick's 2012
    Rick
    Costa Rica
    Stock
    No, don't keep tightening them to 120 .
  16. Nov 8, 2021 at 7:03 PM
    #56
    Knute
    Knute Well-Known Member
    '06 4.0L Tacoma TRD Sport
    Stock, 4WD, Access Cab, White,
    Hmmm.....
    FWIW, the studs may be compromised with a continuous over-torque of 50%.
    Suggest to consider replacing all the studs. I know..... a royal PITA. On the flip side, you could just run until one of the studs break. Then replacement will be imminent.
    Back off the torque to 85 lb-ft or 85 ft-lb (no difference) and begin using a torque wrench on them lug nuts. Always tighten in a "star" pattern.
  17. Nov 9, 2021 at 9:04 AM
    #57
    clip
    clip Well-Known Member
    VA
    15 OR
    pinstripes. lots of pinstripes.
    83 x 6 - 498 ft-lb total. Put it all on one or spread it evenly, your call.
  18. Nov 12, 2021 at 3:44 AM
    #58
    DJ Funktacular
    DJ Funktacular Well-Known Member
    Maine
    '05 Toyota Tacoma TRD off road
    Toyota tech told me 100 when I asked him. I read it was 83 or 85. He gave me a reason, but I forgot why.
  19. Nov 12, 2021 at 6:04 AM
    #59
    Knute
    I would have the Service Manager confirm that level of torque in print from the Maintenance Manual.
    Its 83 ftlb. 85 ftlb will not cause problems. 100 ftlb is too much.
    I have doubts if the Toyota Tech knows more than the people who designed the truck.
    Rambo MARINE Recon likes this.
