Torque Wrench
Discussion in 'Technical Chat' started by grubburg, Feb 28, 2015.
  1. Feb 28, 2015 at 8:07 PM
    grubburg
    grubburg [OP] Well-Known Member
    2019 TRD OR MT
    K & N Intake, Gibson Catback (chopped), Weathertech floormats, 285/70/17 Ridge Grapplers, Black Rhino Glamis wheels, Kicker Key, Kicker Hideaway, Infiniti Speakers, OV Tune, 888's, 5100s X 4, HS 3-leaf, LR SPC UCAs, Diff Drop, Carrier Bearing Drop, OEM Bed Mat, Morimoto HID low beams, Morimoto LED 2 Stroke High Beams, KC 336 LED bar, KC C3 LED pods for rear, KC LED 6'' SlimLites ditch lights, N-Fab Steps, Auxbeam Interior Blue Lights, 7r41lbr34k3r Shift Knob, Wet Okole Seat Covers, Diode Dynamics SAE Pro Fogs, Cali Raised ditch light brackets, hidden light bar brackets, tailgate light brackets.
    I'm looking to buy a torque wrench. what strength is necessary for general tacoma work? 150 pounds?
  2. Feb 28, 2015 at 8:09 PM
    Unchained 5150
    Unchained 5150 Rick
    Rick
    Auburn Ma
    2021 TRD Poser Pro Manual.
  3. Feb 28, 2015 at 8:10 PM
    armyoffoo
    armyoffoo Scrotie McBoogerballs
    Houston, TX
    2018 Tundra CM TRD Sport
    Front axle nuts are 173ft lbs, Crank shaft pulley bolt is 204ft lbs (with supercharger). Those are just a couple that I can think of that require higher than 150.
  4. Feb 28, 2015 at 8:19 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    I have a couple. One starts at 5# and goes to 74, and the other starts at 20# and goes to 120. For the larger bolts, I just borrow, or rent it.
  5. Feb 28, 2015 at 10:40 PM
    michael roberts
    michael roberts Well-Known Member
    san diego
    07,4x4, white, AC.
    powder coated hood support.
    Years ago i read you should store the torque wrench set a 0 lbs. The reason why reason wasn't mentioned, but i've always did this.
  6. Mar 1, 2015 at 7:34 AM
    tan4x4
    tan4x4 Well-Known Member
    Rick
    Folsom, CA
    99 Tacoma EC 4x4 2.7L Auto
    Bilsteins, OME 881's, 3-leaf AAL, Detroit TruTrac, Tundra brake swap, Michelin LTX AT2, Tranny skidplate, TC skidplate, CBI rear bumper, TG sliders, UltraGauge, PowerTank, Reverse Camera
    There is also an 'inch-pound' torque wrench, thats handy for oil-pan and valve-cover bolts. I have both.
  7. Mar 1, 2015 at 7:42 AM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    I have a couple... 1/2" and 3/8"
    Both have settings for foot lbs & inch/lbs from ZERO up to ?? (without going out and looking - LOL). They're both Craftsman and we've had them probably for 15 years.
  8. Mar 1, 2015 at 7:43 AM
    Eric F
    Eric F Well-Known Member
    AZ
    2014 DC SB TRD-OR 4x4
    Anytime fog lights, U.S. Off Road-Winch Mount Bumper, diff breather, Doug Thorley mid pipe
    To keep unnecessary pressure off of the torque mechanism. Keeps the wrench accurate
  9. Mar 1, 2015 at 7:52 AM
    Frogging
    Frogging Well-Known Member
    DEREK
    ORLANDO, FL
    DCLB 4.0 2wd
    ASV vent visors LED tailgate brake light Weathertech floor mats Wish list:Maxtrac Spindles New leaf pack Extended rear shocks Braided Brake lines Konig countersteer Anodized bronze 285/70/18 tires NST Crank lite pulley setup XTP intake manifold spacer Neoprene seat covers Fiberglass fenders Power sliding rear window 1" Spacers for rear wheels
    the wheels are only 90 lbs or so. unless you are taking major items off you shouldnt need much more. i have a 1/2 inch from harbor freight that goes 20-150 lbs. small stuff i use a 1/4 inch. torque wrench but that is measured by inch pounds.
    certainly worth having and using.
    you set a torque wrench to 0 to minimized the fatigued to the spring mechanism inside. the spring mechanism determines the right torque each time used once it is set to which ever setting
  10. Mar 1, 2015 at 7:57 AM
    Drainbung
    Drainbung Somedays you are the show....
    Bob
    Fallabama, NV
    10 DCLB
    TRD Fleshlight
  11. Mar 1, 2015 at 8:09 AM
    Styx586
    Styx586 Well-Known Member
    Terrance
    Lake Elsinore, Ca
    2013 Tacoma DCLB TRD Sport, 2001 Tacoma TRD Off-Road
    Idk if u have a 1st gen or not, but if u ever plan on doing a timing belt, the crank pulley bolt requires 217ft/lbs. just something to think about.
  12. Mar 1, 2015 at 1:18 PM
    Hugh Morron
    Hugh Morron Manic Mechanic
    Bill
    Schuylkill County, PA
    12 DCLB SR5 4X4 Barcelona Red Metallic
    ARE Cap, AVS Bugdeflector II, AVS Ventshades, DTRL delete, ABS/VSC/TRAC disable, Toyota LSD with clutchpacks, N-Fab Lightbar, Hella 700ff lights
    Lowes sells a good Kobalt torque wrench. 25 to 250 ft/lbs for around $80.00. They are a clicker type that you set the desired torque and when it is reached it clicks.
  13. Mar 1, 2015 at 1:21 PM
    a.smo
    a.smo Well-Known Member
    Aaron
    PHX, Az
    '99 Trd Xtra Cab 4x4 5sp
    Subd
  14. Mar 1, 2015 at 1:31 PM
    Black Taco
    Black Taco Well-Known Member
    Rob
    WPB, FL
    TOYOTA
    No mods whatsoever!
  15. Mar 12, 2015 at 3:48 AM
    orangeglo
    orangeglo ¯\_(ツ)_/¯
    Los Angeles, CA
    2011 DCSB OR
    This only applies to micrometer torque wrenches. Split beam torque wrenches can be stored at any setting.
  16. Mar 17, 2015 at 12:42 AM
    JJ04TACO
    JJ04TACO Well-Known Member
    Jim
    Dallas
    04 White DC/TRD
    Fox 2.5 RR front, 2.0 RR rear from AccuTune Offroad, OME Dakar Leafs, Camburg Uniball UCA's, CBI Offroad Bolt on Sliders w/kickout, Scangauge II Uniden Bearcat 880 w/ 3' Firestick on CBI antenna mount B&M Trans Cooler
    Go to ebay and search "CDI Torque Wrench". I have the 10-100 lb/ft model there are many to choose. They are made in USA and are affiliated with Snap On. Mine is VERY nice and they won't break the bank. There will be a chart you can reference to pick the model that best suits your needs.
  17. Mar 17, 2015 at 2:54 PM
    CASTRATE
    CASTRATE Well-Known Member
    Gabe
    SW of Tulsa, OK
    2012 4x4 SR5 6spd
    Totally different torque range, but I purchased the smallest torque wrench for in/oz available at HF, & who'd uh thunk it, it was junk. Set it at 25 in/oz for scope ring caps. Ended up snapping the head off a grade 8 8-32 cap screw. Lesson learned
  18. Mar 17, 2015 at 10:42 PM
    JJ04TACO
    Jim
    Dallas
    04 White DC/TRD
    I chose the 10-100 model but there's a 20-150 model (1503MFRMH). But it's a 1/2 inch drive. The 10-100 is 3/8. There may be a time when there will be clearance issues with a 1/2" drive but if you need to go to 150 that's the one. You can get a smaller 5-75 for a little more than $100. They have in/lb ones too. I'm telling ya these are very nice. I've been through three other wrenches (craftsman), and they just don't make them like they used to. Buy once cry once.
  19. Mar 18, 2015 at 4:44 AM
    Teleholic
    Teleholic Well-Known Member
    2014 Baja tx
    Got a 3/8th drive 10-80 foot pound torque wrench from Tekton, and was impressed at what I could get for about 40 bucks. Just received a 1/2 drive 10-150 ft. lb from Tekton as well. It has to go back cause the internal mechanism's are pretty bad when changing setting's, it's very rough and make's all sorts of horrible noises that my 3/8th doesn't do. Can't trust it.
    I've heard if you go with a click type, its wise to have many separate torque wrench's with different range's for the sake of accuracy; even if they overlap each other in range. For example, a 10-150 ft.lb wrench has more range than a 10-80 ft.lb. However if you are tightening to lets say 80 ft.lb, your 10-80 ft.lb would be more accurate at that setting than your 10-150 ft. lb's, because it's on the farther end of it's range. Click-type torque wrench's are more accurate at higher settings.
  20. Mar 18, 2015 at 4:58 AM
    BadBrains
    BadBrains Spreading the Aloha
    AL
    '07 Taco LT, '00 GS-R, '75 C10, '83 CJ-7, '19 T4R SR5
    King, TC +2"LT, 35's, Aluminum this and that.
    Yep, always zero out your torque wrench before storing.
    Of course try not to drop it, baby it.
    Hold by the middle of the handle so it does not affect leverage.
    Crows feet and other attachments not inline with the drive change the leverage, to be truly accurate, it needs to be accounted for.
    Greases, anti-seize, etc can give false torque readings.
    Teleholic is correct, you should try not to use the limits of your wrench.
    In aviation, wrenches are re-calibrated annually.
    NEVER back nuts off with your torque wrench, only tighten.
    Always torque the nut, not the bolt head.
    Granny bars/Cheater bars change leverage, the correct way is to use a multiplier.
    Can't think of any more.
