TORSPD: NEVR
Discussion in '2nd Gen. Builds (2005-2015)' started by Torspd, Feb 9, 2012.
  1. May 6, 2014 at 12:45 PM
    #2001
    RedLantern
    RedLantern Well-Known Member
    Honolulu, Hi
    2019 TRD Pro Tacoma - Voodoo Blue / 06 double cab PreRunner Turbocharged (sold)
    everyone do the homer
  2. May 6, 2014 at 4:07 PM
    #2002
    Lucario Runner
    Lucario Runner Resident Truck/SUV racer
    Robert
    San Antonio, TX or nearest race track
    06 Toyota 4Runner
    AFE stage II intake, APR X1, URD 70mm Throttle Valve (ported and knife edged), NST intake manifold spacer, URD spec U headers, Denso IKH20, URD fuel pump, APR fuel rail, URD Y pipe, URD spec u catback, lightweight water pump pulley, Greddy sandwich cooler plate, Earls oil cooler, IPT valve body, FJ TRD shocks, Cusco front and rear sway bars, Energy Suspension rear track rod bushings and rear link bushings, Carbotech pads, Stoptech ss brake lines, Stoptech slotted rotors, Motul 600 rbf, Limited Grill, Painted hatch cover by me, Painted valve covers by me, Cobra CB, TRD rad and oil cap, Escort 8500, Autometer oil psi and temp gauges, AEM wideband afr gauge, Flexpod, Pioneer 400w speakers.
  3. May 6, 2014 at 6:56 PM
    #2003
    HomerTaco
    HomerTaco
    HomerTaco
    HomerTaco
    That's about right. ;)
  4. May 6, 2014 at 7:36 PM
    #2004
    SconnieHailer
    SconnieHailer PutterClutch
    Marc
    West Central Wisconsin
    2012 TRD Off Road Double Cab V6 6Speed
    Also, "Josh" who shot that is decent at panning shots... Not the easiest thing to do!
  5. May 9, 2014 at 10:43 AM
    #2005
    Papa Taco
    Papa Taco HARD CAAAAAAARRRRRRRL
    Jared
    Socal
    2011 Access Cab 4x4 6 Speed
    Follow the yellow brick road
    damn.... super legit build
  6. May 9, 2014 at 11:34 AM
    #2006
    Torspd
    Torspd [OP] Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    No kidding. Curious what kind of camera he has also.
    Thank you sir. :thumbsup:
  7. May 9, 2014 at 12:21 PM
    #2007
    Torspd
    Tor
    The Great America!
    Latest word on the engine build is that there should be an update on Monday, and the engine should be ready to ship next week.......
    Unrelated note. Lucario Runner and i have been working with Dezod to get some cam choices available for us. From a simple bolt in set, to the more aggressive profiles. :thumbsup:
  8. May 9, 2014 at 12:35 PM
    #2008
    Bellis
    Bellis friggin rad
    Ben
    mass southshore
    pyrite 6-speed 2012 offroad
    driver mod
    badassness
  9. May 9, 2014 at 12:42 PM
    #2009
    memario1214
    memario1214 Hotshot Offroad Moderator Vendor
    Colton
    Missoula, MT
    SOLD - 05 Dub Cab TRD Sport 4x4, CURRENT - '21 Tundra MGM Limited
    Please don't. I don't want to buy a new Tacoma just so I can cam it haha
  10. May 9, 2014 at 5:56 PM
    #2010
    Papa Taco
    Jared
    Socal
    :drool:
  11. May 9, 2014 at 5:59 PM
    #2011
    SconnieHailer
    Marc
    mmmm custom grinnnndzzzz!
  12. May 9, 2014 at 8:55 PM
    #2012
    RedLantern
    Honolulu, Hi
    Mmmmm....cams. I curious how the aggressive ones will sound with its new exhaust note.
  13. May 10, 2014 at 7:26 AM
    #2013
    Bowhuntercoop
    Bowhuntercoop Well-Known Member
    2025 gx550 overtrail. 2025 limited off-road tundra.
    Took me around 3 days but I read the whole thread front to back haha. I work for cummins and build engines daily. From little 3.3 b series to 50 litre v 16 cummins on frac Rigs. Pretty awesome seeing your attention to detail and passion for building it. Keep up the solid work my friend. I was thinking bout gettin a side project going on an older truck. Now I wanna buy another yota and build a 4.0 haha.
  14. May 10, 2014 at 11:24 AM
    #2014
    Gaunt596
    Gaunt596 Well-Known Member
    Matthew
    Central Maryland
    Nice, just in time for the summer racing season :burnrubber:
  15. May 16, 2014 at 7:32 AM
    #2015
    Torspd
    Tor
    The Great America!
    Haven't yet started any teardown. Been to busy with work. On a good note though, going to be putting a spare set of heads and Clifford's engine to good work this weekend. Getting specs for cams.
    I also ordered a Whiteline Front sway bar. Need more handling! Next, as far as suspension, will be stiffer rear springs in the rear, from the XR. At least until a possible 4-link setup. As well as a little stiffer up front. Then I need to find upgraded bushings. All in the name of reducing body roll. Which is quite prevalent in the picture which Lucario Runner posted.
    This is the link to the sway bar. Going to be a while before it ships since it is on backorder from Australia. Hopefully it will still be here before the next MSR race in August.
    http://www.frsport.com/Whiteline-BT...justable-Toyota-FJ-Cruiser-07-10_p_34886.html
    I am as well! However, being that there won't be any overlap between the two, it definitely won't have that "nasty" lope sound to it. It should still sound different.
    I really appreciate the kind words Bowhuntercoop. :thumbsup: Maintaining (or trying to) a strict level of attention to detail, is very costly. That in and of itself creates a lot of mental stress. Coupled with a project that juuuuuuuuust can't seem to get finished, which has lasted for about 6 years now. Fortunately, I have still been able to go out and enjoy the hard work and experience something which is extremely rare. Racing a truck on a road course. A truck which used to be lifted on 35's. Doing that with friends. Let's not forget the perks of racing people in their cars who have to work harder to race against a truck. We motivate them. ;)
    Custom for now. Not once we get the profiles in place. I am not doing this for a one off set. I am doing this for the community of Tacoma owners. To be 100% positive that we can bring forth a set of cams that are straight bolt-in, without having to buy springs and retainers, nor machine work. A mild set of course. For the aggressive set, I already know what needs to be done. Those require a lot of work. Those will make some serious power! The power from the styles which we have researched so far, is very impressive still. Once we do some calculations, I will know how excited to be. :)
    Buy you must. It is your Destiny!
    That is the plan! Hopefully it can stay that way. Those some of those drivers need some more advanced schooling. :devil:
  16. May 16, 2014 at 7:44 AM
    #2016
    SconnieHailer
    Marc
    :cool:
  17. May 16, 2014 at 10:50 AM
    #2017
    Torspd
    Tor
    The Great America!
    This is the company. http://www.definedengineering.com/products.html
  18. May 16, 2014 at 11:00 AM
    #2018
    colinb17
    colinb17 If at first you don't succeed, don't try skydiving
    Colin
    Charleston, SC
    '07 TRD Sport 4x4
    Build thread in sig... 4-link long travel
    couple of the guys i've wheeled with have those and love them. I would get one, but i'm pretty sure my shackle hangers are already to bent for it to fit.
  19. May 16, 2014 at 11:14 AM
    #2019
    Torspd
    Tor
    The Great America!
    Good to know! :thumbsup:
    Nothing that a hammer cannot remedy. ;)
  20. May 20, 2014 at 12:06 PM
    #2020
    Torspd
    Tor
    The Great America!
    Currently in the search for poly bushings, to replace the gushy rubber ones. I have done some looking and found some, but there doesn't seem to be a master kit anywhere. Some places have body bushings, some control arm, and others have rear suspension. The places which have the rear suspension bushings (All Pro) don't show the metal sleeves that usually come with the replacement bushings. Maybe someone on here has a better place to look, or more knowledge on the subject?
