TORSPD: NEVR
Discussion in '2nd Gen. Builds (2005-2015)' started by Torspd, Feb 9, 2012.
  1. Oct 22, 2014 at 2:46 PM
    #2581
    Lucario Runner
    Lucario Runner Resident Truck/SUV racer
    Robert
    San Antonio, TX or nearest race track
    06 Toyota 4Runner
    AFE stage II intake, APR X1, URD 70mm Throttle Valve (ported and knife edged), NST intake manifold spacer, URD spec U headers, Denso IKH20, URD fuel pump, APR fuel rail, URD Y pipe, URD spec u catback, lightweight water pump pulley, Greddy sandwich cooler plate, Earls oil cooler, IPT valve body, FJ TRD shocks, Cusco front and rear sway bars, Energy Suspension rear track rod bushings and rear link bushings, Carbotech pads, Stoptech ss brake lines, Stoptech slotted rotors, Motul 600 rbf, Limited Grill, Painted hatch cover by me, Painted valve covers by me, Cobra CB, TRD rad and oil cap, Escort 8500, Autometer oil psi and temp gauges, AEM wideband afr gauge, Flexpod, Pioneer 400w speakers.
    Time for a ron davis radiator then.
  2. Oct 22, 2014 at 3:03 PM
    #2582
    BradyT88
    BradyT88 Well-Known Member
    Already got one picked out! Just need the money. haha
  3. Oct 22, 2014 at 4:32 PM
    #2583
    Justus
    Justus fucks not given
    Nabisco the kid
    In ur toolbox
    stockish
    story of our lives here on TW
  4. Oct 22, 2014 at 4:33 PM
    #2584
    XPOTRPR
    XPOTRPR CNC Programmer/Machinist
    Josh
    Chandler, AZ
    > BUILD LINKS >
    here, and mail order bride websites
  5. Oct 23, 2014 at 1:34 PM
    #2585
    Justus
    Nabisco the kid
    In ur toolbox
    stockish
    we are drooling here Tor
  6. Oct 23, 2014 at 2:12 PM
    #2586
    Torspd
    Torspd [OP] Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    Say hwat?! Lol
    Waiting on the proper parts. Memory card en route
  7. Oct 23, 2014 at 4:55 PM
    #2587
    XPOTRPR
    Josh
    Chandler, AZ
    > BUILD LINKS >
    did you just hweat thins? lol
  8. Oct 31, 2014 at 10:32 AM
    #2588
    Torspd
    Tor
    The Great America!
    Gearing FTW!
  9. Oct 31, 2014 at 10:33 AM
    #2589
    XPOTRPR
    Josh
    Chandler, AZ
    > BUILD LINKS >
    :jellydance:
    damn you
  10. Oct 31, 2014 at 10:35 AM
    #2590
    Bellis
    Bellis friggin rad
    Ben
    mass southshore
    pyrite 6-speed 2012 offroad
    driver mod
    x2
  11. Oct 31, 2014 at 10:39 AM
    #2591
    Torspd
    Tor
    The Great America!
    Ranging between 22-24 mpg now. :woot:
  12. Oct 31, 2014 at 10:39 AM
    #2592
    XPOTRPR
    Josh
    Chandler, AZ
    > BUILD LINKS >
    ugh... and the salt in the wound..
  13. Oct 31, 2014 at 10:50 AM
    #2593
    BradyT88
    Is your speedo accurate? (not sure what size tires you are running) Although if they are smaller than stock you are going faster than what your speedo says:eek:
    I run 2700 rpm at that same speed on my 33's and get about 18 mpg there.
  14. Oct 31, 2014 at 11:04 AM
    #2594
    Torspd
    Tor
    The Great America!
    .73 6th gear, 3.73 final, 275/40 R20. Dakota Digital calibrator to correct Speedo. It's GPS tuned. ;)
  15. Oct 31, 2014 at 11:29 AM
    #2595
    Lucario Runner
    Robert
    06 Toyota 4Runner
    Around the same speed I get about 20-21 mpg. You should get a 2nd set of wheels with Prius (low rolling resistance) tires, duct tape all the gaps, air dam, etc and go for the highest mpg record ever on a race truck. ;)
  16. Oct 31, 2014 at 11:31 AM
    #2596
    BenMara
    BenMara That Asian RedNeck
    Ben
    Belton, SC
    2011 DC 4x4 SCed
    TRD Blower, Ham Radio, DBA T2 Rotors
    x2
  17. Oct 31, 2014 at 11:33 AM
    #2597
    XPOTRPR
    Josh
    Chandler, AZ
    > BUILD LINKS >
    at those speeds im at about 2200-2400 RPM
  18. Oct 31, 2014 at 12:04 PM
    #2598
    Torspd
    Tor
    The Great America!
    Hmmmm........
  19. Oct 31, 2014 at 1:55 PM
    #2599
    BradyT88
    Something is weird there... 0.73 is about the same as the auto 5th of 0.72. With the same 3.73 R&P you should run higher than a stock auto at 75 mph which is about 2200RPM... In fact punching it in to grimmcreeper it says you should be running 2400 RPM at 75... Hell even a 3.15 diff gear from an X-runner would only get you down to 2000 RPM at 75 with those tires:confused:
    I have been too cheap to buy a speedo calibrator, but an ultragauge isn't too spendy and I calibrated it via GPS as well:thumbsup:
  20. Oct 31, 2014 at 1:58 PM
    #2600
    BradyT88
    Quick question though... Your oil pressure gauge there doesn't happen to be showing your MPH there does it? Because 59 mph with those gears and tires would put you right about where your tach says. haha
