TORSPD: NEVR
Discussion in '2nd Gen. Builds (2005-2015)' started by Torspd, Feb 9, 2012.
  1. Oct 31, 2014 at 1:59 PM
    #2601
    Lucario Runner
    Lucario Runner Resident Truck/SUV racer
    Robert
    San Antonio, TX or nearest race track
    06 Toyota 4Runner
    AFE stage II intake, APR X1, URD 70mm Throttle Valve (ported and knife edged), NST intake manifold spacer, URD spec U headers, Denso IKH20, URD fuel pump, APR fuel rail, URD Y pipe, URD spec u catback, lightweight water pump pulley, Greddy sandwich cooler plate, Earls oil cooler, IPT valve body, FJ TRD shocks, Cusco front and rear sway bars, Energy Suspension rear track rod bushings and rear link bushings, Carbotech pads, Stoptech ss brake lines, Stoptech slotted rotors, Motul 600 rbf, Limited Grill, Painted hatch cover by me, Painted valve covers by me, Cobra CB, TRD rad and oil cap, Escort 8500, Autometer oil psi and temp gauges, AEM wideband afr gauge, Flexpod, Pioneer 400w speakers.
    Nope, that's showing pressure.
  2. Oct 31, 2014 at 2:00 PM
    #2602
    Torspd
    Torspd [OP] Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    Hmmm.....you sure? I swear I checked it before. If I am wrong, then it is lower.
    23.38 MPG at last fill. :woot:
    ***Edit*** Averaging 75 mph
  3. Oct 31, 2014 at 2:05 PM
    #2603
    BradyT88
    BradyT88 Well-Known Member
    Well unless grimmcreeper tripped out because I put a low profile tire into a rock crawler site I am sure:laugh:
    I'd guess your 6th gear is between 0.50 and 0.55 to get 1650 to 1800 RPM at 75 mph.
  4. Oct 31, 2014 at 2:17 PM
    #2604
    Torspd
    Tor
    The Great America!
    That's what I was about to say as the next possible gear. This transmission has been full of surprises. Lol
    Means I have an even higher top end. :eek:
  5. Oct 31, 2014 at 2:26 PM
    #2605
    Torspd
    Tor
    The Great America!
  6. Oct 31, 2014 at 2:32 PM
    #2606
    BradyT88
    The 2nd gen Tundras with the 4.6L use the A760 trans (2nd gen Taco use the A750). Both the 750 and 760 have the same first 5 gears, but the 760 has a 6th gear that is 0.59 but those are autos so it's kinda like apples to oranges with your manual.
    Your topend is something in the neighbor hood of 275:cool: haha
  7. Oct 31, 2014 at 2:40 PM
    #2607
    Torspd
    Tor
    The Great America!
    Mythical 275......stories recanted about it, but never seen.....lol
  8. Oct 31, 2014 at 3:39 PM
    #2608
    Torspd
    Tor
    The Great America!
    Wonder what MPG I can best with the stroker engine? ??
  9. Oct 31, 2014 at 4:04 PM
    #2609
    HomerTaco
    HomerTaco
    HomerTaco
    HomerTaco
  10. Oct 31, 2014 at 4:10 PM
    #2610
    AR15xAR10
    08 SR5 4x4 V6 IndigoInkPearl ACLBFTMFW
  11. Oct 31, 2014 at 4:15 PM
    #2611
    BradyT88
    I'm thinking less since the displacement is larger, but :notsure: I'll bet you average 5mpg or less at the track though!:eek:
    I was going to say go back to stock gears and you could do the same, but then I remembered you have the manual trans. I ran about 1900RPM at 75mph with 33's on stock gears. I wouldn't be nearly as peppy though since his 275's are significantly lighter than my 255's. haha
  12. Oct 31, 2014 at 4:19 PM
    #2612
    HomerTaco
    HomerTaco
    HomerTaco
    HomerTaco
    I'm between 2600 & 2700 RPM's @ 70mph in 6th gear with 4.56 and 35's
    Realistically 4.10 would have been much better for my current setup.
    Looks like I'll need to size up to 37's to get it just right. :p
    275MPH Mark? :drool:
    epic. :cool:
  13. Oct 31, 2014 at 4:23 PM
    #2613
    Torspd
    Tor
    The Great America!
    So much win
  14. Nov 5, 2014 at 2:09 PM
    #2614
    Torspd
    Tor
    The Great America!
    Checking in from Fontana, CA.
  15. Nov 5, 2014 at 2:33 PM
    #2615
    Lucario Runner
    Robert
    06 Toyota 4Runner
    I'm sure c.a.r.b. is happy to have ya... :cool:
  16. Nov 5, 2014 at 2:52 PM
    #2616
    Torspd
    Tor
    The Great America!
    You know that they just want to hug the shit out of me. :D
  17. Nov 5, 2014 at 5:58 PM
    #2617
    XPOTRPR
    XPOTRPR CNC Programmer/Machinist
    Josh
    Chandler, AZ
    > BUILD LINKS >
    Hey Tor, when you headed through Az? and same way you went?
  18. Nov 6, 2014 at 4:56 AM
    #2618
    Lurkin
    Lurkin Well-Known Member
    Rod
    Pearland, TX
    09 PreRunner SR5 DC
    Surprised they aren't following you around with a remote sensing truck trying to shove a probe up your exhaust pipe! :eek:
  19. Nov 6, 2014 at 8:16 AM
    #2619
    STiLL WILL
    STiLL WILL MY NAME ISN'T WILL
    Matt [again, not WILL]
    CA
    2021 Tundra TRD Sport 4wd
    Yes, I sold my '13 Taco. :'(
    You'll get harassed for remedial BS before they even begin to start noticing engine mods(unless it's painfully obvious your exhaust is batshit loud)....like front license plates omissions, front window tint, etc. Some areas more forgiving than others. My area is not fun for car/truck guys.
    Usually trucks have it pretty good in general out here in CA though. :) Valley bro'd diesel lifted trucks need not apply though hahaha
  20. Nov 6, 2014 at 8:22 AM
    #2620
    BradyT88
    ^^^They can't site him for any of that stuff anyway since he is registered (and lives) in another state right?
    Like if I am passing through Utah they can't site me for things that are legal in Idaho but not Utah. (Not that it is a big concern).
