TORSPD: NEVR
Discussion in '2nd Gen. Builds (2005-2015)' started by Torspd, Feb 9, 2012.
  1. Dec 8, 2014 at 12:00 PM
    #2741
    MadTaco461
    MadTaco461 BRO runner
    CA
    99 turbo 5 lug long travel
    Kinda stock
    Want a "mechanic"al engineer? I'll move to Texas
  2. Dec 8, 2014 at 12:02 PM
    #2742
    yota243
    yota243 Well-Known Member
    E.J.
    north Alabama
    turbo 05 prerunner trd off road DC
    Bw s256 turbo with 3 in glass pack dumped pre axle raptor liner bed and top rails and fenderflares and rocker panels. Hunter side steps. Plasti-dipped upper fenders and emblems. satin black spray paint here and there inside and out. 5100's set to 1.75" up front . C channel front bumper. Maxxis bighorn 255/85/16
    i've put a rear end in a recliner before. does that count?
  3. Dec 8, 2014 at 12:06 PM
    #2743
    XPOTRPR
    XPOTRPR CNC Programmer/Machinist
    Josh
    Chandler, AZ
    > BUILD LINKS >
    depends.. was it an auto or a manual
  4. Dec 8, 2014 at 12:08 PM
    #2744
    Torspd
    Torspd [OP] Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
  5. Dec 8, 2014 at 12:10 PM
    #2745
    Torspd
    Tor
    The Great America!
    You should contact SWRI, in San Antonio. Right up your alley.
    Kozmic Motorsports is looking for a new mechanic. Throwing it out there for them. They care highly about the work they do, and will be picky about whom they choose.
  6. Dec 8, 2014 at 12:21 PM
    #2746
    Lucario Runner
    Lucario Runner Resident Truck/SUV racer
    Robert
    San Antonio, TX or nearest race track
    06 Toyota 4Runner
    AFE stage II intake, APR X1, URD 70mm Throttle Valve (ported and knife edged), NST intake manifold spacer, URD spec U headers, Denso IKH20, URD fuel pump, APR fuel rail, URD Y pipe, URD spec u catback, lightweight water pump pulley, Greddy sandwich cooler plate, Earls oil cooler, IPT valve body, FJ TRD shocks, Cusco front and rear sway bars, Energy Suspension rear track rod bushings and rear link bushings, Carbotech pads, Stoptech ss brake lines, Stoptech slotted rotors, Motul 600 rbf, Limited Grill, Painted hatch cover by me, Painted valve covers by me, Cobra CB, TRD rad and oil cap, Escort 8500, Autometer oil psi and temp gauges, AEM wideband afr gauge, Flexpod, Pioneer 400w speakers.
    ^that place sounds familiar for some reason...
  7. Dec 8, 2014 at 12:48 PM
    #2747
    yota243
    E.J.
    north Alabama
    most of the ones ive done have been a stick
  8. Dec 8, 2014 at 12:49 PM
    #2748
    XPOTRPR
    Josh
    Chandler, AZ
    > BUILD LINKS >
    Solid.. I think you qualify.
  9. Dec 10, 2014 at 8:19 AM
    #2749
    BradyT88
    BradyT88 Well-Known Member
  10. Dec 10, 2014 at 8:26 AM
    #2750
    Torspd
    Tor
    The Great America!
  11. Dec 10, 2014 at 8:36 AM
    #2751
    XPOTRPR
    Josh
    Chandler, AZ
    > BUILD LINKS >
  12. Dec 16, 2014 at 4:22 AM
    #2752
    Torspd
    Tor
    The Great America!
  13. Dec 16, 2014 at 9:22 AM
    #2753
    TripleThreat
    TripleThreat Vance@freevancewriting.com
    They keep callin me cowboy but its not my name...
    Socal but I am still a southern Florida guy
    Toyota Tacoma 4x4 slightly modified
    nothing special.... wanna race?
  14. Dec 16, 2014 at 9:24 AM
    #2754
    TripleThreat
    Hey back off hes my boosted friend get your own :mad:
  15. Dec 16, 2014 at 9:32 AM
    #2755
    Torspd
    Tor
    The Great America!
    Lol.
    The main site link is to show the description, as the link to Summit Racing doesn't show any description, minus the part #. Bigger spark, more thorough combustion, more power. It won't directly translate to a 15% increase in power though.
    Summit Racing's price is about $14 cheaper each.
  16. Dec 16, 2014 at 9:39 AM
    #2756
    BradyT88
    Sounds like a gimmick...
  17. Dec 16, 2014 at 10:26 AM
    #2757
    Torspd
    Tor
    The Great America!
    Actually, these and or other brands are used regularly in the performance realm by many different types of vehicles. Nothing new there, minus the fact that yesterday was the first time seeing them for our 1GR.
    Basically the same thing as upgrading a distributor setup to the higher output distributor from MSD Ignition.
  18. Dec 16, 2014 at 10:29 AM
    #2758
    StAndrew
    StAndrew Wait for it...
    Hampton Roads, Va
    SR5 4x4TRD
    Intake, exhaust, lift. Typical stuff.
    Not really but its advertising is off. How big the spark is will come down to the plug as well and bigger isnt always better. Engines are designed to run at a certain temp and if the spark is too strong and plug is too hot, you can run too hot in the combustion chamber.
    However, in this case it should be a stronger more reliable spark that will resist being blown out by the boost as long as the plug is gapped correctly.
  19. Dec 17, 2014 at 5:33 AM
    #2759
    Torspd
    Tor
    The Great America!
    Had an over rich issue recently. Anytime the engine would get between 10 inHg and atmosphere, the AFR's would peg the gauge at 10:1. If the gauge could read lower, it would likely be in the 8's or 9's. Huge loss of power. Adding boost would make it lean back out to around 10.6:1, but it was still noticeably lacking power.
    Started out by checking the spark plugs, and those were all fine. Minus the signs of being rich. Checked for vacuum leaks, and not a single one. Checked the compression, and those were all within 15%. Hmmm...
    Next afternoon, I started the truck for the first time that day. Walked over to the turbo, and noticed the sign of an exhaust leak. Soot at the flange. A second later, moisture was dripping out from under the gasket. Shouldn't be doing that, unless the hardware was loose. Sure enough, two nuts were missing, one was loose, and one bolt/nut was missing. Well f*ck me. That titanium hardware was expensive!
    Put new nuts on, and replaced the missing hardware. Test drive was much better. It was a smooth transition from boost to vacuum, but still super rich. Then it dawned on me.....
  20. Dec 17, 2014 at 5:39 AM
    #2760
    yota243
    E.J.
    north Alabama
    what dawned on you? i hate to be continued episodes.
