TORSPD: NEVR
Discussion in '2nd Gen. Builds (2005-2015)' started by Torspd, Feb 9, 2012.
  1. Dec 17, 2014 at 6:07 AM
    #2761
    HomerTaco
    HomerTaco
    HomerTaco
    HomerTaco
    Love it when you do this...
    :popcorn:
  2. Dec 17, 2014 at 7:03 AM
    #2762
    RedLantern
    RedLantern Well-Known Member
    Honolulu, Hi
    2019 TRD Pro Tacoma - Voodoo Blue / 06 double cab PreRunner Turbocharged (sold)
    LOL! I bet he ran out of toilet paper typing this...
  3. Dec 17, 2014 at 7:14 AM
    #2763
    TripleThreat
    TripleThreat Vance@freevancewriting.com
    They keep callin me cowboy but its not my name...
    Socal but I am still a southern Florida guy
    Toyota Tacoma 4x4 slightly modified
    nothing special.... wanna race?
    :rimshot:
  4. Dec 17, 2014 at 7:32 AM
    #2764
    AR15xAR10
    2013 TRD Sport 4x4 V6 ACLBFTMFW
  5. Dec 17, 2014 at 7:34 AM
    #2765
    XPOTRPR
    XPOTRPR CNC Programmer/Machinist
    Josh
    Chandler, AZ
    > BUILD LINKS >
    sounds very similar... :spy:
    now finish the story!!! :goingcrazy:
  6. Dec 17, 2014 at 8:48 AM
    #2766
    Torspd
    Torspd [OP] Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    Let's go back to when I had the STS kit.
    Instead of shipping larger injectors, as part of the fuel system, the sent an FMU. To increase fuel pressure over a 1:1 ratio. Swap disks and it can increase the pressure by 4:1, 6:1, or 8:1. Basically a fuel multiplying unit. Let it also be noted that it came with a 255 LPH pump, so at least they didn't skimp there. The point being that to get more fuel, they just increased the fuel. There was something that the UniChip was intended for, but I am to this day at a loss for their intended plan......... (sarcasm)
    Jumping forward, it is no mystery that having a rising 1:1 fuel pressure w/boost will get you extra output. Raising the base fuel pressure alone will make you have a higher output as well.
    So due to the fact that there have been scheduling conflicts with being able to drop my truck off to have the injector profile changed, in my ProEFI, having the turbo installed, not having a TRD reflash or its injectors, & having and adjustable FPR, I did what would theoretically work. Theoretically, in that "how long" it would work.
    Some might gasp at this, but I considered this as an act of mad scientist desperation, stemmed heavily for chronic boost withdrawal. Up the base fuel pressure went. From ~43 to ~49. Being that it raised with boost as well, and that I could drive it without having to mash the pedal into the carpet. It "worked". For a little over a month......lol. While it worked, AFR's were in the low 11's.
    Basically, they couldn't hang. After being pushed passed their designed limits for X amount of time, they just dumped fuel. In turn, that means that whoever had an STS kit running semi-decently, they would have encountered this same scenario soon enough. Mine never ran right long enough to get to that next problem, from the abyss it already had back then.
    Swapped out the injectors for another set, and bam. Running like a champ again. Minus the oil leak....just wanted to share the fun from the endless tinkering. I have a spot on the schedule at Kozmic, to get the injector profile changed in mid January. Actually the day before the next MSR event. So it won't be a problem again. Although this way a fun one. ;)
  7. Dec 17, 2014 at 8:49 AM
    #2767
    Torspd
    Tor
    The Great America!
    Somebody pass the TP........
  8. Dec 17, 2014 at 10:04 AM
    #2768
    AR15xAR10
  9. Dec 17, 2014 at 10:23 AM
    #2769
    Torspd
    Tor
    The Great America!
    Good thing I have about three sets of injectors left.....lol. #partsdepartmentgarage :cool:
  10. Dec 17, 2014 at 11:28 AM
    #2770
    AR15xAR10
    I lawdy. Spare everything. :drool:
  11. Dec 17, 2014 at 1:46 PM
    #2771
    RedLantern
    Honolulu, Hi
    Hah. Should have an inventory of all your parts. And For TP.. Glad you got that sorted out tho. Did you have lock washers on your hardware?
  12. Dec 17, 2014 at 8:13 PM
    #2772
    Torspd
    Tor
    The Great America!
  13. Dec 17, 2014 at 8:41 PM
    #2773
    XPOTRPR
    Josh
    Chandler, AZ
    > BUILD LINKS >
    daaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaamnnnnnnnnnnnnnnnnn.......... :cool:
    this is not helping in the decision making of if I'm keeping my long tubes are not..
  14. Dec 17, 2014 at 9:27 PM
    #2774
    AR15xAR10
    :eek: i can afford them too! :eek:
  15. Dec 18, 2014 at 4:05 AM
    #2775
    Torspd
    Tor
    The Great America!
    I was unconsciously thinking about you when I posted that. ;)
  16. Dec 18, 2014 at 6:59 AM
    #2776
    BradyT88
    BradyT88 Well-Known Member
    Don't forget to include the price to have the cats welded to the headers though.
    Do you have to pass smog or are you avoiding long tubes because of the low end power loss?
  17. Dec 18, 2014 at 7:10 AM
    #2777
    AR15xAR10
    Short answer: both.
    I never ever ever want to give up my low end.
    Also, i have a serpentine squeak during the first 15-30seconds of cold start up.....should i just go ahead and replace it?
    Tawwww. You the man!
  18. Dec 18, 2014 at 7:27 AM
    #2778
    BradyT88
    Do you not plan on boosting? That'll fix that low end loss issue. haha Though it doesn't fix the smog issue...
    My car would do that when winter hits. I just had to tighten up the belt, but I don't have an auto tensioner so I can adjust mine. I haven't checked but I'm guessing the Taco has a spring loaded tensioner like most new vehicles...
  19. Dec 18, 2014 at 7:57 AM
    #2779
    Torspd
    Tor
    The Great America!
    Spring loaded tensioner. :thumbsup:
  20. Dec 18, 2014 at 8:34 AM
    #2780
    AR15xAR10
    I'll ignore it for now but its been doing it for a while.
    No i do not plan on boosting. The only way my truck would ever see boost is with a 2JZ-GTE swap
