TORSPD: NEVR
Discussion in '2nd Gen. Builds (2005-2015)' started by Torspd, Feb 9, 2012.
  1. Jan 12, 2015 at 8:06 AM
    #2841
    Torspd
    Torspd [OP] Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    Going to www.track21.com this afternoon at 3:30. If anyone wants to join. Combined course an $10 races.
  2. Jan 12, 2015 at 9:12 AM
    #2842
    SMKYTXN
    SMKYTXN If it can't be overdone it's not worth doing Vendor
    Nathan
    Houston
    11, 4dr, TRD Sport, 6sp
    DCFB
    Some of us have jobs!
  3. Jan 12, 2015 at 9:28 AM
    #2843
    Torspd
    Tor
    The Great America!
    We might be going back around 6, for this of you who have the regular 9 - 5 grind. :p
  4. Jan 12, 2015 at 2:56 PM
    #2844
    TripleThreat
    TripleThreat Vance@freevancewriting.com
    They keep callin me cowboy but its not my name...
    Socal but I am still a southern Florida guy
    Toyota Tacoma 4x4 slightly modified
    nothing special.... wanna race?
  5. Jan 12, 2015 at 2:59 PM
    #2845
    Torspd
    Tor
    The Great America!
    Upgraded fuel pump and filter as well. :spy:
  6. Jan 14, 2015 at 10:28 AM
    #2846
    Torspd
    Tor
    The Great America!
  7. Jan 15, 2015 at 12:14 PM
    #2847
    Torspd
    Tor
    The Great America!
    Going to be ordering some stiffer springs than the 600ppi ones I currently have. To complement the Addco front sway bar that Lucario Runner gave me.
    It makes me curious what length springs that most of you off road guys use, and which ppi? I use the 2.5" diameter, but I believe that the King Racing shock, or other, are 3" diameter.
  8. Jan 15, 2015 at 12:29 PM
    #2848
    BradyT88
    BradyT88 Well-Known Member
    Spring diameter is dependent on shock diameter. 2.0" shocks run 2.5" springs, 2.5" shocks run 3" springs and so on.
    On my 5100's I was running OME 886 springs with are like 15.7" long and 656ppi. They were a bit too soft for my weight though.
    For the bolt on 2.5" coilovers for 2nd gens made by King, and Icon, they usually come with 12" or 13" long springs with 600 or 650 ppi. You can request them up to 14" at 700 ppi which is what most of the fully armored guys need to run. These shocks have about 5.5" of travel.
    For the LT guys running 8" travel shocks, they use 16" or 18" long springs with anywhere from 550ppi to 700 ppi (in increments of 50) depending on how heavy they are.
    For 10" and up, you typically see 2, 3, or 4 different springs stacked on the shock and there are far too many possibilities there to mention. haha
  9. Jan 15, 2015 at 12:43 PM
    #2849
    XPOTRPR
    XPOTRPR CNC Programmer/Machinist
    Josh
    Chandler, AZ
    > BUILD LINKS >
    :thumbsup:
  10. Jan 16, 2015 at 7:25 AM
    #2850
    Torspd
    Tor
    The Great America!
    Thank you Brady. :thumbsup:
    I brought that question up because when I was looking at Kings, some time ago, there was a limit to how high the ppi would go for a 3" diameter spring. I didn't search for long because I went with a different setup. In my recent search for higher ppi for my 2.5" springs, PAC Racing springs has higher ppi springs than Eibach. In both 2.5" and 3". Figured that might be of use other members as well.
  11. Jan 16, 2015 at 7:42 AM
    #2851
    username
    username Fluffer
    Pendleton, Or
    05 Taco with some crap welded to it
    mostly stock
    I'm running 650's now, but I did have 700x18x3" for a while. They were too stiff for me, but my truck is gutted and weighs less than a stock one. If you were closer I'd take you for a ride. It would surprise you how well a properly tuned LT does on the street.
  12. Jan 16, 2015 at 7:57 AM
    #2852
    Torspd
    Tor
    The Great America!
    I bet it does handle quite well, and if I were closer, I'd definitely takes you up on that offer. Haven't ridden in a long travel setup yet.
  13. Jan 16, 2015 at 10:47 AM
    #2853
    VolcomTacoma
    VolcomTacoma Well-Known Member
    Jeff
    NorCal
    2015 TRD Sport 4x4 6 Speed Supercharged
    Front- Camburg 4x4 Long Travel 2.5" King Coilovers 2.5" King Triple Bypasses Wheelers Superbumps Rear- DMZ SUA 16" 3.0 King Triple Bypasses 3" 2.0 Fox bumps Wheels and Tires- 295/75/16 Toyo ATII XTREME SCS SR8 Dark Matte Bronze 16" Lighting- (2) 30" Combo light bars (4) Iggycorp diffused pods Tepui Ayer TRD Supercharger URD Mark III 3" Exhaust URD 4x4 Y Pipe URD CAI URD 2.85 Stealth Pulley Hurst Core Shifter with Hurst T URD Stage 3 clutch URD Lightweight flywheel URD Throw out bearing upgrade AEM Wideband AFR Gauge Speedhut Boost Gauge Craven Speed Flex Pod mount Weathertech Floor Liners BAMF Sliders Ultragauge sPod SE ARB CKMTA12 Hella Supertone horns Relentless Tailgate Reinforcement
    It's amazing lol. I got super spoiled, same weekend trip to the desert I got to ride in a truck with front LT and rear MT, was a way better ride than my truck...and then I got to go for a ride in a trophy truck, and that has set my expectations way to high lol
  14. Jan 16, 2015 at 11:07 AM
    #2854
    MadTaco461
    MadTaco461 BRO runner
    CA
    99 turbo 5 lug long travel
    Kinda stock
    My buddy in his mt truck switched to 500lb springs on his 2.5 kings. Rides smooth. He has the knobs to adjust the damping on the resi.
    It trucks are like crack. Every drive I want to put more into it. I'm definitely more heavy than stock
  15. Jan 17, 2015 at 7:25 AM
    #2855
    Torspd
    Tor
    The Great America!
    And thus the turbo. ;) ^^^
  16. Jan 19, 2015 at 10:08 AM
    #2856
    Jerez
    Jerez SoCal LED Dash Swap
    Rod
    Ontario Ranch
    08 TRD 2wd converted to 4wd
    Estock
    senor torspd...quick question.
    ill be adding a trd supercharger sometime this next year, is upgrading the TB to a 76 mm from a tundra onto the 1gr worth it?
  17. Jan 19, 2015 at 10:13 AM
    #2857
    VolcomTacoma
    Jeff
    NorCal
    ^what he said, same here lol.
  18. Jan 19, 2015 at 10:13 AM
    #2858
    Torspd
    Tor
    The Great America!
    I suggest the 70mm one from the Dual VVT-I 1GR (FJ or 4Runner). As it is much closer to port matched. It is still larger than ours.
  19. Jan 19, 2015 at 10:19 AM
    #2859
    Jerez
    Rod
    Ontario Ranch
    Estock
    me and christian where discussing this yesterday (either the 70mm or the 76mm)
    got it...been thinking that if it helps some i can find a used one anywhere online for a bit cheap
  20. Jan 19, 2015 at 10:24 AM
    #2860
    Large
    Large Red
    It's a trap :spy:
