TORSPD: NEVR
Discussion in '2nd Gen. Builds (2005-2015)' started by Torspd, Feb 9, 2012.
  1. Aug 7, 2015 at 7:42 AM
    #3521
    BradyT88
    BradyT88 Well-Known Member
    That puts you over a 4.5L!:jellydance: You have a 103mm stroke right?
  2. Aug 7, 2015 at 7:42 AM
    #3522
    Yota64
    Yota64 Professional Threadjacker
    Thanks! Nice list... more than I will ever do. Lol
    I was wondering the same thing. Why didn't you get the race one? Is the short one more stable?
    How'd it go??
    I've thought about it but put it to rest for that reason.
  3. Aug 7, 2015 at 8:08 AM
    #3523
    Torspd
    Torspd [OP] Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    Goldylocks has stock stroke, so no. :(
    I like to call it the "budget build engine," compared to all of the bells and whistles of the stroker engine.
  4. Aug 7, 2015 at 8:13 AM
    #3524
    Torspd
    Tor
    The Great America!
    Didn't want it to be to obtrusive whenever I use the tailgate. That's the only reason. We'll see how this size works.
  5. Aug 7, 2015 at 8:13 AM
    #3525
    BradyT88
    Ah. I assumed those pistons were for the stroker.
  6. Aug 7, 2015 at 8:22 AM
    #3526
    Torspd
    Tor
    The Great America!
    Monitarily, I am happy that I don't have to buy new pistons for the stroker engine as well. Had they been damaged, and needed a fresh start, you be damn sure that they would have been ordered for an overbore size!
    Since the stroker pistons cannot be used in the non stroker engine, there was no reason to waste those good pistons. So only one new set of pistons were ordered.
  7. Aug 7, 2015 at 8:23 AM
    #3527
    BradyT88
    What bore are you running on the stroker?
    And what's the ETA on that thing now? haha
  8. Aug 7, 2015 at 8:30 AM
    #3528
    Torspd
    Tor
    The Great America!
    That engine, like Goldylocks, is waiting on the crank to be finished. So they can reassemble, check and verify clearances, then disassemble and ship out to WPC in California.
    I believe the piston is 3.708. Not exactly sure any more.
  9. Aug 7, 2015 at 8:41 AM
    #3529
    Torspd
    Tor
    The Great America!
  10. Aug 7, 2015 at 8:50 AM
    #3530
    SMKYTXN
    SMKYTXN If it can't be overdone it's not worth doing Vendor
    Nathan
    Houston
    11, 4dr, TRD Sport, 6sp
    DCFB
  11. Aug 7, 2015 at 8:52 AM
    #3531
    BradyT88
    You are not a shitting! 1 of those costs the same as all 4 of my KM2's and the wheels combined!:eek:
  12. Aug 7, 2015 at 9:01 AM
    #3532
    Torspd
    Tor
    The Great America!
    Price for quality. Price for forged. If I weren't in need of cistom widths, I'd jump all over these. The custom Forgeline wheels are around $2k each. :eek:
    Lucario Runner likes this.
  13. Aug 7, 2015 at 9:10 AM
    #3533
    SMKYTXN
    Nathan
    Houston
    DCFB
    It's time to rethink things when $1200 is the cheap option for one wheel. :rofl:
  14. Aug 7, 2015 at 9:15 AM
    #3534
    BradyT88
    I would think you would sheer the lug studs before you would damage a wheel. Mine handle my fat rig landing on them better than my frame handles it.
  15. Aug 7, 2015 at 9:23 AM
    #3535
    Torspd
    Tor
    The Great America!
    There are no other options. They've all been exhausted.
  16. Aug 7, 2015 at 10:30 AM
    #3536
    armyoffoo
    armyoffoo Scrotie McBoogerballs
    Houston, TX
    2018 Tundra CM TRD Sport
    Have you done the big 3 upgrade yet? Try that before the larger alternator if you are thinking of going that route. Unless you have additional amps, then you may need the alternator as well.
  17. Aug 7, 2015 at 10:34 AM
    #3537
    Torspd
    Tor
    The Great America!
    What are the big three?
    Denso 130 amp is already in route.
  18. Aug 7, 2015 at 10:35 AM
    #3538
    BradyT88
    All the wiring to and from the alt and battery.
  19. Aug 7, 2015 at 10:35 AM
    #3539
    Torspd
    Tor
    The Great America!
    No. I have not. Link?
  20. Aug 7, 2015 at 10:38 AM
    #3540
    armyoffoo
    Houston, TX
    I thing BamaToy has a kit, but I made my own with knukonceptz wire and my own crimp connectors. Replaced alt to battery, alt to fuse box and battery to starter. As well as beefing up engine block to chassis and grounding the alternator to chassis.
    Torspd[OP] likes this.
