TORSPD: NEVR
Discussion in '2nd Gen. Builds (2005-2015)' started by Torspd, Feb 9, 2012.
  1. Aug 7, 2015 at 12:16 PM
    #3561
    STiLL WILL
    STiLL WILL MY NAME ISN'T WILL
    Matt [again, not WILL]
    CA
    2021 Tundra TRD Sport 4wd
    Yes, I sold my '13 Taco. :'(
    ^^^cosign that myself. SPEC makes great clutches/flwywheels, and my experience with ACT(in my STi) has been nothing short of great as well. I will NEVER buy Comp Clutch ever again. Friend a Stage 3 years ago in his Subie that was just terrible in all aspects.
    URD Stage 2 in my truck is flawless, and wasn't a big hit on the wallet.
    Torspd[QUOTED][OP] likes this.
  2. Aug 7, 2015 at 12:17 PM
    #3562
    Torspd
    Torspd [OP] Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
  3. Aug 7, 2015 at 12:23 PM
    #3563
    VolcomTacoma
    VolcomTacoma Well-Known Member
    Jeff
    NorCal
    2015 TRD Sport 4x4 6 Speed Supercharged
    Front- Camburg 4x4 Long Travel 2.5" King Coilovers 2.5" King Triple Bypasses Wheelers Superbumps Rear- DMZ SUA 16" 3.0 King Triple Bypasses 3" 2.0 Fox bumps Wheels and Tires- 295/75/16 Toyo ATII XTREME SCS SR8 Dark Matte Bronze 16" Lighting- (2) 30" Combo light bars (4) Iggycorp diffused pods Tepui Ayer TRD Supercharger URD Mark III 3" Exhaust URD 4x4 Y Pipe URD CAI URD 2.85 Stealth Pulley Hurst Core Shifter with Hurst T URD Stage 3 clutch URD Lightweight flywheel URD Throw out bearing upgrade AEM Wideband AFR Gauge Speedhut Boost Gauge Craven Speed Flex Pod mount Weathertech Floor Liners BAMF Sliders Ultragauge sPod SE ARB CKMTA12 Hella Supertone horns Relentless Tailgate Reinforcement
    What does that accomplish? Out of curiousity, mechanically speaking. I understand it will help shifts
  4. Aug 7, 2015 at 12:25 PM
    #3564
    Biscuits
    Biscuits Thorny Crown of Entropy
    Swiggity swangin' biggity bangin'
    That reinforces the decision I made to go with SpeedHut was the right one. :)
    I'll quietly duck back out into the lurk again.
    GT7 likes this.
  5. Aug 7, 2015 at 12:27 PM
    #3565
    VolcomTacoma
    Jeff
    NorCal
    Yea I liked being able to fully customize the cage how I wanted it. In retrospect though i might have gone with white faces, i ordered becaude my 2011 had black gauge cluster faces, i forgot they added the white band on the clusters
  6. Aug 7, 2015 at 12:30 PM
    #3566
    Torspd
    Tor
    The Great America!
    I had a Spec Stage 3+ , with the OEM trans and T56. Held over it's torque rating of 550 ft-lbs, without a hint of slip. I was making 575 wtq. Only issue was it took close to 3k miles to "break-in" for that smooth and quiet engagement. Damn strong clutch.
    Swapped in a used Spec Clutch 6 puck, which honestly should have been thrown away, back into the car which had pulled it to replace it with a new one. The new one shipped was somehow the wrong disk, either for a different car or just a hair to large on its diameter. So the old used one literally HAD to go back in.
    This was hours before the Texas Lonestar Drift Event. Into Will Parsons' S2000 swapped (2.0L. Brainfart on engine code) AE86. We rushed to get it in, while @Lucario Runner was transporting race cars to the track. Bled the clutch by the time he returned. Will, by this time had already been up for over 24 hours and had no time to sleep, nor by the time we got to the track did he have time to shakedown the car.
    Not only did he qualify, but he also took first place, on that severely worn clutch.
    It has my vote. :bowdown:
  7. Aug 7, 2015 at 12:30 PM
    #3567
    Torspd
    Tor
    The Great America!
    :spy:
  8. Aug 7, 2015 at 12:34 PM
    #3568
    STiLL WILL
    CA
    F20c or F22c ....2 of my fav 4cyl engines of all time. :D
  9. Aug 7, 2015 at 12:37 PM
    #3569
    Torspd
    Tor
    The Great America!
    F20c. With the blasted valve problems. Lol.
  10. Aug 7, 2015 at 12:39 PM
    #3570
    armyoffoo
    armyoffoo Scrotie McBoogerballs
    Houston, TX
    2018 Tundra CM TRD Sport
  11. Aug 7, 2015 at 12:41 PM
    #3571
    STiLL WILL
    CA
    FA20*** ;)
    Torspd[OP] likes this.
  12. Aug 7, 2015 at 12:44 PM
    #3572
    armyoffoo
    Houston, TX
    Yup, fat-fingered it, or too much twin peaks :D
  13. Aug 7, 2015 at 12:45 PM
    #3573
    Torspd
    Tor
    The Great America!
  14. Aug 7, 2015 at 12:51 PM
    #3574
    STiLL WILL
    CA
    Hey at least something's getting fingered around here. :devil:
  15. Aug 7, 2015 at 12:58 PM
    #3575
    Torspd
    Tor
    The Great America!
  16. Aug 7, 2015 at 1:21 PM
    #3576
    SconnieHailer
    SconnieHailer PutterClutch
    Marc
    West Central Wisconsin
    2012 TRD Off Road Double Cab V6 6Speed
  17. Aug 10, 2015 at 5:28 PM
    #3577
    cheech1
    cheech1 Well-Known Member
    Kaneohe, HI
    08 PreRunner Off Road
    Dude, your build is absolutely unreal! Enjoyed the read so far.
    I just know that you'll start modding that bmw too. In addition to what you've already done to the bimmer, be sure to flush the brake fluid. If not done already, replace the entire cooling system too, which is a weak point in almost all bmw's.
    Biscuits and Torspd[QUOTED][OP] like this.
  18. Aug 11, 2015 at 6:29 AM
    #3578
    Torspd
    Tor
    The Great America!
    Already have a substantial wish list on Turner Motorsports website. ;)
    Engine oil changed. Brake fluid and clutch systems flushed.
    Brake pads and rotors are "new".
    The metal water pump is first on the list of upgrades. Aside from the replacement hood struts. Since these are worn out..pain in the ass.....
  19. Aug 21, 2015 at 11:53 AM
    #3579
    Torspd
    Tor
    The Great America!
    Over due for an update....
  20. Aug 21, 2015 at 11:53 AM
    #3580
    yota243
    yota243 Well-Known Member
    E.J.
    north Alabama
    turbo 05 prerunner trd off road DC
    Bw s256 turbo with 3 in glass pack dumped pre axle raptor liner bed and top rails and fenderflares and rocker panels. Hunter side steps. Plasti-dipped upper fenders and emblems. satin black spray paint here and there inside and out. 5100's set to 1.75" up front . C channel front bumper. Maxxis bighorn 255/85/16
    vroom vroom?
