TORSPD: NEVR
Discussion in '2nd Gen. Builds (2005-2015)' started by Torspd, Feb 9, 2012.
  1. Oct 19, 2015 at 11:41 AM
    #3661
    LoneStarTaco
    LoneStarTaco Well-Known Member
    Skylar
    Longview
    01 Xtra Cab TRD 4x4 Std
    Toolbox, 265/70/16 BFG AT's
    Bringing this back from PM. Looks like the Ohlins are a good bit out of my price range. Along with the strut tower adapter, would I need anything other than the QA1's and coils to lower the front? Which QA1 model did you use? I've got parts for an axle flip kit saved already, for significantly cheaper than the TR kit.
  2. Oct 19, 2015 at 12:00 PM
    #3662
    Torspd
    Torspd [OP] Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    They were a coilover for a 2.5" coil. Let me see if I have pictures of any part numbers.
    Also, I believe someone used the QA1 coilover kit from www. xiiperformance.com, minus their strut tower adapter. If I am accurate, it was a PreRunner. Was a while ago that I helped that member though.
  3. Oct 19, 2015 at 12:09 PM
    #3663
    Torspd
    Tor
    The Great America!
    Excuse me. I forgot to add a 2.5" x 14" coil spring.
    Originally I used the Eibach 600ppi spring.
    This weekend I swapped out to PAC Racing's 750ppi spring. Due to racing needs. I think I may have a box in the attic. I can check and see if I still do or not.
    In the mean time, contact XII Performance, and ask them about the length of their coilover. If it fits a 14" spring.
  4. Oct 19, 2015 at 12:52 PM
    #3664
    LoneStarTaco
    Skylar
    Longview
    Thanks, I'll check that out.
  5. Oct 23, 2015 at 10:29 AM
    #3665
    Torspd
    Tor
    The Great America!
    Machinist called me last night. Double checked over all of the notes and parts with him. Siad he hopes to have Goldylocks completed by next weekend. Fingers crossed.
    Now to fix tC's blown head gasket so I can have some garage room to do some wrenching.
    RedLantern and VolcomTacoma like this.
  6. Oct 23, 2015 at 11:09 AM
    #3666
    VolcomTacoma
    VolcomTacoma Well-Known Member
    Jeff
    NorCal
    2015 TRD Sport 4x4 6 Speed Supercharged
    Front- Camburg 4x4 Long Travel 2.5" King Coilovers 2.5" King Triple Bypasses Wheelers Superbumps Rear- DMZ SUA 16" 3.0 King Triple Bypasses 3" 2.0 Fox bumps Wheels and Tires- 295/75/16 Toyo ATII XTREME SCS SR8 Dark Matte Bronze 16" Lighting- (2) 30" Combo light bars (4) Iggycorp diffused pods Tepui Ayer TRD Supercharger URD Mark III 3" Exhaust URD 4x4 Y Pipe URD CAI URD 2.85 Stealth Pulley Hurst Core Shifter with Hurst T URD Stage 3 clutch URD Lightweight flywheel URD Throw out bearing upgrade AEM Wideband AFR Gauge Speedhut Boost Gauge Craven Speed Flex Pod mount Weathertech Floor Liners BAMF Sliders Ultragauge sPod SE ARB CKMTA12 Hella Supertone horns Relentless Tailgate Reinforcement
    One of these days im gonna have to go back througj this thread to see how you did it all. Id love to have a larger V6 :)
  7. Oct 23, 2015 at 11:14 AM
    #3667
    colinb17
    colinb17 If at first you don't succeed, don't try skydiving
    Colin
    Charleston, SC
    '07 TRD Sport 4x4
    Build thread in sig... 4-link long travel
    dagummit jeff! even though the CCs are the same, it's not a street bike. keep it under 12k!
  8. Oct 23, 2015 at 11:24 AM
    #3668
    Torspd
    Tor
    The Great America!
    Convince him of that. :anonymous:
  9. Oct 23, 2015 at 11:28 AM
    #3669
    SMKYTXN
    SMKYTXN If it can't be overdone it's not worth doing Vendor
    Nathan
    Houston
    11, 4dr, TRD Sport, 6sp
    DCFB
    I need to bring you a new passenger side mirror. Maybe next weekend when we're not flooded out?
  10. Oct 23, 2015 at 11:36 AM
    #3670
    RedLantern
    RedLantern Well-Known Member
    Honolulu, Hi
    2019 TRD Pro Tacoma - Voodoo Blue / 06 double cab PreRunner Turbocharged (sold)
    That's good news bro! I lost track of what motor is what again lol. I'll read up to clarify. I know you explained it a few pages ago.
  11. Oct 23, 2015 at 11:36 AM
    #3671
    XPOTRPR
    XPOTRPR CNC Programmer/Machinist
    Josh
    Chandler, AZ
    > BUILD LINKS >
  12. Oct 23, 2015 at 11:40 AM
    #3672
    Torspd
    Tor
    The Great America!
    Doing so will let you literally watch the evolution of my skill and my knowledge.
    Other updates are that the stroker engine is waiting on its bearings to come in. Then it'll be shipped out finally.
    Installed the PAC Racing 750ppi springs this past Sunday, with the help of @Lucario Runner. As well as the King Racing remote reservoir mounts. These Ohlins reservoirs quite a bit smaller than the Kings. I noticed this recently on another Tacoma owner's truck.
    Only problem I'm faced with now is that the Afco Racing front sway bar now contacts the springs, and will not properly fit. Yet...
    The ride however is very much improved versus the 600ppi springs that I originally had. Which surprised both of us. Even without the sway bar. I didn't have to add hardly any preload to the springs to setup the ride height. More usable stroke than before, which has to be the direct translation into a better ride.
    Lucario Runner likes this.
  13. Oct 23, 2015 at 11:43 AM
    #3673
    Sacrifice
    Sacrifice Motorcycle Goon
    KS
    DCSB OR 4X4 LT
    Pelfreybilt Front Bumper,BAMF sliders, Airflow Snorkel,Mini D2S Retrofits, ADS Rear Shocks, Deaver U402 Leafsprings, 35s, AllPro +2LT
    notch the spring :p
    any pictures of your suspension setup up front? curious to see how it looks on the ground since i havent seen any recent pictures, or i missed them
  14. Oct 23, 2015 at 11:45 AM
    #3674
    Torspd
    Tor
    The Great America!
    Goldylocks is the sleeved engine that I purchased from DoubllD. It was the 1st sleeved 1GR, which the sleeves were made from my sacrificed block. DoubllD purchased it from the original owner, Gadget. He originally had it sent to APR for building, but they had a falling out, and it took Gadget about two years to get it returned to him. That is when DoubllD purchased it from him.
  15. Oct 23, 2015 at 11:47 AM
    #3675
    Torspd
    Tor
    The Great America!
    There are a few pictures. During the original Ohlins installation, the track day picture which I am extremely fond of, then some regular angle shots. Which are you looking for specifically?
  16. Oct 23, 2015 at 11:51 AM
    #3676
    RedLantern
    Honolulu, Hi
    Ah ok got it. Thanks for clarifying. My thoughts were correct about it being doubllds motor. I'm surprised the turnaround for it ended up being that quick. I expected it to take longer honestly.
  17. Oct 23, 2015 at 11:53 AM
    #3677
    Torspd
    Tor
    The Great America!
    Also, I been dabbling with my tune a little. Took a while to get all of the files necessary to connect. Cold starts has a fuel enrichment process. Until the engine warms up to 136° it runs extremely rich. In a plotted leaning AFR as the temps rise. However, too rich and wastes fuel.
    Going to be testing out my modified tune this weekend hopefully.
  18. Oct 23, 2015 at 11:57 AM
    #3678
    Torspd
    Tor
    The Great America!
    Honestly, it has been there since last December. They couldn't start until the cranks and rods were finished, as well as the torque plate being made. Both of those themselves took until roughly July. Then they were able to order pistons for Goldylocks. Which almost had a snafu. So a long time in the scheme of things, but waiting for all parties to be able to get to my space in the line was the main factor.
  19. Oct 23, 2015 at 11:57 AM
    #3679
    Sacrifice
    KS
    DCSB OR 4X4 LT
    nothing specifically, just curious.
  20. Oct 23, 2015 at 11:59 AM
    #3680
    Torspd
    Tor
    The Great America!
    Sounds like a plan. I'll see if I can find any more Saint Arnold's Pumkinator.....Colin, you should see if you can order at least one of those. So delicious. :cheers:
