TORSPD: NEVR
Discussion in '2nd Gen. Builds (2005-2015)' started by Torspd, Feb 9, 2012.
  1. Dec 23, 2015 at 11:15 AM
    #3841
    Torspd
    Torspd [OP] Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    Waiting on machinist to tell me how much of the deck is removed, so that I can order the proper thickness head gaskets. I was told by this week, that they should be finished with the short block assembly.
    Which leaves me to finish with the heads.
    I have Calvert Racing Caltracs. Using primarily XR rear suspension components. They work incredibly well.
    When all said and done, Goldylocks should make a number difference of 50 to 75, from HP to TQ. If history repeats itself with the past setups. Cams and valves aren't changed. Just better springs and retainers for this engine.
    The difference on the stroker could be the similar, or much different. Due to increased stroke, larger valves, and aggressive cam profiles.
  2. Dec 23, 2015 at 11:21 AM
    #3842
    BradyT88
    BradyT88 Well-Known Member
    You think the small oil pan would be an issue in the 400-500HP range on an 6.2L LS? I don't know what you are pushing since you have that twin turbo setup. I would say I won't be racing it, but when I hit the dunes for a weekend I spend a lot of time with my foot to the floor; though maybe that would be a bit different with more than twice the HP.
  3. Dec 23, 2015 at 11:27 AM
    #3843
    Torspd
    Tor
    The Great America!
    Capacity is the issue. Preventing cavitation from a lack of capacity. Among other factors.
    Then you have to worry about liquifying the oil. Getting it too hot and breaking it down to where it will not longer provide the hydrodynamic barrier layer. Not enough capacity, + heavy usage, will get that oil over 300° quickly. Without means to cool the oil.
  4. Dec 23, 2015 at 12:05 PM
    #3844
    Torspd
    Tor
    The Great America!
  5. Dec 23, 2015 at 12:18 PM
    #3845
    DOUBLLD
    DOUBLLD Well-Known Member
    Daniel
    Bluemont, VA
    05 Tacoma LS Swap Twin Turbo
    Alot
    what tor said.
  6. Dec 23, 2015 at 12:20 PM
    #3846
    DOUBLLD
    Daniel
    Bluemont, VA
    Alot
  7. Dec 23, 2015 at 12:24 PM
    #3847
    BradyT88
    Is it possible to increase overall oil capacity by running a large radiator as an oil cooler? Would also have the added benefit of cooling the oil.
  8. Dec 23, 2015 at 12:26 PM
    #3848
    DOUBLLD
    Daniel
    Bluemont, VA
    Alot
    it would help but i would reccomend a oil tank that is pressurized. i forget the proper name of it. but that would help. also i have a oil pan already made for a ls to fit with the toyota front diff if your interested in it. comes with oil filter relocation
  9. Dec 23, 2015 at 12:29 PM
    #3849
    BradyT88
    I may be interested if you don't find a buyer between now and when I get an LS. I'm planning on tearing into my 1GR this next week to see what the damage is before I start buying stuff.
  10. Dec 23, 2015 at 1:19 PM
    #3850
    Torspd
    Tor
    The Great America!
    Yes, but still doesn't resolve a potential shallow oil pick-up area. I.E. similar XRunner shallow pan/spun rod bearings. Similar to the tC as well.
  11. Dec 23, 2015 at 7:35 PM
    #3851
    BradyT88
    I see. So is it possible to mount the engine a little higher in the engine bay to make more room for a larger oil pan? Or is that just going to result in a whole lot of cutting into the cab to fit the trans and tcase?...
    Also:D
  12. Dec 23, 2015 at 7:46 PM
    #3852
    VolcomTacoma
    VolcomTacoma Well-Known Member
    Jeff
    NorCal
    2015 TRD Sport 4x4 6 Speed Supercharged
    Front- Camburg 4x4 Long Travel 2.5" King Coilovers 2.5" King Triple Bypasses Wheelers Superbumps Rear- DMZ SUA 16" 3.0 King Triple Bypasses 3" 2.0 Fox bumps Wheels and Tires- 295/75/16 Toyo ATII XTREME SCS SR8 Dark Matte Bronze 16" Lighting- (2) 30" Combo light bars (4) Iggycorp diffused pods Tepui Ayer TRD Supercharger URD Mark III 3" Exhaust URD 4x4 Y Pipe URD CAI URD 2.85 Stealth Pulley Hurst Core Shifter with Hurst T URD Stage 3 clutch URD Lightweight flywheel URD Throw out bearing upgrade AEM Wideband AFR Gauge Speedhut Boost Gauge Craven Speed Flex Pod mount Weathertech Floor Liners BAMF Sliders Ultragauge sPod SE ARB CKMTA12 Hella Supertone horns Relentless Tailgate Reinforcement
    Is there a way to make a T56 work with 4WD? Or are there any good transmission that allows you to retain 4WD and still be #racetruck lol
  13. Dec 23, 2015 at 7:48 PM
    #3853
    StAndrew
    StAndrew Wait for it...
    Hampton Roads, Va
    SR5 4x4TRD
    Intake, exhaust, lift. Typical stuff.
    The more common solution is dry sump. Gonna cost you though as mentioned before.
  14. Dec 23, 2015 at 7:49 PM
    #3854
    BradyT88
    Yeah that was brought up over on XR-U... Lot of money.
  15. Dec 23, 2015 at 7:51 PM
    #3855
    StAndrew
    Hampton Roads, Va
    SR5 4x4TRD
    You know what they say, gotta pay to play :D
  16. Dec 23, 2015 at 8:08 PM
    #3856
    BradyT88
    Yep! haha
  17. Dec 23, 2015 at 11:11 PM
    #3857
    HomerTaco
    HomerTaco
    HomerTaco
    HomerTaco
    I recall reading something on the URD site that said it was possible. Also with gearing more suitable to the application.
  18. Dec 23, 2015 at 11:16 PM
    #3858
    AR15xAR10
    2013 TRD Sport 4x4 V6 ACLBFTMFW
    MQQSE likes this.
  19. Dec 23, 2015 at 11:48 PM
    #3859
    HomerTaco
    HomerTaco
    HomerTaco
    HomerTaco
    Wrapping presents. :anonymous:
    AR15xAR10 likes this.
  20. Dec 23, 2015 at 11:57 PM
    #3860
    AR15xAR10
    Legos and star wars i imagine
    Torspd[OP] and MQQSE like this.
