TORSPD: NEVR
Discussion in '2nd Gen. Builds (2005-2015)' started by Torspd, Feb 9, 2012.
  1. Dec 30, 2015 at 9:03 PM
    #3901
    VolcomTacoma
    VolcomTacoma Well-Known Member
    Jeff
    NorCal
    2015 TRD Sport 4x4 6 Speed Supercharged
    Front- Camburg 4x4 Long Travel 2.5" King Coilovers 2.5" King Triple Bypasses Wheelers Superbumps Rear- DMZ SUA 16" 3.0 King Triple Bypasses 3" 2.0 Fox bumps Wheels and Tires- 295/75/16 Toyo ATII XTREME SCS SR8 Dark Matte Bronze 16" Lighting- (2) 30" Combo light bars (4) Iggycorp diffused pods Tepui Ayer TRD Supercharger URD Mark III 3" Exhaust URD 4x4 Y Pipe URD CAI URD 2.85 Stealth Pulley Hurst Core Shifter with Hurst T URD Stage 3 clutch URD Lightweight flywheel URD Throw out bearing upgrade AEM Wideband AFR Gauge Speedhut Boost Gauge Craven Speed Flex Pod mount Weathertech Floor Liners BAMF Sliders Ultragauge sPod SE ARB CKMTA12 Hella Supertone horns Relentless Tailgate Reinforcement
    Dropped the truck off today before work, going under the knife! URD Stage 3, URD flywheel, T/O bearing upgrade, ARP bolts.
    From what I've read I need to go drive around for about 300-500 miles of stop and go and constant gear changes? And no boosting (cry).
    thekernel114 likes this.
  2. Dec 30, 2015 at 9:16 PM
    #3902
    AR15xAR10
    2013 TRD Sport 4x4 V6 ACLBFTMFW
  3. Dec 30, 2015 at 9:51 PM
    #3903
    Sacrifice
    Sacrifice Motorcycle Goon
    KS
    DCSB OR 4X4 LT
    Pelfreybilt Front Bumper,BAMF sliders, Airflow Snorkel,Mini D2S Retrofits, ADS Rear Shocks, Deaver U402 Leafsprings, 35s, AllPro +2LT
    You can boost..you just dont want to full throttle every chance you get and have the clutch chattering the whole time.
  4. Dec 30, 2015 at 9:57 PM
    #3904
    VolcomTacoma
    Jeff
    NorCal
    Ok. I was just planning on taking it easy, running through the gears slowly but running up the revs in each gear before shifting. I'll just be sure not to go slamming through gears at all until its broken in. Alot of the stuff I've read says it still takes a couple thousand miles until everything stops making noise and feels fully broken in.
  5. Dec 31, 2015 at 5:29 AM
    #3905
    Torspd
    Torspd [OP] Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    Do 500 to be on the safe side. It will pass much more quickly than it seems. It will be worth it. Then hammer down!
    My Spec Stage 3+, with its extremely coarse friction material, took about 2k miles, until it tamed down and stopped chattering. At first test drive, I thought I had done something improperly during the installation. It held more than its rated torque. I cannot praise that clutch enough. It is rated to 550 crank torque. My truck was regularly boosting 550 wheel torque. Practically everywhere. Lol
  6. Dec 31, 2015 at 5:30 AM
    #3906
    Torspd
    Tor
    The Great America!
    :wave:
  7. Dec 31, 2015 at 7:02 AM
    #3907
    AR15xAR10
    How've you been? Still hard at it I see
  8. Dec 31, 2015 at 7:06 AM
    #3908
    Torspd
    Tor
    The Great America!
    It Nevr stops.
    HomerTaco and AR15xAR10 like this.
  9. Dec 31, 2015 at 7:10 AM
    #3909
    Lurkin
    Lurkin Well-Known Member
    Rod
    Pearland, TX
    09 PreRunner SR5 DC
    Have job and some $$$$, will continue to blow shit up. :devil::devil:
  10. Dec 31, 2015 at 7:25 AM
    #3910
    Torspd
    Tor
    The Great America!
  11. Dec 31, 2015 at 4:01 PM
    #3911
    VolcomTacoma
    Jeff
    NorCal
    Yea that's alot of what I've been reading about break in and such. Go super easy, make sure everything beds in correctly and nothing gets glassed over, and then after about 500 you're good to go. Every thing I've read about the Stage 3 says it grabs like crazy! So that will be fun getting used to. Will also prevent me from slipping it to much! And then exactly as you said, alot of people saying it was super chattery and sounds coming from there for first couple thousand miles.
    No Call today, so I'm assuming I get to wait until Monday. Once I got home and really started thinking about it, I realized how much actual work is involved in dropping the trans lol. Would definitely have taken me a good solid 12 hour+ a day weekend to get it done I think (by myself). At least the first time.
  12. Dec 31, 2015 at 5:04 PM
    #3912
    Torspd
    Tor
    The Great America!
    A lot by oneself with no lift. Took me about 16 hours the first time. Without proper tools. At TexFest we had a team of people and did the drop swap in just over 3 hours! We were f*cking flying man!
  13. Dec 31, 2015 at 5:14 PM
    #3913
    AR15xAR10
    Nevr give up ;)
    Torspd[QUOTED][OP] likes this.
  14. Dec 31, 2015 at 10:32 PM
    #3914
    BradyT88
    BradyT88 Well-Known Member
  15. Dec 31, 2015 at 10:35 PM
    #3915
    AR15xAR10
    But you have an auto? :notsure:
    :p
  16. Dec 31, 2015 at 10:39 PM
    #3916
    BradyT88
    My DD is a manual ;) all 72HP! Haha
  17. Dec 31, 2015 at 10:57 PM
    #3917
    AR15xAR10
    lolwut
  18. Dec 31, 2015 at 11:00 PM
    #3918
    BradyT88
    Beater economy car. But that 35+ mpg is nice! It's a car I paid cash for my senior year of high school that I'm still driving about a decade later.
    Torspd[OP] and AR15xAR10[QUOTED] like this.
  19. Jan 1, 2016 at 11:01 AM
    #3919
    VolcomTacoma
    Jeff
    NorCal
    This is pretty much what I'm going to be picking up soon as well. Once the truck goes under the knife for LT I won't be DDing it as much and 35s really kill gas mileage lol. Keeping an eye out on CL for something in the 1 grand range that i can fix if it breaks :D
  20. Jan 1, 2016 at 12:23 PM
    #3920
    username
    username Fluffer
    Pendleton, Or
    05 Taco with some crap welded to it
    mostly stock
    It's not as bad as you think. With 37's I still average 14.7mpg mixed, and I don't drive it easy. $1000 buys 333 gallons of fuel @ $3 a gallon... even if your mileage dropped by 10% it would take years to justify the price of the added vehicle.
    Taco Nation likes this.
