TORSPD: NEVR
Discussion in '2nd Gen. Builds (2005-2015)' started by Torspd, Feb 9, 2012.
  1. Jan 5, 2016 at 5:49 AM
    #3941
    Torspd
    Torspd [OP] Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    Check it. It is only supposed to be a few millimeters. That will give you maximum disk disengagement, and make it easier to shift and slip for take-off.
    Too close however will cause it to ride. So close to the minimum tolerance is best.
    Changing subjects, I am seriously considering these mirrors. To reduce the driver side blind spot even more so.
    http://shop.aprperformance.com/inde...t&product_id=144&search=Universal+gt3+mirrors ***Edited***
  2. Jan 5, 2016 at 5:52 AM
    #3942
    SMKYTXN
    SMKYTXN If it can't be overdone it's not worth doing Vendor
    Nathan
    Houston
    11, 4dr, TRD Sport, 6sp
    DCFB
    Crom and AR15xAR10 like this.
  3. Jan 5, 2016 at 5:59 AM
    #3943
    Torspd
    Tor
    The Great America!
    Lol. No. Not the field of view which your mirror lenses fixed. The blind spot caused by the tight gap between the mirror and the A-pillar.
    Coupled with the large size of the mirror. Makes it difficult to be accurate take a left turn, precisely at the edge of safety for a "clipping point." If I had 35's, I wouldn't quite worry about it. I race though, and would rather be accurate than use perception for every left turn...
    Crom likes this.
  4. Jan 5, 2016 at 6:16 AM
    #3944
    SMKYTXN
    Nathan
    Houston
    DCFB
    I guess if your link wasn't dead I might have been able to see that for myself. :rofl:
  5. Jan 5, 2016 at 6:25 AM
    #3945
    Torspd
    Tor
    The Great America!
  6. Jan 5, 2016 at 6:39 AM
    #3946
    SMKYTXN
    Nathan
    Houston
    DCFB
    Gotcha. So you're concerned with being able to look around the mirror as well.
  7. Jan 5, 2016 at 6:56 AM
    #3947
    Torspd
    Tor
    The Great America!
    Absolutely. That gap between the back of the mirror to the a-pillar is just to close for my liking.
  8. Jan 5, 2016 at 4:42 PM
    #3948
    SconnieHailer
    SconnieHailer PutterClutch
    Marc
    West Central Wisconsin
    2012 TRD Off Road Double Cab V6 6Speed
    My dad had those mirrors on the Evo. Much cool points, very wow :laugh:
    Really though, they're sick mirrors.
    Edit: Side note you might find fun, the Evo is gone and he ordered a Caterham with the lowered floor/big motor/wide track :cool:
    Torspd[OP] and Lucario Runner like this.
  9. Jan 5, 2016 at 10:11 PM
    #3949
    FreidTaco
    FreidTaco boost
    jeff
    Panhandle of Wyoming
    06 Tacoma TRD OffRoad SR5
    URD Stage 3 SC. 35" duratracs LT
    Is it possible that the engagement can change? Here is my situation: 4hi 1st to 2nd gear shift in 12"+ of snow on 35's the clutch started slipping. Had to use the skinny pedal to power through a drift. Got to the other side and now it is extremely hard to get trans into any gear. Clutch fully depressed and forcing into first the pickup will actually start moving forward while trying to put it into gear. Keep in mind this is a stage 3+ clutch rated for over 580 wheel torque. I know my engine won't put out that high even running stage 3 urd setup.
    Also on a side note.... is it possible to hear a blown head gasket. As in sounds like an exhaust leak but from one cylinder on passenger side.
  10. Jan 6, 2016 at 1:09 AM
    #3950
    VolcomTacoma
    VolcomTacoma Well-Known Member
    Jeff
    NorCal
    2015 TRD Sport 4x4 6 Speed Supercharged
    Front- Camburg 4x4 Long Travel 2.5" King Coilovers 2.5" King Triple Bypasses Wheelers Superbumps Rear- DMZ SUA 16" 3.0 King Triple Bypasses 3" 2.0 Fox bumps Wheels and Tires- 295/75/16 Toyo ATII XTREME SCS SR8 Dark Matte Bronze 16" Lighting- (2) 30" Combo light bars (4) Iggycorp diffused pods Tepui Ayer TRD Supercharger URD Mark III 3" Exhaust URD 4x4 Y Pipe URD CAI URD 2.85 Stealth Pulley Hurst Core Shifter with Hurst T URD Stage 3 clutch URD Lightweight flywheel URD Throw out bearing upgrade AEM Wideband AFR Gauge Speedhut Boost Gauge Craven Speed Flex Pod mount Weathertech Floor Liners BAMF Sliders Ultragauge sPod SE ARB CKMTA12 Hella Supertone horns Relentless Tailgate Reinforcement
    Well, today it seemed like everything firmed up a bit. Maybe I need to drive it around some more. That first 2 inches of play seemed alot firmer this afternoon. Ill drive it around for a little longer and see if it was just hydrolics or something that needed to be pumped.
  11. Jan 6, 2016 at 6:11 AM
    #3951
    Torspd
    Tor
    The Great America!
    I'd check your pedal to master cylinder piston as well. At least to rule it out.
    Let me ask this though. How long and or how many miles does the clutch have on it? Is it making any new or unfamiliar noises? Was a new TOB installed? Have you checked your reservoir's fluid level? Does the clutch pedal still behave the same as when the clutch worked properly, pressure wise?
  12. Jan 6, 2016 at 6:19 AM
    #3952
    Torspd
    Tor
    The Great America!
    On my twin disk, ever since I swapped to the Tilton TOB, I have encountered the strangest operation. Which I have taken my time to solve. The issue being that if I haven't driven the truck, in say 8 hours, the clutch pedal will be extremely soft.
    Then after driving a few miles, the clutch pedal resistance increases, or stiffens up. If I then park the truck for a short period of time, then come back to it, the first depression of the pedal will be extremely stiff. Then I pump it a few times, and the resistance lessens back to the "driving stiffness." The McLeod TOB was just always stiff.
    I have upgraded all of the lines from the master cylinder to the TOB, to -4 AN. Installed a new master cylinder. Installed an independant reservoir. All to no avail. The only next option is to try installing a larger diaphragm master cylinder. Unfortunately, the one I ordered from Wilwood was far to large overall. So I'll need to get a different one.
    Crom likes this.
  13. Jan 6, 2016 at 7:29 AM
    #3953
    FreidTaco
    FreidTaco boost
    jeff
    Let me ask this though. How long and or how many miles does the clutch have on it? 1year almost to the day. Around 8k miles
    Is it making any new or unfamiliar noises? No new noises.
    Was a new TOB installed? Yes.
    Have you checked your reservoir's fluid level? Yes. It is golden.
    Does the clutch pedal still behave the same as when the clutch worked properly, pressure wise? I feel no difference.
    Maybe pressure plate went bad or throw out fork bent?
  14. Jan 6, 2016 at 8:20 AM
    #3954
    Torspd
    Tor
    The Great America!
    How much play is between your clutch pedal and the piston?
    If you push the clutch pedal in all the way, is it easy to go into gear, or hard? And does the vehicle try to move forward with the clutch pedal fully depressed? (I believe that is what you were trying to state earlier?)
    If it tries to move forward while clutch is fully depressed, and trying to get into gear, then your clutch isn't fully disengaging.
    Make sure there is only a few millimeters of play between the clutch pedal and piston.
  15. Jan 6, 2016 at 9:00 AM
    #3955
    Torspd
    Tor
    The Great America!
    Sorry. I was in a rush and didn't realize that you had answered the questions within the quote.
  16. Jan 6, 2016 at 9:02 AM
    #3956
    FreidTaco
    FreidTaco boost
    jeff
    No worries. I will double check specs when i get home end of the week. Do you know total travel distances of the slave cylinder?
    And on the head gasket, could that be blown or maybe a bad valve now that i think about it...
  17. Jan 6, 2016 at 9:52 AM
    #3957
    Torspd
    Tor
    The Great America!
    I do not know the travel specs of the master cylinder, under the pedal, or the slave cylinder, in the transmission. The specs for pedal travel between back of pedal and piston should be easy to find though.
    You shouldn't be able to hear a head gasket problem, externally. I am guessing you are meaning a head to header gasket perhaps? That would be audible, and sound like a loud clicking. Depending on where or how bad the leak is, it will throw a CEL. There will also be tell tell signs of soot around the area.
  18. Jan 6, 2016 at 9:57 AM
    #3958
    Torspd
    Tor
    The Great America!
    Never even saw that Evo in person and already miss is. Aiming to emulate as much of that vehicle as possible. ;)
    @FreidTaco
    Also check your fittings for the clutch. Make sure they are all tight and try rebleeding it as well. Knock out all of the simple things prior to taking any big steps.
  19. Jan 6, 2016 at 11:52 AM
    #3959
    FreidTaco
    FreidTaco boost
    jeff
    Will do. Thanks hoss.
  20. Jan 6, 2016 at 11:52 AM
    #3960
    Torspd
    Tor
    The Great America!
