TORSPD: NEVR
Discussion in '2nd Gen. Builds (2005-2015)' started by Torspd, Feb 9, 2012.
  1. Jan 28, 2016 at 12:20 PM
    #4041
    deeezy
    deeezy Well-Known Member
    Dana
    Hawaii
    2013 4x4 DC, 6 spd, TRD Sport
    King ext travel coilovers, Icon tubular UCA's Rear-King "Tundra" 2.5's, Allpro Expos, TRD cat-back, Hurst/Core short shift kit, etc...
    Granny shifting, not double clutching like he's supposed to.
    Torspd[OP] and SMKYTXN like this.
  2. Jan 28, 2016 at 12:38 PM
    #4042
    357sig
    357sig Donut king
    dough boy
    donut shop
    Gold digger
    Mark lives one lap at a time... nothing else matters
  3. Jan 29, 2016 at 6:48 AM
    #4043
    Torspd
    Torspd [OP] Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    I swear that I posted that earlier. Upgraded to an Eaton Aeroquip PTFE -4AN stainless braided hose, with Earl's flame shield covering it.
  4. Jan 30, 2016 at 6:31 PM
    #4044
    Torspd
    Tor
    The Great America!
  5. Jan 30, 2016 at 6:45 PM
    #4045
    Torspd
    Tor
    The Great America!
  6. Jan 30, 2016 at 6:46 PM
    #4046
    Torspd
    Tor
    The Great America!
  7. Jan 30, 2016 at 6:51 PM
    #4047
    Torspd
    Tor
    The Great America!
    SMKYTXN likes this.
  8. Jan 30, 2016 at 6:52 PM
    #4048
    StAndrew
    StAndrew Wait for it...
    Hampton Roads, Va
    SR5 4x4TRD
    Intake, exhaust, lift. Typical stuff.
    Looks like you've got a no sleep weekend coming up :thumbsup:
  9. Jan 30, 2016 at 7:02 PM
    #4049
    Torspd
    Tor
    The Great America!
    Going to tidy up the block's old paint. Waiting on headgaskets to arrive before I can button it all up.
  10. Jan 30, 2016 at 7:08 PM
    #4050
    StAndrew
    Hampton Roads, Va
    SR5 4x4TRD
    Oh that's right; got to get that hot pink.
  11. Jan 30, 2016 at 7:32 PM
    #4051
    Torspd
    Tor
    The Great America!
    Yup. No one will expect that when I pop the hood. Lol
  12. Jan 30, 2016 at 9:01 PM
    #4052
    Torspd
    Tor
    The Great America!
    Newly machined freeze plugs.
    SconnieHailer likes this.
  13. Jan 31, 2016 at 9:48 AM
    #4053
    HomerTaco
    HomerTaco
    HomerTaco
    HomerTaco
  14. Jan 31, 2016 at 10:35 AM
    #4054
    Torspd
    Tor
    The Great America!
    Got damn right!
  15. Jan 31, 2016 at 10:48 AM
    #4055
    Torspd
    Tor
    The Great America!
    I need to point out this note. *****
    Here, if you look closely, you'll see that the #4 main cap was machined to allow clearance for the ARP nuts and washers. To allow the oil pan to fit down. Without the machining of the top of the cap, and the stop of the studs, the oil pan would not be able to mount flush with the block.
    Lucario Runner likes this.
  16. Jan 31, 2016 at 10:50 AM
    #4056
    HomerTaco
    HomerTaco
    HomerTaco
    HomerTaco
    Devil is in the details... :cool:
    Torspd[OP] likes this.
  17. Jan 31, 2016 at 10:58 AM
    #4057
    Torspd
    Tor
    The Great America!
    Using this
    To do this
    From this
  18. Jan 31, 2016 at 4:26 PM
    #4058
    Taco Nation
    Taco Nation Well-Known Member
    Zack
    Clinton, MS
    94.5 F350, 77 F150, 74 F100, 11 Jeep Grand Cherokee
    Lift, wheels, tires
    Would you happen to know where I could get a stroker crank for my 2tr? I have to rebuild it so I figured I would upgrade it while it's getting machined.
  19. Jan 31, 2016 at 5:42 PM
    #4059
    StAndrew
    Hampton Roads, Va
    SR5 4x4TRD
    The 2TR has a 95mm stroke; wouldn't recommend anything longer. There is a reason the 2.7L is about as big as you'd find a displacement on a gas engine. The 3RZ (same bore and stroke as the 2TR) is essentially a stroked 2RZ.
    Although, IIRC, the 1GR has the same stroke...
  20. Jan 31, 2016 at 7:05 PM
    #4060
    Torspd
    Tor
    The Great America!
    Correct.
