TORSPD: NEVR
Discussion in '2nd Gen. Builds (2005-2015)' started by Torspd, Feb 9, 2012.
  1. Feb 1, 2016 at 4:43 AM
    #4061
    Taco Nation
    Taco Nation Well-Known Member
    Zack
    Clinton, MS
    94.5 F350, 77 F150, 74 F100, 11 Jeep Grand Cherokee
    Lift, wheels, tires
    Ok so what I'm reading is that the 1GR also has a stroke of 95mm and I'm looking at a stroker kit for the 1GR which has a 103mm stroke. 4.66L is what the kit claimes. So why couldn't this be done on a 2TR?
  2. Feb 1, 2016 at 4:55 AM
    #4062
    Torspd
    Torspd [OP] Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    The stroker crank by itself makes the engine a 4.3L. Over boring the cylinders, after having Darton Sleeves installed is how you gain the rest of the liter size. Except therein lies the issue.
    Cometic will only make a gasket so large, due to where the embossed lip is. Which mine was on the verge of.
    You could get there, but you'd have to use a copper gasket.
    Either way, sleeving ghe block is the only way to do any significant over-boring.
    The 2TR could have a stroker crank made. I would contact LC Engineering and ask them about having a stroker crank made. If you are serious. Rod length could potentially stay the same, as long as the pistons were designed with the wrist pin in a different location, specifically for the new stroke.
    It can all be done. Just need to find the people to help you get there.
    Which engine shares the most components with the 2TR would be the most beneficial. Such as head studs for example.
  3. Feb 1, 2016 at 5:00 AM
    #4063
    Torspd
    Tor
    The Great America!
    Then again, there is a limit to how much larger the stroke of a stroker crank can be. Due to physical limitations. Of the rotating assembly for one.
  4. Feb 1, 2016 at 6:45 AM
    #4064
    StAndrew
    StAndrew Wait for it...
    Hampton Roads, Va
    SR5 4x4TRD
    Intake, exhaust, lift. Typical stuff.
    Most people prefer the 2RZ 86mm stroke over the 3RZ 95mm for the good compromise between low end power and max RPM's. They respond well and put down a good power band with a turbo. The 2.7 is generally avoided as the longer stroke (generally) means a weaker con rod and lower RPM's. Its harder to get the higher end power (RPM) as you are limited by the internal weight/strength.
    As Tor can attest to, when you start making that stroke longer and those cylinders bigger, you need to be very careful with the weight of the internals as well as the strength. This isn't cheap. You also have to be careful where you cap the RPM's.
    SconnieHailer likes this.
  5. Feb 1, 2016 at 8:37 AM
    #4065
    Torspd
    Tor
    The Great America!
    Your best bet @Taco Nation , is to first find out how badly your current engine is damaged. Then lay out a plan from there.
  6. Feb 1, 2016 at 3:36 PM
    #4066
    VolcomTacoma
    VolcomTacoma Well-Known Member
    Jeff
    NorCal
    2015 TRD Sport 4x4 6 Speed Supercharged
    Front- Camburg 4x4 Long Travel 2.5" King Coilovers 2.5" King Triple Bypasses Wheelers Superbumps Rear- DMZ SUA 16" 3.0 King Triple Bypasses 3" 2.0 Fox bumps Wheels and Tires- 295/75/16 Toyo ATII XTREME SCS SR8 Dark Matte Bronze 16" Lighting- (2) 30" Combo light bars (4) Iggycorp diffused pods Tepui Ayer TRD Supercharger URD Mark III 3" Exhaust URD 4x4 Y Pipe URD CAI URD 2.85 Stealth Pulley Hurst Core Shifter with Hurst T URD Stage 3 clutch URD Lightweight flywheel URD Throw out bearing upgrade AEM Wideband AFR Gauge Speedhut Boost Gauge Craven Speed Flex Pod mount Weathertech Floor Liners BAMF Sliders Ultragauge sPod SE ARB CKMTA12 Hella Supertone horns Relentless Tailgate Reinforcement
    @Torspd is there an internal you would upgrade first above all else? One URD comes out with UCON for everyone (years from now :rofl:) I'll be having just about everything I can as a power upgrade and will start looking into upgrading internal for stronger HP and such.
  7. Feb 1, 2016 at 5:20 PM
    #4067
    Lucario Runner
    Lucario Runner Resident Truck/SUV racer
    Robert
    San Antonio, TX or nearest race track
    06 Toyota 4Runner
    AFE stage II intake, APR X1, URD 70mm Throttle Valve (ported and knife edged), NST intake manifold spacer, URD spec U headers, Denso IKH20, URD fuel pump, APR fuel rail, URD Y pipe, URD spec u catback, lightweight water pump pulley, Greddy sandwich cooler plate, Earls oil cooler, IPT valve body, FJ TRD shocks, Cusco front and rear sway bars, Energy Suspension rear track rod bushings and rear link bushings, Carbotech pads, Stoptech ss brake lines, Stoptech slotted rotors, Motul 600 rbf, Limited Grill, Painted hatch cover by me, Painted valve covers by me, Cobra CB, TRD rad and oil cap, Escort 8500, Autometer oil psi and temp gauges, AEM wideband afr gauge, Flexpod, Pioneer 400w speakers.
    Rods and pistons
    Torspd[OP] likes this.
  8. Feb 1, 2016 at 8:41 PM
    #4068
    Torspd
    Tor
    The Great America!
    What he said ^^^. Plain. Simple. Easy. Molnar, Pauter, BC, CP Carrillo. Molnar rods will be the most economical. About $600 for the set. Wiseco, JE, or CP pistons. Since those have all been made for the 1GR.
    I pat myself on the back for my contributions to Pauter, Molnar, and JE. ;)
    Pistons can be had for $800- 1200.
    Then just bearings, for the rods. Headgaskets, and head studs.
    Biscuits and FreidTaco like this.
  9. Feb 2, 2016 at 4:44 AM
    #4069
    SMKYTXN
    SMKYTXN If it can't be overdone it's not worth doing Vendor
    Nathan
    Houston
    11, 4dr, TRD Sport, 6sp
    DCFB
    So... if I put 9 ton axles under Smokey are you going to help me turbo the motor? :D
  10. Feb 2, 2016 at 5:50 AM
    #4070
    Torspd
    Tor
    The Great America!
    Planning on building a dump truck?
  11. Feb 2, 2016 at 6:05 AM
    #4071
    SMKYTXN
    Nathan
    Houston
    DCFB
    I keep having bad thoughts about putting Axletech 4000's under the taco. 6.83 gears, air lockers in the hubs, bulletproof, and only cost $2500 for the pair.
    1901424_861204747224361_4766252559637842_165eaa22949167b626758576d6a69e4e7e9e8a01.jpg
    nfs257 likes this.
  12. Feb 2, 2016 at 6:22 AM
    #4072
    Torspd
    Tor
    The Great America!
    Going to need a built engine and two turbos for those bad boys!
  13. Feb 2, 2016 at 6:53 AM
    #4073
    StAndrew
    Hampton Roads, Va
    SR5 4x4TRD
    W/ 6.83 gears? 22R could turn those things.
  14. Feb 2, 2016 at 8:07 AM
    #4074
    Torspd
    Tor
    The Great America!
    $2500 for a pair of axles with the capability of 4 wheel steering and monster trucking everything! Hell yeah.
    nfs257 and tacobell007 like this.
  15. Feb 2, 2016 at 8:16 AM
    #4075
    Lurkin
    Lurkin Well-Known Member
    Rod
    Pearland, TX
    09 PreRunner SR5 DC
    Kind of like STS turbos, seems cheap, but the devil is in the (fab/install) details. :devil:
    Torspd[QUOTED][OP] likes this.
  16. Feb 2, 2016 at 8:16 AM
    #4076
    SMKYTXN
    Nathan
    Houston
    DCFB
    Possibly. I'll have the crawl ratio to turn the tires, but the regular 2H might be an issue with the stocker.
    Yeah, 6.83 gears. The only question is what size tires? :rofl:
    There are rigs running 54's with these axles and they just laugh at them. I was thinking 44's would be plenty. :D
    That's what has me thinking about it. The WMS spacing is 93" though. So I'd have to run a very high backspace wheel to keep me under legal width.
  17. Feb 2, 2016 at 8:17 AM
    #4077
    SMKYTXN
    Nathan
    Houston
    DCFB
    Truth! Maybe I'll pick up a pair and sit on them till the aftermarket builder parts start picking up.
    Let's not forget that after you pull the brakes off the axles are still 1k lbs each.
  18. Feb 2, 2016 at 8:21 AM
    #4078
    Lurkin
    Rod
    Pearland, TX
    09 PreRunner SR5 DC
    Easy to assume that you are not trying to minimize unsprung weight. :eek:
  19. Feb 2, 2016 at 8:23 AM
    #4079
    Torspd
    Tor
    The Great America!
    Those two completed axles with tires likely weigh in almost as much as the dang truck. :eek:
  20. Feb 2, 2016 at 8:24 AM
    #4080
    SMKYTXN
    Nathan
    Houston
    DCFB
    Smokey would tip the scales close to 7-8k with those axles and tires.
