TORSPD: NEVR
Discussion in '2nd Gen. Builds (2005-2015)' started by Torspd, Feb 9, 2012.
  1. Feb 2, 2016 at 7:47 PM
    #4101
    SMKYTXN
    SMKYTXN If it can't be overdone it's not worth doing Vendor
    Nathan
    Houston
    11, 4dr, TRD Sport, 6sp
    DCFB
    Closest thing I could find to a reference image. The wheels are 20's if you were wondering.
    DF0D5369-0D8A-484D-B711-7FE14132283C_zps_a90e1e9096789dc48cac34c63d97a0fb5c21ccb3.jpg
  2. Feb 3, 2016 at 5:17 AM
    #4102
    Torspd
    Torspd [OP] Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    After a few days of block prep, I finally pulled out the timing cover which arrived with Goldylocks. To start prepping it for installation by removing any old gasket material, and swapping out the oil pump for a new one.
    Since it had lost oil pressure on the dyno, and spun some bearings, in its past life, I planned on swapping out the oil pump to be on the safe side.
    Come to find out it wouldn't be necessary.
    Didn't like the purple nurple glitter color anyway. Without work, it is basically trash. On to plan B. Pulled out the timing cover from the original block that came with the truck. Another Ace up my sleeve.
    Oh. The block is looking pretty dang good, and I must say. That new color just screams power. ;)
    SMKYTXN likes this.
  3. Feb 4, 2016 at 3:41 PM
    #4103
    Torspd
    Tor
    The Great America!
    What it used to look like.
    What it will look like, is TBA.
    SMKYTXN likes this.
  4. Feb 12, 2016 at 12:36 PM
    #4104
    Torspd
    Tor
    The Great America!
    My roomate took a really cool picture the other night, when he had to drive me home. Threw back a few to many, we'll say.
  5. Feb 16, 2016 at 12:01 PM
    #4105
    Torspd
    Tor
    The Great America!
    Guess I'll add a little update. Had some miscommunications two weeks back. As well as when I originally ordered the head gaskets. Thicker ones were needed than what I had ordered. Long story condensed, they will be arriving this week. In the mean time I have been trying to knock out punch list items of the other components so that assembly will be as quickly as possible.
    New water pump gasket installed, as well as the old silicone removed from the timing cover. Had to rummage though the old boxes to find the hardware for the water pump.
    Old oil around the pump removed and replaced with assembly lube. The tube which sends oil from the pump up to the top of the timing cover for the oil filter, recieved new gaskets. They were old and deformed. While I was there, I took some of pictures of the timing cover where the root of the timing cover TSB stems from.
    AR15xAR10 and MadTaco461 like this.
  6. Feb 16, 2016 at 2:20 PM
    #4106
    Torspd
    Tor
    The Great America!
    I posted this information in another thread as well.
    Not sure why I never took pictures prior to now, but at least now I have them and can share them.
    Here are the two machined locations, on the mating surface of the timing cover, in the location of where the power steering pump resides. As well as where the tsb fix is for.
    Here you can clearly see how the mating surface is not even. The first picture is of the gap closest to the top of the timing cover. The second and third pictures are the next slot a little lower.
    AR15xAR10 likes this.
  7. Feb 16, 2016 at 2:31 PM
    #4107
    Torspd
    Tor
    The Great America!
    These coolant tubes had some rust on them. The coating was coming off in a few external places. Sanded them down, and used POR15 as the rust inhibitor. I dare you to have some of that dry on your skin. Triple dog dare you!
    This was the preliminary coat. It has since been finished and installed to the valley.
    AR15xAR10 and ImplicitlyAlberta like this.
  8. Feb 16, 2016 at 2:56 PM
    #4108
    VolcomTacoma
    VolcomTacoma Well-Known Member
    Jeff
    NorCal
    2015 TRD Sport 4x4 6 Speed Supercharged
    Front- Camburg 4x4 Long Travel 2.5" King Coilovers 2.5" King Triple Bypasses Wheelers Superbumps Rear- DMZ SUA 16" 3.0 King Triple Bypasses 3" 2.0 Fox bumps Wheels and Tires- 295/75/16 Toyo ATII XTREME SCS SR8 Dark Matte Bronze 16" Lighting- (2) 30" Combo light bars (4) Iggycorp diffused pods Tepui Ayer TRD Supercharger URD Mark III 3" Exhaust URD 4x4 Y Pipe URD CAI URD 2.85 Stealth Pulley Hurst Core Shifter with Hurst T URD Stage 3 clutch URD Lightweight flywheel URD Throw out bearing upgrade AEM Wideband AFR Gauge Speedhut Boost Gauge Craven Speed Flex Pod mount Weathertech Floor Liners BAMF Sliders Ultragauge sPod SE ARB CKMTA12 Hella Supertone horns Relentless Tailgate Reinforcement
    If its anything like having extra strength epoxy dry on your skin, you're gonna have a patch of it there for a good two weeks :rofl:
    Biscuits and Torspd[OP] like this.
  9. Feb 16, 2016 at 3:59 PM
    #4109
    StAndrew
    StAndrew Wait for it...
    Hampton Roads, Va
    SR5 4x4TRD
    Intake, exhaust, lift. Typical stuff.
    Been there, done that. Paint thinner before it dries or it'll be there for a while.
    Torspd[QUOTED][OP] likes this.
  10. Feb 17, 2016 at 11:06 AM
    #4110
    Torspd
    Tor
    The Great America!
  11. Feb 17, 2016 at 11:34 AM
    #4111
    MadTaco461
    MadTaco461 BRO runner
    CA
    99 turbo 5 lug long travel
    Kinda stock
    I almost jumped on the spray paint train when I pulled my head last month. I do like the color.
  12. Feb 17, 2016 at 12:11 PM
    #4112
    Torspd
    Tor
    The Great America!
    I do very much as well. It turned out exactly the way I hoped.
    This is an enamel spray paint meant specifically for engines. Sprays on like it is thin, as it will run easily, but dries hard.
    American Muscle paint BTW. :spy:
    AR15xAR10, StAndrew and MadTaco461 like this.
  13. Feb 17, 2016 at 1:33 PM
    #4113
    StAndrew
    Hampton Roads, Va
    SR5 4x4TRD
    About to say, you're engine bay is gonna look like a chevy minus two cylinders (among other things).
    Torspd[QUOTED][OP] and AR15xAR10 like this.
  14. Feb 17, 2016 at 1:34 PM
    #4114
    AR15xAR10
    2013 TRD Sport 4x4 V6 ACLBFTMFW
    Go fast orange :cool:
    Torspd[OP] likes this.
  15. Feb 23, 2016 at 6:28 AM
    #4115
    Torspd
    Tor
    The Great America!
    Yesterday was a day of engine building progress. Lucario Runner picked uo the headgaskets, and assembly commenced when I made it home from work. :woot: Not without a twist to the story of course....
    Headgaskets installed.
    Cams removed for stud installtion.
    This loctite has some serious bonding strength!
    Passenger side on amd snugged. Driver side on and the torqueing of both heads about to commence.
    Found this stud which had the head cut off. Couldn't figure out why, so I had to scavange a stud from the stroker engine's set, to use in the driver side head.
    RedLantern, Crom and Lucario Runner like this.
  16. Feb 23, 2016 at 6:48 AM
    #4116
    Torspd
    Tor
    The Great America!
    Both heads all torqued down. Rob and I were laying out the game plan for the rest of the assembly. While doing so, I decided to pull the intake cam gear's VVTI solenoid out of the driver side head (visible in the picture) and move it into the passenger head where it belonged.
    Felt some resistance, and noticed that it wouldn't seat flush. Hmm????
    Upon inspection, I saw something which I had never encountered before.
    Going back to this picture, if you look closely at the two visible studs on the passenger head, you'll notice that the stud closest to the valley is higher that the other. Enough so to cause interference with the solenoid.
    And this is where the twist in the story happens.
    It now made sense why there was one cut stud & nut...so we had to uninstall that number 8 stud, and insert the cut one in its place. By this time, that locite had already started curing. Sufficiently enough, that when we tried to remove the stroke engine stud, it twisted the allen bit. :eek:
    Guess that Matco bit wasn't up to task.....
    Re-torque that bolt, and then torqued down the trimmed studs.
    Let it be known that in all of the studs which I have installed in multiple blocks, this is the first one that I have encountered such as this...an extremely uncommon occurance.
  17. Feb 23, 2016 at 6:50 AM
    #4117
    Torspd
    Tor
    The Great America!
    Hemi Orange :cool:
    AR15xAR10[QUOTED] likes this.
  18. Feb 23, 2016 at 6:50 AM
    #4118
    FreidTaco
    FreidTaco boost
    jeff
    Panhandle of Wyoming
    06 Tacoma TRD OffRoad SR5
    URD Stage 3 SC. 35" duratracs LT
    So what tolerance was off that allowed for this to happen?
  19. Feb 23, 2016 at 7:31 AM
    #4119
    Torspd
    Tor
    The Great America!
    The tolerance as in the length of the stud? It was the same as the others. I took a long straight pic and stuck it into the bottom of the hole. There is either something cemented down there or the hole just wasn't drilled to the same depth as the other 3 blocks which I have installed studs in. Couldn't get a good visual. Whatever is at the bottom, it is hard.
    Beats me how it happened. Just adds more flavor to the story.
  20. Feb 23, 2016 at 7:36 AM
    #4120
    Torspd
    Tor
    The Great America!
    @Coupe , I'll be needing one of the baffled lower oil pan spacers really soon. To finish off the engine build!
