TORSPD: NEVR
Discussion in '2nd Gen. Builds (2005-2015)' started by Torspd, Feb 9, 2012.
  1. Mar 1, 2016 at 7:08 PM
    #4201
    SconnieHailer
    SconnieHailer PutterClutch
    Marc
    West Central Wisconsin
    2012 TRD Off Road Double Cab V6 6Speed
    Awesome man, stoked to read about this today! :cool:
  2. Mar 2, 2016 at 12:24 AM
    #4202
    Gaunt596
    Gaunt596 Well-Known Member
    Matthew
    Central Maryland
    Ever thought about tuning one of your engines for E85? youll probably run out of fuel pump before you run out of tuning
  3. Mar 2, 2016 at 5:21 AM
    #4203
    Torspd
    Torspd [OP] Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    Stoked to drive it! The more I drive it the better the engine feels.
    I have actually. All of the fueling components are rated for E85. The fuel pump waiting to be installed is the E85 Walbro 400 LPH. http://www.treadstoneperformance.co...prodname=Walbro+E85+Approved+400LPH+Fuel+Pump
  4. Mar 2, 2016 at 6:36 AM
    #4204
    Torspd
    Tor
    The Great America!
    I would also like to add that the injectors are sized larger than what I'll need for my power goals. Even with E85. The only thing that I'd need to improve would be the fuel pumping system for more flow.
  5. Mar 2, 2016 at 6:37 AM
    #4205
    DOUBLLD
    DOUBLLD Well-Known Member
    Daniel
    Bluemont, VA
    05 Tacoma LS Swap Twin Turbo
    Alot
    Time for a fuel cell with a aeromotive 1000
  6. Mar 2, 2016 at 7:31 AM
    #4206
    Torspd
    Tor
    The Great America!
    Fuel cell yes. Most likely another brand/style pump setup. Due to dual stage requirements of the pumps. Without a controller or way to control the A1000, it either all low speed or high speed. Trying to keep complexity down. Which requires more planning.
    There will definitely be the Holly Hydromat installed, in whichever setup is chosen.
  7. Mar 2, 2016 at 7:37 AM
    #4207
    357sig
    357sig Donut king
    dough boy
    donut shop
    Gold digger
    Dual pumps :D
  8. Mar 2, 2016 at 8:47 AM
    #4208
    Torspd
    Tor
    The Great America!
  9. Mar 2, 2016 at 8:35 PM
    #4209
    AR15xAR10
    08 SR5 4x4 V6 IndigoInkPearl ACLBFTMFW
    Weren't some generations of this motor able to run on E85?
    I thought the 4th gen T4Rs could?
    Also, what cams are you running with these motors? There are 4 cams right?
  10. Mar 3, 2016 at 12:24 AM
    #4210
    Gaunt596
    Matthew
    Central Maryland
    Sweet. how hard is it to get E85 over here? i know its big in aussie, but tbh i havent seen a single place around me that sells it.
  11. Mar 3, 2016 at 9:13 AM
    #4211
    Torspd
    Tor
    The Great America!
    The engine isn't the problem. It is the tuning combined with a content analyzer sensor (fuel system components a given) which makes it capable.
    The cams in this engine are stock cams.
    There are two stations within 3 miles of my house. ;)
    You normally don't have to drive more than 10 miles to find a station around here.
  12. Mar 3, 2016 at 9:24 AM
    #4212
    AR15xAR10
    How come stock cams?!
  13. Mar 3, 2016 at 12:17 PM
    #4213
    Torspd
    Tor
    The Great America!
    Because there are only 1 set of new cams made by Kelford, in the U.S. and they are on my heads for the stroker. :cool:
    AR15xAR10[QUOTED] likes this.
  14. Mar 3, 2016 at 3:57 PM
    #4214
    HomerTaco
    HomerTaco
    HomerTaco
    HomerTaco
  15. Mar 4, 2016 at 5:50 PM
    #4215
    RedLantern
    RedLantern Well-Known Member
    Honolulu, Hi
    2019 TRD Pro Tacoma - Voodoo Blue / 06 double cab PreRunner Turbocharged (sold)
    I bet your toilet is a Recaro with "holy sh*t" belts to strap you down.
  16. Mar 8, 2016 at 2:55 PM
    #4216
    ImplicitlyAlberta
    ImplicitlyAlberta VA6DCO
    David
    edmonton
    06 SR5 Trail Rated, 16 Tundra CM TRD
    TC Uni Uppers, TC race lowers, TC shock tower gusset/ secondary shock hoop, Modified Pelfrey rear shock relocate, ATO shackle flip,radflo hydro bumps front and rear, Radflo 2.0 CO/ 14" rear, Arb rear air locker, ARB front bump/m8000, Road armor rear bump/m8000, FJ TransCase/ Twin sticks....other shit.
  17. Mar 8, 2016 at 6:30 PM
    #4217
    StAndrew
    StAndrew Wait for it...
    Hampton Roads, Va
    SR5 4x4TRD
    Intake, exhaust, lift. Typical stuff.
    He's probably having too much fun with his new engine. I know I would be :burnrubber:
  18. Mar 8, 2016 at 6:54 PM
    #4218
    ImplicitlyAlberta
    David
    edmonton
    Vids? I wannna hear and see this beast in action!
    :burnrubber:
  19. Mar 8, 2016 at 7:20 PM
    #4219
    Torspd
    Tor
    The Great America!
    Just been enjoying it to be honest. It runs about 10 degrees hotter with the sleeves than without. So with the URD 170* t-stat, the sensor shows a fluctuation between 181 to 190. With the stock Frankenblock, it was between 174 - 184. I just received a Motorad 160* t-stat and some new PTP exhaust wrap. To prep for turbo installation.
    I will see about getting some sort of videos up in the near future. :thumbsup:
  20. Mar 8, 2016 at 7:39 PM
    #4220
    StAndrew
    Hampton Roads, Va
    SR5 4x4TRD
    A t-stat isn't going to change the overall operating temps; it'll just open sooner to slow down the heat build up; but you will eventually run at the same max temp regardless what t-stat you run. You need to upgrade your cooling capacity :notsure:
