TORSPD: NEVR
Discussion in '2nd Gen. Builds (2005-2015)' started by Torspd, Feb 9, 2012.
  1. Mar 10, 2016 at 6:57 AM
    #4241
    VolcomTacoma
    VolcomTacoma Well-Known Member
    Jeff
    NorCal
    2015 TRD Sport 4x4 6 Speed Supercharged
    Front- Camburg 4x4 Long Travel 2.5" King Coilovers 2.5" King Triple Bypasses Wheelers Superbumps Rear- DMZ SUA 16" 3.0 King Triple Bypasses 3" 2.0 Fox bumps Wheels and Tires- 295/75/16 Toyo ATII XTREME SCS SR8 Dark Matte Bronze 16" Lighting- (2) 30" Combo light bars (4) Iggycorp diffused pods Tepui Ayer TRD Supercharger URD Mark III 3" Exhaust URD 4x4 Y Pipe URD CAI URD 2.85 Stealth Pulley Hurst Core Shifter with Hurst T URD Stage 3 clutch URD Lightweight flywheel URD Throw out bearing upgrade AEM Wideband AFR Gauge Speedhut Boost Gauge Craven Speed Flex Pod mount Weathertech Floor Liners BAMF Sliders Ultragauge sPod SE ARB CKMTA12 Hella Supertone horns Relentless Tailgate Reinforcement
    Not talking about getting in gear, talking about taking off in 1st :D
  2. Mar 10, 2016 at 7:01 AM
    #4242
    Sacrifice
    Sacrifice Motorcycle Goon
    KS
    DCSB OR 4X4 LT
    Pelfreybilt Front Bumper,BAMF sliders, Airflow Snorkel,Mini D2S Retrofits, ADS Rear Shocks, Deaver U402 Leafsprings, 35s, AllPro +2LT
    :facepalm:misread, haha
  3. Mar 10, 2016 at 7:04 AM
    #4243
    VolcomTacoma
    Jeff
    NorCal
    Its all good haha!
  4. Mar 10, 2016 at 7:06 AM
    #4244
    VolcomTacoma
    Jeff
    NorCal
    Clutch pedal has about 1/2" of friction zone now so slipping in first to get going with stock gears and 34s takes some patience. Super fun dropping the clutch in the rain from a stop though :).
    Torspd[OP] likes this.
  5. Mar 10, 2016 at 7:06 AM
    #4245
    SMKYTXN
    SMKYTXN If it can't be overdone it's not worth doing Vendor
    Nathan
    Houston
    11, 4dr, TRD Sport, 6sp
    DCFB
    Well, add a 3ft tall vertical ledge to that hill and you'll slip the clutch. Unless you're the guy that pins it and prays. :rofl:
    I could care less about getting off the line fast, that's not what my rig is about. :D
  6. Mar 10, 2016 at 7:07 AM
    #4246
    VolcomTacoma
    Jeff
    NorCal
    Nope, I don't pin it anymore offroad unless I want to rooster tail. My 2WD days are over :D
  7. Mar 10, 2016 at 7:33 AM
    #4247
    Torspd
    Torspd [OP] Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    Slip is one factor. Strength through better construction is another.
    The OEM design is miserably poor. Only amasses to a runny fart. Not even a floater.
    At least upgrade to another brand's OEM replacement.
    SMKYTXN likes this.
  8. Mar 10, 2016 at 7:50 AM
    #4248
    VolcomTacoma
    Jeff
    NorCal
    Agreed. The stock clutch is great if you never offroad or plan on going over 3k rpms. Seems like I keep seeing supercharged 6 speeds coming out of the woodwork complaining about excessive slippage. I am convinced that the OEM clutch simply can not handle the power. I mean, I slipped it alot, which is probably why I barely got any miles on it before it started slipping, but alot of guys are saying 10-20k miles and then having to replace. Boo I say.
    Torspd[QUOTED][OP] likes this.
  9. Mar 10, 2016 at 7:56 AM
    #4249
    Torspd
    Tor
    The Great America!
    The stock clutch can barely handle the weight added from off road builds. Their design makes it easy to either separate the hub, loose a spring from the hub, and slip due to light clamping pressure of the pressure plate. Larger tires and added weight stress that the stock clutch the most, especially in higher gears.
    Not even taking about adding power. A clutch with higher torque capacity is a must.
  10. Mar 10, 2016 at 7:58 AM
    #4250
    SMKYTXN
    Nathan
    Houston
    DCFB
    One of these days I'm going to teach you how to quote my posts so I know when you're talking to me. :rofl:
  11. Mar 10, 2016 at 8:02 AM
    #4251
    Torspd
    Tor
    The Great America!
    I'm just talking to all.
  12. Mar 10, 2016 at 8:03 AM
    #4252
    VolcomTacoma
    Jeff
    NorCal
    Hah. Quote what now?
  13. Mar 10, 2016 at 8:05 AM
    #4253
    Lurkin
    Lurkin Well-Known Member
    Rod
    Pearland, TX
    09 PreRunner SR5 DC
    No! You must read all of his posts for content and applicability. They are THAT important.
    :D
  14. Mar 10, 2016 at 8:06 AM
    #4254
    Torspd
    Tor
    The Great America!
  15. Mar 10, 2016 at 10:11 AM
    #4255
    SconnieHailer
    SconnieHailer PutterClutch
    Marc
    West Central Wisconsin
    2012 TRD Off Road Double Cab V6 6Speed
    Wondering when my stock clutch will die. My truck weighs almost 6k :cookiemonster:
    Gonna get the heavy fly when it does. :)
    AR15xAR10 likes this.
  16. Mar 10, 2016 at 10:22 AM
    #4256
    deeezy
    deeezy Well-Known Member
    Dana
    Hawaii
    2013 4x4 DC, 6 spd, TRD Sport
    King ext travel coilovers, Icon tubular UCA's Rear-King "Tundra" 2.5's, Allpro Expos, TRD cat-back, Hurst/Core short shift kit, etc...
    Where is the heavier flywheel from?
  17. Mar 10, 2016 at 10:22 AM
    #4257
    Torspd
    Tor
    The Great America!
    deeezy likes this.
  18. Mar 10, 2016 at 10:23 AM
    #4258
    SconnieHailer
    Marc
    Urd. It's 9.5 lbs heavier. 400$
  19. Mar 10, 2016 at 10:28 AM
    #4259
    deeezy
    Dana
    Hawaii
    I just went and looked at it and it does look good. I'll have to consider that when it's time.
  20. Mar 10, 2016 at 10:32 AM
    #4260
    Torspd
    Tor
    The Great America!
    Keeps the gears a turning.
    TripleThreat likes this.
