TORSPD: NEVR
Discussion in '2nd Gen. Builds (2005-2015)' started by Torspd, Feb 9, 2012.
  1. Mar 10, 2016 at 10:33 AM
    #4261
    Sacrifice
    Sacrifice Motorcycle Goon
    KS
    DCSB OR 4X4 LT
    Pelfreybilt Front Bumper,BAMF sliders, Airflow Snorkel,Mini D2S Retrofits, ADS Rear Shocks, Deaver U402 Leafsprings, 35s, AllPro +2LT
    Is that loaded with gear? Other than a rear bumper i think we are near setup the same now, but im only at 5360
  2. Mar 10, 2016 at 10:37 AM
    #4262
    SconnieHailer
    SconnieHailer PutterClutch
    Marc
    West Central Wisconsin
    2012 TRD Off Road Double Cab V6 6Speed
    Yea all loaded to wheel for a weekend I'm at like 5800-5900. 5600 last time I rolled across the scale at the dump. In DD mode
  3. Mar 10, 2016 at 11:34 AM
    #4263
    SMKYTXN
    SMKYTXN If it can't be overdone it's not worth doing Vendor
    Nathan
    Houston
    11, 4dr, TRD Sport, 6sp
    DCFB
    You guys are almost as good as @colinb17 used to be when it comes to spending my money for me.
    colinb17 and AR15xAR10 like this.
  4. Mar 10, 2016 at 11:41 AM
    #4264
    Torspd
    Torspd [OP] Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    I can easily help with more. Good thing you're a vendor. Gets the members to help fund the build. ;) I should do the same. :spy:
  5. Mar 10, 2016 at 11:43 AM
    #4265
    Lurkin
    Lurkin Well-Known Member
    Rod
    Pearland, TX
    09 PreRunner SR5 DC
    Get another job or two, you'll be fine. :deadhorse:
    nfs257 likes this.
  6. Mar 10, 2016 at 11:51 AM
    #4266
    SMKYTXN
    Nathan
    Houston
    DCFB
    Might have to have to have a random sale to fund the rest of the goodies needed for this project. :D
    Buy more of my stuff and I'll be fine. :D
    Torspd[QUOTED][OP] and AR15xAR10 like this.
  7. Mar 10, 2016 at 11:54 AM
    #4267
    Lurkin
    Rod
    Pearland, TX
    09 PreRunner SR5 DC
    :rofl::rofl:
    Good point, but to do that you're going to need to expand your street queen catalog. ;)
  8. Mar 10, 2016 at 11:56 AM
    #4268
    SMKYTXN
    Nathan
    Houston
    DCFB
    So the question is... URD Stage 2, 3, or 3+?
    I'm thinking either 2 or 3. They're the same price, so which one would be better suited to my purposes. :turtleride:
  9. Mar 10, 2016 at 12:49 PM
    #4269
    VolcomTacoma
    VolcomTacoma Well-Known Member
    Jeff
    NorCal
    2015 TRD Sport 4x4 6 Speed Supercharged
    Front- Camburg 4x4 Long Travel 2.5" King Coilovers 2.5" King Triple Bypasses Wheelers Superbumps Rear- DMZ SUA 16" 3.0 King Triple Bypasses 3" 2.0 Fox bumps Wheels and Tires- 295/75/16 Toyo ATII XTREME SCS SR8 Dark Matte Bronze 16" Lighting- (2) 30" Combo light bars (4) Iggycorp diffused pods Tepui Ayer TRD Supercharger URD Mark III 3" Exhaust URD 4x4 Y Pipe URD CAI URD 2.85 Stealth Pulley Hurst Core Shifter with Hurst T URD Stage 3 clutch URD Lightweight flywheel URD Throw out bearing upgrade AEM Wideband AFR Gauge Speedhut Boost Gauge Craven Speed Flex Pod mount Weathertech Floor Liners BAMF Sliders Ultragauge sPod SE ARB CKMTA12 Hella Supertone horns Relentless Tailgate Reinforcement
    I'd say 2. 3 is great if you're boosted and want to go fast. If I wasnt boosted but wanted an improved clutch i would have gone with 2
  10. Mar 10, 2016 at 12:51 PM
    #4270
    SMKYTXN
    Nathan
    Houston
    DCFB
    I'll keep that in mind, but for now I'm going to leave well enough alone. :thumbsup:
  11. Mar 10, 2016 at 1:11 PM
    #4271
    VolcomTacoma
    Jeff
    NorCal
    Well, my clutch was so bad I basically had to drive like grandma. Boosting in any gear was impossible, giving it more than 1/3 throttle meant slippage in any gear, and it went from just fine to that in about a months time. So keep an eye out...once that clutch start slippings, its a big downhill from there. In my defense, I had every intention of getting a race clutch in there, so I didnt really give many fucks about how I treated my oem clutch.
    Biscuits, Torspd[OP] and SMKYTXN like this.
  12. Mar 10, 2016 at 2:18 PM
    #4272
    StAndrew
    StAndrew Wait for it...
    Hampton Roads, Va
    SR5 4x4TRD
    Intake, exhaust, lift. Typical stuff.
    Stage 2 URD would be my vote. The stage 3 uses ceramic material on its friction plate which is much more grabby than organic clutches and generally are not great for daily driving. The URD stage 2 is still a typical organic clutch (on steroids) for a much better feel when driving around.
  13. Mar 10, 2016 at 2:35 PM
    #4273
    Sacrifice
    KS
    DCSB OR 4X4 LT
    Go stage 3! Haha. Im gonna be the odd one but i like a stiff clutch. I ran a 6 puck unsprung in one of my old DDs.
    Torspd[OP] likes this.
  14. Mar 10, 2016 at 2:51 PM
    #4274
    HomerTaco
    HomerTaco
    HomerTaco
    HomerTaco
    I got nearly 170K out of my stock clutch. Replaced it with OEM before the crawl box install... I figured since I did fine with the original I might as well stick with it. :oops:
    Biscuits and Torspd[OP] like this.
  15. Mar 12, 2016 at 7:14 PM
    #4275
    Torspd
    Tor
    The Great America!
  16. Mar 12, 2016 at 7:16 PM
    #4276
    Gaunt596
    Gaunt596 Well-Known Member
    Matthew
    Central Maryland
    That parking brake, TPMS, and 4-lo light tho
  17. Mar 12, 2016 at 7:18 PM
    #4277
    Torspd
    Tor
    The Great America!
    Don't forget the air bag light....
  18. Mar 12, 2016 at 7:36 PM
    #4278
    Gaunt596
    Matthew
    Central Maryland
    wasnt sure what the other yellow light in the corner was, now i know
  19. Mar 12, 2016 at 7:37 PM
    #4279
    Torspd
    Tor
    The Great America!
    Nope. That is another one. Lol
  20. Mar 12, 2016 at 7:38 PM
    #4280
    Gaunt596
    Matthew
    Central Maryland
    good god, how many lights do you have lit up on the dash now? did you attack the wiring harness with a razor blade or something?
