TORSPD: NEVR
Discussion in '2nd Gen. Builds (2005-2015)' started by Torspd, Feb 9, 2012.
  1. Apr 25, 2016 at 12:17 PM
    #4541
    Torspd
    Torspd [OP] Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    Those were back in '06 that I purchased them. Not sure if thwy are still available.
  2. Apr 25, 2016 at 1:45 PM
    #4542
    sasquatch95
    sasquatch95 Well-Known Member
    Hunter
    nanaimo BC
    07 DCLB sport
    Love to hear about the specs of your cams vs. The other ones
  3. Apr 25, 2016 at 3:03 PM
    #4543
    Torspd
    Tor
    The Great America!
    I'll post up what data I have in a little bit.
    thewarriordinghy likes this.
  4. Apr 25, 2016 at 3:08 PM
    #4544
    thewarriordinghy
    thewarriordinghy General Lee's Titan
    Ben
    Georgia
    2017 Nissan Titan 4x4
    Temporarily Stock
    they good for N/A? require a tune?
  5. Apr 25, 2016 at 3:10 PM
    #4545
    Torspd
    Tor
    The Great America!
    His were more N/A oriented. Mine are turbo oriented. Mine will work with either, his will be best for N/A and S/C.
  6. Apr 25, 2016 at 3:36 PM
    #4546
    thewarriordinghy
    Ben
    Georgia
    Temporarily Stock
    So does it need a tune or no?
  7. Apr 25, 2016 at 7:19 PM
    #4547
    F75gunslinger
    F75gunslinger Ka like a wheel
    Christian
    Rochester,NY
    SWB '10 Doublecab TRD Sport 4x4
    Cluster and Radio LED swap,Westin bull bar,2nd set of bed tie downs,URD SS,K&N filter,weathertechs
    Tease !!
  8. Apr 25, 2016 at 7:26 PM
    #4548
    StAndrew
    StAndrew Wait for it...
    Hampton Roads, Va
    SR5 4x4TRD
    Intake, exhaust, lift. Typical stuff.
    No tune but Tor needs a dyno!
    ImplicitlyAlberta likes this.
  9. Apr 25, 2016 at 7:27 PM
    #4549
    thewarriordinghy
    Ben
    Georgia
    Temporarily Stock
    so these can just bolt up and run with tune and no issues?
  10. Apr 25, 2016 at 7:30 PM
    #4550
    Torspd
    Tor
    The Great America!
    Here are the specs of my camshafts, for a point of reference:
    Kelford Camshafts Stage 2 Turbo cams.
    Total duration 265 intake, 270 exhaust.
    Duration at 1mm valve lift, 225 inlet, 231 exhaust.
    Total valve lift with lash set, 10.55mm inlet, 10.75mm exhaust.
    If I remember the conversation correctly, the OEM total durations are 232 intake, and 236 exhaust.
    What specs that I have of his are:
    256/248 with a 9.65mm lift.
    Intake at 10.16mm exhaust at 9.7mm
    RedLantern likes this.
  11. Apr 25, 2016 at 7:38 PM
    #4551
    Torspd
    Tor
    The Great America!
    It won't need a tune. A tune will definitely help optimize the beast as a whole. If you were to have enough additional mods, in supplement, and the engine output was exceeding the injector duty cycle, then definitely a tune would be recommended.
    Oh yeah. Super old picture. I ended up literally giving those wheels away. To my neighbor. As I couldn't find a buyer and didn't want to scrap them.
    Still there. Fortunately, I am not worried or in a rush. The joys of having three vehicles. Who knows. With any luck, I'll get it back just in time to swap in the stroker engine....Wouldn't that be something?
    StAndrew[QUOTED] likes this.
  12. Apr 25, 2016 at 7:39 PM
    #4552
    Torspd
    Tor
    The Great America!
    I should probably start a new thread specifically to get this information more visibility.
    nfs257 likes this.
  13. Apr 25, 2016 at 9:52 PM
    #4553
    FreidTaco
    FreidTaco boost
    jeff
    Panhandle of Wyoming
    06 Tacoma TRD OffRoad SR5
    URD Stage 3 SC. 35" duratracs LT
    Put me as a absolute yes for a cam gb purchaser.
  14. Apr 25, 2016 at 10:13 PM
    #4554
    TonyDobbs
    TonyDobbs Well-Known Member
    Tony
    Cotati, CA
    2012 LT TRD OR + 2007 TRD Sport
    Why would his be better than yours in a S/C application? I'm not terribly knowledgeable on cam specs, so I'm just curious as to why you say that.
  15. Apr 26, 2016 at 9:22 AM
    #4555
    Torspd
    Tor
    The Great America!
    N/A cams have intake and exhaust overlap. Where their lobe separation angles overlap to allow intake and exhaust ports to be open, at the same time, for a small amount of time. Varying on what their LSA is. It could be more or less. This allows intake air to be used to push out exhaust gasses. Improved cylinder scavenging, effectively.
    On a turbo setup, their can be a lot of increased pressure built up between the cylinder head and the turbine housing's inlet. There is a potential for that to blow back into the intake, if the LSA's overlap. Therefore, in most case scenarios, turbo cams don't overlap intake and exhaust opening events.
  16. Apr 26, 2016 at 9:44 AM
    #4556
    HomerTaco
    HomerTaco
    HomerTaco
    HomerTaco
    As always, I learned something new. :)
    ninjastar808, BradyT88 and Torspd[OP] like this.
  17. Apr 26, 2016 at 6:06 PM
    #4557
    RedLantern
    RedLantern Well-Known Member
    Honolulu, Hi
    2019 TRD Pro Tacoma - Voodoo Blue / 06 double cab PreRunner Turbocharged (sold)
    I wonder if they have a part number for turbo cams.
  18. Apr 26, 2016 at 7:17 PM
    #4558
    Torspd
    Tor
    The Great America!
    The only one that I might have, would be on the back side of my cams, as I never received a part number.
    Or you contact Kelford, and ask them if they have a part number for a set. Mine require quite a bit of head work. Including aftermarket valves.
  19. Apr 27, 2016 at 12:50 PM
    #4559
    Lucario Runner
    Lucario Runner Resident Truck/SUV racer
    Robert
    San Antonio, TX or nearest race track
    06 Toyota 4Runner
    AFE stage II intake, APR X1, URD 70mm Throttle Valve (ported and knife edged), NST intake manifold spacer, URD spec U headers, Denso IKH20, URD fuel pump, APR fuel rail, URD Y pipe, URD spec u catback, lightweight water pump pulley, Greddy sandwich cooler plate, Earls oil cooler, IPT valve body, FJ TRD shocks, Cusco front and rear sway bars, Energy Suspension rear track rod bushings and rear link bushings, Carbotech pads, Stoptech ss brake lines, Stoptech slotted rotors, Motul 600 rbf, Limited Grill, Painted hatch cover by me, Painted valve covers by me, Cobra CB, TRD rad and oil cap, Escort 8500, Autometer oil psi and temp gauges, AEM wideband afr gauge, Flexpod, Pioneer 400w speakers.
  20. Apr 27, 2016 at 1:55 PM
    #4560
    TonyDobbs
    Tony
    Cotati, CA
    Awesome explanation, thanks Torspd!
    Torspd[QUOTED][OP] likes this.
