TORSPD: NEVR
Discussion in '2nd Gen. Builds (2005-2015)' started by Torspd, Feb 9, 2012.
  1. Aug 9, 2016 at 12:51 PM
    #4961
    Torspd
    Torspd [OP] Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    I agree. His track awareness and driving patterns proved he should have started in Novice. Who knows if he'll return to the next event. Either way, it all adds to the excitement and story of the event.
    ChadsPride likes this.
  2. Aug 9, 2016 at 12:54 PM
    #4962
    Torspd
    Tor
    The Great America!
    So now to get the last few parts to do the rear disk conversion, and purchase the new Haltech Elite 2500.....to prep for maximum boost!
  3. Aug 9, 2016 at 1:15 PM
    #4963
    XPOTRPR
    XPOTRPR CNC Programmer/Machinist
    Josh
    Chandler, AZ
    > BUILD LINKS >
    and excitement while out there I'm sure! moving 3k pound obstacles. lol
  4. Aug 9, 2016 at 1:21 PM
    #4964
    Gaunt596
    Gaunt596 Well-Known Member
    Matthew
    Central Maryland
    Hopefully he at least realizes that he needs to be in the novice group... We all have to start somewhere
    Haltecs are nice, I just wish there was a way to wire them in and leave the stock OBD2 in a happy place
  5. Aug 9, 2016 at 2:45 PM
    #4965
    Torspd
    Tor
    The Great America!
    That we do. :thumbsup:
    My ProEFI is wired in a plug n play harness which still allows me to use the OBDII Port, with the factory ecu. The new Elite can be wired in with the obd port to read all codes through the Haltech. If you weren't aware. I'd have to link that video.
  6. Aug 9, 2016 at 3:51 PM
    #4966
    4Running Daily
    4Running Daily Long Live ZS
    Connor
    Tempe/San Diego
    1996 Toyota 4Runner
    We had a guy auto cross his Toyota Avalon in a BMW event, he blew through the tires after 2 runs haha
  7. Aug 9, 2016 at 4:26 PM
    #4967
    Torspd
    Tor
    The Great America!
    O_O Wow! Guess he did a "run whatchu brung." Lol.
  8. Aug 9, 2016 at 4:37 PM
    #4968
    sasquatch95
    sasquatch95 Well-Known Member
    Hunter
    nanaimo BC
    07 DCLB sport
    Quick question.. Is there a huge difference between a oval muffler or a round muffler if they are the same length? Will one be more noisy then the other?
  9. Aug 9, 2016 at 4:39 PM
    #4969
    VolcomTacoma
    VolcomTacoma Well-Known Member
    Jeff
    NorCal
    2015 TRD Sport 4x4 6 Speed Supercharged
    Front- Camburg 4x4 Long Travel 2.5" King Coilovers 2.5" King Triple Bypasses Wheelers Superbumps Rear- DMZ SUA 16" 3.0 King Triple Bypasses 3" 2.0 Fox bumps Wheels and Tires- 295/75/16 Toyo ATII XTREME SCS SR8 Dark Matte Bronze 16" Lighting- (2) 30" Combo light bars (4) Iggycorp diffused pods Tepui Ayer TRD Supercharger URD Mark III 3" Exhaust URD 4x4 Y Pipe URD CAI URD 2.85 Stealth Pulley Hurst Core Shifter with Hurst T URD Stage 3 clutch URD Lightweight flywheel URD Throw out bearing upgrade AEM Wideband AFR Gauge Speedhut Boost Gauge Craven Speed Flex Pod mount Weathertech Floor Liners BAMF Sliders Ultragauge sPod SE ARB CKMTA12 Hella Supertone horns Relentless Tailgate Reinforcement
    Im gonna go out on a limb and say muffler shape has zero bearing on anything, but length, width, and internals is everything
  10. Aug 9, 2016 at 5:31 PM
    #4970
    XPOTRPR
    Josh
    Chandler, AZ
    > BUILD LINKS >
    this, but usually the oval style are the ones that have more baffling, etc.
  11. Aug 9, 2016 at 6:01 PM
    #4971
    sasquatch95
    Hunter
    nanaimo BC
    07 DCLB sport
    That's what I figured just wanted to make sure! Thanks guys
  12. Aug 9, 2016 at 9:20 PM
    #4972
    Torspd
    Tor
    The Great America!
    "If this, then this." Wouldn't those aspects dictate shape? o_O :D
  13. Aug 9, 2016 at 9:34 PM
    #4973
    VolcomTacoma
    Jeff
    NorCal
    NO. Lol
  14. Aug 9, 2016 at 9:45 PM
    #4974
    Gaunt596
    Matthew
    Central Maryland
    id really like to see this, if not for my truck, then for my rally car, since it needs to keep the OBD2 intact
  15. Aug 10, 2016 at 7:16 AM
    #4975
    Torspd
    Tor
    The Great America!
    This is from Haltech.
    "If you are wiring into your factory harness you always can run a parallel ECU installation with the factory ECU remaining to communicate on the CAN bus."
  16. Aug 10, 2016 at 8:00 AM
    #4976
    DOUBLLD
    DOUBLLD Well-Known Member
    Daniel
    Bluemont, VA
    05 Tacoma LS Swap Twin Turbo
    Alot
    should just do a motec. can do the same thing an is a amazing ecu
  17. Aug 10, 2016 at 8:08 AM
    #4977
    Torspd
    Tor
    The Great America!
    I'm not paying that kind of money. No way
  18. Aug 10, 2016 at 11:49 AM
    #4978
    DOUBLLD
    Daniel
    Bluemont, VA
    Alot
    boooo lol jk i can feel you on the price. still a amazing product
  19. Aug 10, 2016 at 1:45 PM
    #4979
    Gaunt596
    Matthew
    Central Maryland
    Yeah, I just haven't figured out how to set up their software to output to the OEM ecu to keep it happy and not throw codes. Plus I'm not 100% sure when Canbus became a standard
  20. Aug 10, 2016 at 1:50 PM
    #4980
    VolcomTacoma
    Jeff
    NorCal
    Well, in other news I bugged Gadget a bunch on facebook and told him I'd guinea pig a 2015 UCON and he said they finally got a donor truck local, so its not needed. So fingers crossed that they release it soon! Guess I better get my regear out of the way soon so I can start setting aside more monies for more HP stuff :D
    nfs257 and ChadsPride like this.
