TORSPD: NEVR
Discussion in '2nd Gen. Builds (2005-2015)' started by Torspd, Feb 9, 2012.
  1. Nov 19, 2012 at 8:17 PM
    #481
    Torspd
    Torspd [OP] Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    It was a project build by TRD. I still like the s/c on it, as well as the R&D they did for it, a lot more than the current setup.
    Such as something as simple as these velocity stacks.
    And double oil coolers.
  2. Nov 19, 2012 at 8:41 PM
    #482
    BradyT88
    BradyT88 Well-Known Member
    I see, crazy! Is the TRD S/C somewhat similiar to this in anyway? I don't see why they would put the research into this S/C and then put a bunch of research into another one when they already have one. haha. Unless of course this one was likely to not be safe enough for the average Joe I guess.
  3. Nov 19, 2012 at 8:43 PM
    #483
    Torspd
    Tor
    The Great America!
    I honestly have no idea on their similarities, as far as performance goes.
    By the looks, they are clearly different. Throttle body, and belt routings are in far different locations than the ones offered today.
  4. Nov 19, 2012 at 8:45 PM
    #484
    Lucario Runner
    Lucario Runner Resident Truck/SUV racer
    Robert
    San Antonio, TX or nearest race track
    06 Toyota 4Runner
    AFE stage II intake, APR X1, URD 70mm Throttle Valve (ported and knife edged), NST intake manifold spacer, URD spec U headers, Denso IKH20, URD fuel pump, APR fuel rail, URD Y pipe, URD spec u catback, lightweight water pump pulley, Greddy sandwich cooler plate, Earls oil cooler, IPT valve body, FJ TRD shocks, Cusco front and rear sway bars, Energy Suspension rear track rod bushings and rear link bushings, Carbotech pads, Stoptech ss brake lines, Stoptech slotted rotors, Motul 600 rbf, Limited Grill, Painted hatch cover by me, Painted valve covers by me, Cobra CB, TRD rad and oil cap, Escort 8500, Autometer oil psi and temp gauges, AEM wideband afr gauge, Flexpod, Pioneer 400w speakers.
    So when are you joining that uae FJ drift team? :D
  5. Nov 19, 2012 at 8:46 PM
    #485
    Torspd
    Tor
    The Great America!
    Pff. They need to join our team.
  6. Nov 19, 2012 at 8:47 PM
    #486
    Lucario Runner
    Robert
    06 Toyota 4Runner
    This is true....they owe me some camshafts.
  7. Nov 19, 2012 at 8:49 PM
    #487
    Torspd
    Tor
    The Great America!
    Get the Tomei ones. ^_^. Those Aussie guys are stingy. lol
  8. Nov 19, 2012 at 8:52 PM
    #488
    Lucario Runner
    Robert
    06 Toyota 4Runner
    I'm just playing the waiting game till they have it cataloged. Then its buy, buy, buy. And buy. I would still love to know the specs though if they release one that is vvt-i friendly
  9. Nov 19, 2012 at 8:53 PM
    #489
    Torspd
    Tor
    The Great America!
    Post up some links to that stuff. I would really like to see what Tomei was doing.
  10. Nov 20, 2012 at 12:25 AM
    #490
    acdronin
    acdronin Well-Known Member
    so let me get this straight, you are now going to have a 4.3 that you are looking to boost up to 7-800??? Stroked? Holeee sheeit! This is probably going to seem like a silly question but there is a reason for it, what kind of MPG's do you expect to get?
  11. Nov 20, 2012 at 2:09 AM
    #491
    BrokenTusk
    BrokenTusk I support a velociraptor free workplace.
    Marcelasaurus
    AB, Canada
    The Scarlett Whore
    Check Build Thread!!
    If I had to estimate? My Xrunner was supposed to get 20 mpg's combined, I was getting 22 winter gas and 24 summer with all my upgrades. I drive "spiritedly".
    Educated guess would put him in the 26-27 range at least. prob 28.
  12. Nov 20, 2012 at 5:12 AM
    #492
    BrokenTusk
    Marcelasaurus
    AB, Canada
    The Scarlett Whore
    I shouldn't have said break-in, bad choice of words. Only 1000km's break in period. 8,000 km's are the oil change intervals. I'll be switching to synthertic after the first 8,000. Which then nets me 16,000 km oil change intervals. Which is just simply awesome.
  13. Nov 20, 2012 at 5:15 AM
    #493
    Torspd
    Tor
    The Great America!
    When the man Chris "Diablo" Delgado fine tunes it, cruising around I should easily be in the 16-22 mpg range. At the track and what not, I can imagine an estimated 4-10 mpg. Lol
  14. Nov 20, 2012 at 5:21 AM
    #494
    BrokenTusk
    Marcelasaurus
    AB, Canada
    The Scarlett Whore
    ??? My efficiency when up when i was boosted. Though suppose your running larger injectors.
  15. Nov 20, 2012 at 5:45 AM
    #495
    Torspd
    Tor
    The Great America!
    I will be running 2000cc Injector Dynamics. Even at that size they flow a proper spray pattern across the entire voltage range for precise atomization and efficient burning. At this point though, it is all about the quality of the tune. That will be the ultimate end factor in my daily mpg.
    Before it even gets that far along, I am going to drive around on the stock ecu and injectors. To break it in. I will be anxious to see the mpg in that scenario as well.
  16. Nov 20, 2012 at 7:01 PM
    #496
    hansdoward
    hansdoward Active Member
    Dan
    Albuquerque
    13 trd/or dcsb 4x4
    Debadged all emblems. trd stickers still on for now
    Took two nights to read from start. Learned more than I thought possible about a subject I thought I knew somthing about. This tread is extreamly valuable to any and all who will take the time to read and understand it. You have done a great service and can be proud. Waiting to see vids of build setup. Good luck you deserve the best.
  17. Nov 21, 2012 at 9:07 AM
    #497
    Torspd
    Tor
    The Great America!
    That means a lot, and I truly appreciate what you said. Trust me. I still don't know everything there is to know, when it comes to what I am building. Still learning a ton, and want to make sure to be able to share that info for those that take the time to read through. Sharing is the only way we move the aftermarket for our trucks forward. Not matter which sector of modification that is.
    My ultimate goal is to build a bad ass truck. Along the way, help inform all of those who are interested in any portion of what I am doing. That they can get it right the first time. Currently, I feel that my biggest success in that has been helping my good friend Toon714, get his truck to where it is. With a minimal amount of issue. And his truck is quite the compilation of power and style.
  18. Nov 21, 2012 at 1:59 PM
    #498
    HomerTaco
    HomerTaco
    HomerTaco
    HomerTaco
    I'll be coming through Texas to hopefully meet up with you guys on the way to the Moab meet. Also want to catch up with Delmarva & SecretSquirrel too. ;)
  19. Nov 21, 2012 at 2:02 PM
    #499
    Torspd
    Tor
    The Great America!
    PM me when the time comes. :thumbsup:
  20. Nov 21, 2012 at 2:04 PM
    #500
    HomerTaco
    HomerTaco
    HomerTaco
    HomerTaco
    Of course. ;)
