TORSPD: NEVR
Discussion in '2nd Gen. Builds (2005-2015)' started by Torspd, Feb 9, 2012.
  1. Aug 18, 2016 at 6:36 PM
    #5021
    VolcomTacoma
    VolcomTacoma Well-Known Member
    Jeff
    NorCal
    2015 TRD Sport 4x4 6 Speed Supercharged
    Front- Camburg 4x4 Long Travel 2.5" King Coilovers 2.5" King Triple Bypasses Wheelers Superbumps Rear- DMZ SUA 16" 3.0 King Triple Bypasses 3" 2.0 Fox bumps Wheels and Tires- 295/75/16 Toyo ATII XTREME SCS SR8 Dark Matte Bronze 16" Lighting- (2) 30" Combo light bars (4) Iggycorp diffused pods Tepui Ayer TRD Supercharger URD Mark III 3" Exhaust URD 4x4 Y Pipe URD CAI URD 2.85 Stealth Pulley Hurst Core Shifter with Hurst T URD Stage 3 clutch URD Lightweight flywheel URD Throw out bearing upgrade AEM Wideband AFR Gauge Speedhut Boost Gauge Craven Speed Flex Pod mount Weathertech Floor Liners BAMF Sliders Ultragauge sPod SE ARB CKMTA12 Hella Supertone horns Relentless Tailgate Reinforcement
    I'm down. Maybe not from your backseat, however...eh...
  2. Aug 18, 2016 at 6:38 PM
    #5022
    Torspd
    Torspd [OP] Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    ......Before this gets weird..... Booooooooost!
  3. Aug 18, 2016 at 6:39 PM
    #5023
    Torspd
    Tor
    The Great America!
    And motor mounts, and push-ups.
  4. Aug 18, 2016 at 6:44 PM
    #5024
    VolcomTacoma
    Jeff
    NorCal
    I still haven't done my motor mounts :(. I'm sooooo lazy! Fuel tank is leaking, ugh. Pretty sure now I didn't seat the pump right. That ring is crazy tight and it was still leaking on the trail. Or the O-ring fell out and I didn't notice it. Soon as I've got a free day I'm gonna drop it and figure out whats leaking where.
  5. Aug 18, 2016 at 6:44 PM
    #5025
    VolcomTacoma
    Jeff
    NorCal
    But, I can still BOOOOOOOOOOOSSSTT
  6. Aug 18, 2016 at 6:48 PM
    #5026
    Torspd
    Tor
    The Great America!
    Whereas I currently cannot. :pout:
    Weren't you supposed to drop that tank a weekend or two ago??????????????????
  7. Aug 18, 2016 at 6:54 PM
    #5027
    VolcomTacoma
    Jeff
    NorCal
    I messed with that stupid vent line for 20 minutes and called it quits. Dropped the tank to the max of those lines and was able to get a visual on the pump. Nothing looked broken, and I was able to throw a flat head and a hammer on the ring and get it to move another inch or so. So the only thing I can think is the pump isn't seated or the O ring is gone.
  8. Aug 18, 2016 at 6:54 PM
    #5028
    VolcomTacoma
    Jeff
    NorCal
    But you probably have more HP unboosted than I do boosted :rofl:
  9. Aug 18, 2016 at 6:56 PM
    #5029
    Torspd
    Tor
    The Great America!
    So close and so far away......
  10. Aug 19, 2016 at 7:55 AM
    #5030
    Bonzen
    Bonzen Solid Offroad motor & transmission mounts
    Lake Havasu City
    The Silver Bullet
    Everything.
    Boostin & Roostin... sorry about your panties ladies.
    Roostfactor, Biscuits, Nickel and 3 others like this.
  11. Aug 19, 2016 at 7:57 AM
    #5031
    Torspd
    Tor
    The Great America!
    Fawk yeah that's a mean one! :mudding:
    Bonzen likes this.
  12. Aug 19, 2016 at 8:00 AM
    #5032
    Torspd
    Tor
    The Great America!
    Doubt it currently. However, with a new tune, it should be closer.....
    Has to be that the o-ring on the fuel tank isn't seated properly.
  13. Aug 19, 2016 at 10:08 AM
    #5033
    VolcomTacoma
    Jeff
    NorCal
    With 34s and not regeared Id be surprised if Im over 250 to the wheels. Its soooo sluggish.
    And yeah I really think theres no O-ring. I really don't remember putting one back on and just always assumed since then that it was stuck to the inside of the ring. So we'll see. Next week I've got a solid 3 1/2 days off to mess around with it
  14. Aug 20, 2016 at 2:32 PM
    #5034
    RedLantern
    RedLantern Well-Known Member
    Honolulu, Hi
    2019 TRD Pro Tacoma - Voodoo Blue / 06 double cab PreRunner Turbocharged (sold)
    Hopefully problem figured out. Scott said it was tested with 80# injectors after the repair and wasn't switched back to 60# on the cal file when returned to me causing the misfire.
    Still dreaming of a different ecu tho. Would love to be tuned with speed density instead.
    nfs257 likes this.
  15. Aug 20, 2016 at 11:38 PM
    #5035
    Torspd
    Tor
    The Great America!
    Stated as you wrote that, it seems so obvious. Clearly, not so obvious when you're dealing with it though.
  16. Aug 21, 2016 at 12:27 AM
    #5036
    Gaunt596
    Gaunt596 Well-Known Member
    Matthew
    Central Maryland
    Misfires, Lean conditions, Rich Conditions, Overheating and the like are the worst problems to diagnose, as theres 300 different things that can all be the cause, or be one of the causes. took me four tires to fix the overheating issue in my race car, and it ended up being a $15 part that was the issue, after throwing $100 in parts at it in diagnoses
    Lucario Runner likes this.
  17. Aug 21, 2016 at 3:03 PM
    #5037
    Torspd
    Tor
    The Great America!
    So obvious that it cannot be so simple.....such a relief once the root of the problem is found though.
    Lucario Runner and RedLantern like this.
  18. Aug 21, 2016 at 3:08 PM
    #5038
    RedLantern
    Honolulu, Hi
    So true. Hate when that happens. Happened to my brothers truck too. Had misfires as well and we couldn't figure out what was wrong. Spend a few days trying to solve it just to find a vacuum hose wasn't connected. Gets frustrating but grateful to finally figure it out.
  19. Aug 21, 2016 at 3:09 PM
    #5039
    memario1214
    memario1214 Hotshot Offroad Moderator Vendor
    Colton
    Missoula, MT
    SOLD - 05 Dub Cab TRD Sport 4x4, CURRENT - '21 Tundra MGM Limited
    Mark is over here talking in riddles... does this thread even mean anything anymore!?
    Torspd[OP] likes this.
  20. Aug 21, 2016 at 6:26 PM
    #5040
    Sacrifice
    Sacrifice Motorcycle Goon
    KS
    DCSB OR 4X4 LT
    Pelfreybilt Front Bumper,BAMF sliders, Airflow Snorkel,Mini D2S Retrofits, ADS Rear Shocks, Deaver U402 Leafsprings, 35s, AllPro +2LT
    Isn't that the truth!
    I once diagnosed a friend's turbo Volvo 240 over the phone for a crankshaft position sensor at 4am when he was 4 hour away. Which I then proceeded to have to tow afterwards cause there wasn't any easy way to fix.
