TORSPD: NEVR
Discussion in '2nd Gen. Builds (2005-2015)' started by Torspd, Feb 9, 2012.
  1. Aug 23, 2016 at 5:11 AM
    #5061
    Torspd
    Torspd [OP] Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    Hmmmmmmmm
  2. Aug 23, 2016 at 5:35 AM
    #5062
    yota243
    yota243 Well-Known Member
    E.J.
    north Alabama
    turbo 05 prerunner trd off road DC
    Bw s256 turbo with 3 in glass pack dumped pre axle raptor liner bed and top rails and fenderflares and rocker panels. Hunter side steps. Plasti-dipped upper fenders and emblems. satin black spray paint here and there inside and out. 5100's set to 1.75" up front . C channel front bumper. Maxxis bighorn 255/85/16
    all of it I suppose, that is just the first of the thing I have order that has came in. just a 3" pipe 4' long (post turbo) and then obviously the t4 flange and a 2.5" v band.
    Torspd[QUOTED][OP] likes this.
  3. Aug 23, 2016 at 7:14 AM
    #5063
    DOUBLLD
    DOUBLLD Well-Known Member
    Daniel
    Bluemont, VA
    05 Tacoma LS Swap Twin Turbo
    Alot
    what exactly are you trying to do now?
  4. Aug 23, 2016 at 12:19 PM
    #5064
    Torspd
    Tor
    The Great America!
    I have to redo we merge collector 4 the larger Borg Warner Turbo, so that it'll fit with the hood closed.
    Also quite a few things were delivered yesterday which was very exciting. This new item being one of them. With its thermal imaging camera.
  5. Aug 23, 2016 at 1:17 PM
    #5065
    VolcomTacoma
    VolcomTacoma Well-Known Member
    Jeff
    NorCal
    2015 TRD Sport 4x4 6 Speed Supercharged
    Front- Camburg 4x4 Long Travel 2.5" King Coilovers 2.5" King Triple Bypasses Wheelers Superbumps Rear- DMZ SUA 16" 3.0 King Triple Bypasses 3" 2.0 Fox bumps Wheels and Tires- 295/75/16 Toyo ATII XTREME SCS SR8 Dark Matte Bronze 16" Lighting- (2) 30" Combo light bars (4) Iggycorp diffused pods Tepui Ayer TRD Supercharger URD Mark III 3" Exhaust URD 4x4 Y Pipe URD CAI URD 2.85 Stealth Pulley Hurst Core Shifter with Hurst T URD Stage 3 clutch URD Lightweight flywheel URD Throw out bearing upgrade AEM Wideband AFR Gauge Speedhut Boost Gauge Craven Speed Flex Pod mount Weathertech Floor Liners BAMF Sliders Ultragauge sPod SE ARB CKMTA12 Hella Supertone horns Relentless Tailgate Reinforcement
    My God man, You constantly find things I didn't know I needed.
  6. Aug 23, 2016 at 1:34 PM
    #5066
    Lucario Runner
    Lucario Runner Resident Truck/SUV racer
    Robert
    San Antonio, TX or nearest race track
    06 Toyota 4Runner
    AFE stage II intake, APR X1, URD 70mm Throttle Valve (ported and knife edged), NST intake manifold spacer, URD spec U headers, Denso IKH20, URD fuel pump, APR fuel rail, URD Y pipe, URD spec u catback, lightweight water pump pulley, Greddy sandwich cooler plate, Earls oil cooler, IPT valve body, FJ TRD shocks, Cusco front and rear sway bars, Energy Suspension rear track rod bushings and rear link bushings, Carbotech pads, Stoptech ss brake lines, Stoptech slotted rotors, Motul 600 rbf, Limited Grill, Painted hatch cover by me, Painted valve covers by me, Cobra CB, TRD rad and oil cap, Escort 8500, Autometer oil psi and temp gauges, AEM wideband afr gauge, Flexpod, Pioneer 400w speakers.
    The s60 is awesome, saved me a couple trips to the toolbox today.
    Torspd[OP] likes this.
  7. Aug 23, 2016 at 2:21 PM
    #5067
    Gaunt596
    Gaunt596 Well-Known Member
    Matthew
    Central Maryland
    I need one of those. Too bad Verizon probably dosent have a chip for it
  8. Aug 23, 2016 at 2:31 PM
    #5068
    Torspd
    Tor
    The Great America!
    Unlocked , uses a sim, and has a slot for micro SD.
    Lucario Runner likes this.
  9. Aug 23, 2016 at 2:36 PM
    #5069
    XPOTRPR
    XPOTRPR CNC Programmer/Machinist
    Josh
    Chandler, AZ
    > BUILD LINKS >
    just checked them out on their Site.. holy hell that's an awesome phone! Want!
  10. Aug 23, 2016 at 2:39 PM
    #5070
    Lucario Runner
    Robert
    06 Toyota 4Runner
    I believe any major carrier can support the phone. I too wasn't willing to go sign up with verizon. I use att.
  11. Aug 23, 2016 at 2:44 PM
    #5071
    Torspd
    Tor
    The Great America!
    I guess this means that I need some better thermal barrier on the firewall. Keep my feet from getting all toasty.
    Biscuits, Crom, XPOTRPR and 1 other person like this.
  12. Aug 23, 2016 at 2:46 PM
    #5072
    Torspd
    Tor
    The Great America!
    Trust me. You NEED!
  13. Aug 24, 2016 at 4:43 AM
    #5073
    DOUBLLD
    Daniel
    Bluemont, VA
    Alot
    that is freaking cool.
  14. Aug 24, 2016 at 5:29 AM
    #5074
    Torspd
    Tor
    The Great America!
    Heck yeah it is. I have also been checking all sorts of areas around the inside of my house.
    Biscuits and DOUBLLD like this.
  15. Aug 24, 2016 at 5:38 AM
    #5075
    Lurkin
    Lurkin Well-Known Member
    Rod
    Pearland, TX
    09 PreRunner SR5 DC
    Just think, it can also be used on ex-wives/GFs to have proof that she really is a cold-hearted bitch. :D
  16. Aug 24, 2016 at 6:13 AM
    #5076
    Torspd
    Tor
    The Great America!
    Said that same thing to my neighbor yesterday. Lol.
    Think of all of the shenanigans that you can do when you go out....
  17. Aug 24, 2016 at 6:27 AM
    #5077
    Lurkin
    Rod
    Pearland, TX
    09 PreRunner SR5 DC
    :rofl::rofl:...trouble waiting for a place to happen...
  18. Aug 24, 2016 at 10:02 AM
    #5078
    Gaunt596
    Matthew
    Central Maryland
    :jerkoff: sadly that thing probably cost more than i make in a year lol
  19. Aug 24, 2016 at 10:17 AM
    #5079
    RedLantern
    RedLantern Well-Known Member
    Honolulu, Hi
    2019 TRD Pro Tacoma - Voodoo Blue / 06 double cab PreRunner Turbocharged (sold)
    Dang. I think you need to find a new job. Lol
  20. Aug 24, 2016 at 11:02 AM
    #5080
    Torspd
    Tor
    The Great America!
    $607 shipped
