TORSPD: NEVR
Discussion in '2nd Gen. Builds (2005-2015)' started by Torspd, Feb 9, 2012.
  1. Oct 18, 2016 at 7:47 PM
    #5221
    HomerTaco
    HomerTaco
    HomerTaco
    HomerTaco
    Ok need this in my life. :drool:
    Biscuits likes this.
  2. Oct 18, 2016 at 8:35 PM
    #5222
    VolcomTacoma
    VolcomTacoma Well-Known Member
    Jeff
    NorCal
    2015 TRD Sport 4x4 6 Speed Supercharged
    Front- Camburg 4x4 Long Travel 2.5" King Coilovers 2.5" King Triple Bypasses Wheelers Superbumps Rear- DMZ SUA 16" 3.0 King Triple Bypasses 3" 2.0 Fox bumps Wheels and Tires- 295/75/16 Toyo ATII XTREME SCS SR8 Dark Matte Bronze 16" Lighting- (2) 30" Combo light bars (4) Iggycorp diffused pods Tepui Ayer TRD Supercharger URD Mark III 3" Exhaust URD 4x4 Y Pipe URD CAI URD 2.85 Stealth Pulley Hurst Core Shifter with Hurst T URD Stage 3 clutch URD Lightweight flywheel URD Throw out bearing upgrade AEM Wideband AFR Gauge Speedhut Boost Gauge Craven Speed Flex Pod mount Weathertech Floor Liners BAMF Sliders Ultragauge sPod SE ARB CKMTA12 Hella Supertone horns Relentless Tailgate Reinforcement
    @Torspd is that the Stoptech kit? I'm trying to figure out how to get a Ford 9" rear end with 6 lug disc brakes together lol
  3. Oct 18, 2016 at 8:38 PM
    #5223
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    You worried about shearing your shafts, or? What about chromoly shafts?
  4. Oct 18, 2016 at 8:55 PM
    #5224
    VolcomTacoma
    Jeff
    NorCal
    No, I'm worried about- I don't know WTF I'm doing and trying to figure out where/what to order lol. I'm looking at a full float 9" from Ruffstuff, but all of their brake stuff comes with 5 lug stuff. I'm guessing I can order it all through Ruffstuff and just order a 6 lug rotor of the same size and that should work?
  5. Oct 18, 2016 at 9:00 PM
    #5225
    TonyDobbs
    TonyDobbs Well-Known Member
    Tony
    Cotati, CA
    2012 LT TRD OR + 2007 TRD Sport
    Here is another option. Front range off road does a full float with disc brakes 6 lug.
  6. Oct 18, 2016 at 9:05 PM
    #5226
    VolcomTacoma
    Jeff
    NorCal
    I see the 9.5" axle, but what Diff goes in that? I'd like to be able to order the diffs through ECGS and possibly just burn on shock mounts and leaf mounts with everything else set up lol
  7. Oct 18, 2016 at 9:09 PM
    #5227
    TonyDobbs
    Tony
    Cotati, CA
    I think it's out of a Tundra or a Landcruiser, but it's been a while. You should really give them a call instead. I've been messaging Brian about this for a while, but he's not on TW that often, so it would be faster to call. I think you will be able to source the diff from ECGS, but don't trust my word on that.
  8. Oct 18, 2016 at 9:16 PM
    #5228
    VolcomTacoma
    Jeff
    NorCal
    Interesting.
  9. Oct 18, 2016 at 9:18 PM
    #5229
    sasquatch95
    sasquatch95 Well-Known Member
    Hunter
    nanaimo BC
    07 DCLB sport
    If it's a diamond axle from front range with a 9.5diff it should be from the land cruiser
  10. Oct 18, 2016 at 9:34 PM
    #5230
    MadTaco461
    MadTaco461 BRO runner
    CA
    99 turbo 5 lug long travel
    Kinda stock
    It's pretty easy to build a 9" with 6 lug. There are a lot of places to choose from. You can piece it together like building a gun.
    Trail gear
    Camburg
    Currie
    Speedway engineering
    Ruffstuff
    Strange engineering
  11. Oct 18, 2016 at 9:49 PM
    #5231
    VolcomTacoma
    Jeff
    NorCal
    Yeah I've been eyeballing stuff a bunch, just can't find it online. Not quite ready to make calls for it all. I'll know my budget in about a month and a half after a couple awesome checks lol. Wife wants house stuff first, then paying off the Motorcycle, then Truck fund gets a bump. Working 2 months straight with like 8 days of OT on each check means I moved up from "I need to regear" to "I'm just gonna get a 9" and get it over with. And front and back lockers".
  12. Oct 18, 2016 at 9:57 PM
    #5232
    MadTaco461
    CA
    Kinda stock
    They aren't cheap, but when you add up gears locker you are like shit I should just go all out. I thought about a 9" too.
  13. Oct 18, 2016 at 10:09 PM
    #5233
    VolcomTacoma
    Jeff
    NorCal
    Exactly. Hence why I want to just order through ECGS to at least get the diffs on hand, then I can build a 9" with whats left. I have a 80's something econoline axle sitting in the garage, but the axles are 31 spline and I've been advised to just go 35 spline, and it looks a little beat up lol. Really need to get it trussed but worried about warping it when I truss it. Ugh.
  14. Oct 18, 2016 at 10:26 PM
    #5234
    VolcomTacoma
    Jeff
    NorCal
    Wow, nvm, Just found the full assembled Axle on Ruffstuff. Was looking at the wrong spot lol. $2750 or so for the assembled axle, trussed and armored. Figure a little more for the TC lower shock mounts and some new U bolts and leaf mounts and such....and then another 4k or so for Diffs....hmmmm interesting.
    Torspd[OP] and MadTaco461 like this.
  15. Oct 19, 2016 at 6:18 AM
    #5235
    Torspd
    Torspd [OP] Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    I certainly will.
    Negative. The bracketry and e-brake cable kit is from www.sosperformance.com
    The rotors are StopTech, which I picked up from Amazon. 2006 4Runner, as well as the caliper and brake pads. Still need the shoes and the other caliper.
    I wanted just the slotted rotors, but they were not available at the time.
    I also purchased a can of POR15 red caliper paint. So that the rears will match the front. I want to be different and do yellow, but then decided to just make them match.
    SonnyBones, HomerTaco and Biscuits like this.
  16. Oct 19, 2016 at 10:08 AM
    #5236
    SonnyBones
    SonnyBones I VOID WARRANTIES
    Jeffery
    2015 TACOMA ACCESS CAB
    Interested to see your results as well. Is a proportioning valve needing when installing a rear disc conversion?
  17. Oct 19, 2016 at 10:10 AM
    #5237
    VolcomTacoma
    Jeff
    NorCal
  18. Oct 19, 2016 at 10:11 AM
    #5238
    VolcomTacoma
    Jeff
    NorCal
    Unless you switch out for the FJ Master cyclindwr and stuff IIRC
  19. Oct 19, 2016 at 10:14 AM
    #5239
    TonyDobbs
    Tony
    Cotati, CA
    Interesting, do you know if the FJ's were vacuum or hydraulic?
  20. Oct 19, 2016 at 10:15 AM
    #5240
    SonnyBones
    Jeffery
    Interesting, seems like the proportioning valve would be easier, and you can do finite adjustments when needed. Very pricey brake kits from SOS Performance
