TORSPD: NEVR
Discussion in '2nd Gen. Builds (2005-2015)' started by Torspd, Feb 9, 2012.
  1. Dec 18, 2016 at 4:35 PM
    #5641
    Torspd
    Torspd [OP] Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    Very interesting!
  2. Dec 18, 2016 at 4:43 PM
    #5642
    yota243
    yota243 Well-Known Member
    E.J.
    north Alabama
    turbo 05 prerunner trd off road DC
    Bw s256 turbo with 3 in glass pack dumped pre axle raptor liner bed and top rails and fenderflares and rocker panels. Hunter side steps. Plasti-dipped upper fenders and emblems. satin black spray paint here and there inside and out. 5100's set to 1.75" up front . C channel front bumper. Maxxis bighorn 255/85/16
    Airbags=weight... Weight bad right?
    ChadsPride likes this.
  3. Dec 18, 2016 at 4:47 PM
    #5643
    Torspd
    Tor
    The Great America!
    Indubitably
    yota243 likes this.
  4. Dec 18, 2016 at 4:49 PM
    #5644
    VolcomTacoma
    VolcomTacoma Well-Known Member
    Jeff
    NorCal
    2015 TRD Sport 4x4 6 Speed Supercharged
    Front- Camburg 4x4 Long Travel 2.5" King Coilovers 2.5" King Triple Bypasses Wheelers Superbumps Rear- DMZ SUA 16" 3.0 King Triple Bypasses 3" 2.0 Fox bumps Wheels and Tires- 295/75/16 Toyo ATII XTREME SCS SR8 Dark Matte Bronze 16" Lighting- (2) 30" Combo light bars (4) Iggycorp diffused pods Tepui Ayer TRD Supercharger URD Mark III 3" Exhaust URD 4x4 Y Pipe URD CAI URD 2.85 Stealth Pulley Hurst Core Shifter with Hurst T URD Stage 3 clutch URD Lightweight flywheel URD Throw out bearing upgrade AEM Wideband AFR Gauge Speedhut Boost Gauge Craven Speed Flex Pod mount Weathertech Floor Liners BAMF Sliders Ultragauge sPod SE ARB CKMTA12 Hella Supertone horns Relentless Tailgate Reinforcement
    Indisputably
    ChadsPride and yota243 like this.
  5. Dec 18, 2016 at 5:22 PM
    #5645
    SonnyBones
    SonnyBones I VOID WARRANTIES
    Jeffery
    2015 TACOMA ACCESS CAB
  6. Dec 18, 2016 at 5:44 PM
    #5646
    nfs257
    nfs257 Well-Known Member
    DFW
    She gone
    yeah they allow you to turn the passenger one on and off so you can run race seats with out the positioning sensor
  7. Dec 18, 2016 at 5:46 PM
    #5647
    nfs257
    DFW
    She gone
  8. Dec 18, 2016 at 5:50 PM
    #5648
    MrCrowntown
    MrCrowntown Well-Known Member
    Alyn
    Ky
    06 Extended cab Prerunner 2.7
    Dirt King Mid travel with King 2.5 coilovers, Baja Kits chase SUA with 14in fox smoothies under custom hangars.
  9. Dec 18, 2016 at 6:13 PM
    #5649
    nfs257
    DFW
    She gone
    yes
    MrCrowntown[QUOTED] likes this.
  10. Dec 22, 2016 at 3:55 AM
    #5650
    VolcomTacoma
    Jeff
    NorCal
  11. Dec 22, 2016 at 5:00 AM
    #5651
    Torspd
    Tor
    The Great America!
  12. Dec 22, 2016 at 10:12 AM
    #5652
    VolcomTacoma
    Jeff
    NorCal
    Well, looks like my URD Throw out bearing upgrade crapped the bed. Shut the truck down this morning, had forgot to put it in gear, so with the door open pushed the clutch...hear a squeak from under the truck...did it a couple more times, almost positive its coming from the transmission. Sigh, really don't wanna have to pull the trans to replace the bearing.
  13. Dec 22, 2016 at 10:19 AM
    #5653
    Torspd
    Tor
    The Great America!
    I don't exactly follow what you mean about,"forgot to put it in gear,"?
    Which TOB do you have? The one with the input shaft sleeve, of the whole replacement TOB which is of a different style of operation?
  14. Dec 22, 2016 at 10:26 AM
    #5654
    VolcomTacoma
    Jeff
    NorCal
  15. Dec 22, 2016 at 10:29 AM
    #5655
    MrCrowntown
    Alyn
    Ky
    A squeak? My clutch pedal squeaks, but not my clutch.
  16. Dec 22, 2016 at 11:11 AM
    #5656
    Torspd
    Tor
    The Great America!
    All that I can say is monitor the noise. I am aware of a few cases where the sleeved came off and would spin. Installer error. Others, the sleeve would intermittently squeak. It is just the nature of the design, as it axially loads the input sleeve.
  17. Dec 22, 2016 at 11:31 AM
    #5657
    Torspd
    Tor
    The Great America!
  18. Dec 22, 2016 at 12:27 PM
    #5658
    VolcomTacoma
    Jeff
    NorCal
    My pedal squeaks on occasion, but this is definitely coming from the transmission. Different sqeak.
  19. Dec 22, 2016 at 12:28 PM
    #5659
    VolcomTacoma
    Jeff
    NorCal
    Yep, that's the plan. Haven't noticed anything detrimental about it, but have just now noticed the squeak from the tranny, so it must be deteriorating, whatever it is.
  20. Dec 22, 2016 at 1:04 PM
    #5660
    Torspd
    Tor
    The Great America!
    Could just need some more grease. Best case.
    On the later sleeve installs, I added JB weld, to fill in the voids of the worn out shaft, and for overall structural rigidity. To many stories of people's coming loose. We also added a different grease than what came with that bearing kit.
