TORSPD: NEVR
Discussion in '2nd Gen. Builds (2005-2015)' started by Torspd, Feb 9, 2012.
  1. Dec 23, 2016 at 8:51 PM
    #5681
    Gaunt596
    Gaunt596 Well-Known Member
    Matthew
    Central Maryland
    right now about 130500. also, because older truck every clip that is plastic breaks or crumbles when you touch it :annoyed:
  2. Dec 23, 2016 at 9:02 PM
    #5682
    Torspd
    Torspd [OP] Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    Haha. Yeah. You see a lot colder extremes where you're located. They they just "put salt on the wounds." Lol.
    I fight the age of mine with new mods constantly. Father time is still winning. Sigh.
    Just changing the filter alone would make your engine feel new and peppy. I promise.
  3. Dec 23, 2016 at 9:11 PM
    #5683
    Gaunt596
    Matthew
    Central Maryland
    im sure it would. that plus new fuel pump would probably gain me back a number of ponies
  4. Dec 23, 2016 at 9:31 PM
    #5684
    Torspd
    Tor
    The Great America!
    Yup yup. And it will have fresh new brushes. Not end-of-life worn out brushes.
  5. Dec 23, 2016 at 9:57 PM
    #5685
    Gaunt596
    Matthew
    Central Maryland
    beyond end of life, ive got two that im not sure if they are steering rack or differential bushes that have shed all the rubber and are nothing more than a sleeve
  6. Dec 23, 2016 at 9:59 PM
    #5686
    Torspd
    Tor
    The Great America!
    :eek: Skeletal remains.
  7. Dec 23, 2016 at 10:05 PM
    #5687
    Gaunt596
    Matthew
    Central Maryland
    yup. im also 100% sure that those bushings are the source of a clunk when turning hard left or right, hence why i think they are steering rack mounts
  8. Dec 27, 2016 at 5:44 AM
    #5688
    Torspd
    Tor
    The Great America!
    I spent a few hours last night setting up tables and functions for the Haltech Elite ecu, last night. I must say, it is very intuitive and easy to navigate. I am impressed.
    Very easy to navigate through the tables, modify the tables, navigate through the main setup, and turn on and off functions. As in various sensors and their parameters.
    To enable sensors, you just select the box to the left if the name, and assign the wires which should be used for it. Otherwise and Error will come up, directing which elements need to be corrected, in order for that function to work. Pictures will help, but man has this layout been thoroughly planned through and refined.
  9. Dec 27, 2016 at 5:46 AM
    #5689
    Torspd
    Tor
    The Great America!
    Have you inspected yet which bushings you might need? Have your ordered the steering rack bushings?
    Energry Suspension makes the steering rack bushings, correct?
  10. Dec 27, 2016 at 6:02 AM
    #5690
    inwood customs
    inwood customs Roaming potato
    Dave
    2006 v6 potato bugTuRD
    K&n, flowmaster, plastidip, chipped, hids, daves
    +1 for peekature books
    Biscuits likes this.
  11. Dec 27, 2016 at 6:20 AM
    #5691
    VolcomTacoma
    VolcomTacoma Well-Known Member
    Jeff
    NorCal
    2015 TRD Sport 4x4 6 Speed Supercharged
    Front- Camburg 4x4 Long Travel 2.5" King Coilovers 2.5" King Triple Bypasses Wheelers Superbumps Rear- DMZ SUA 16" 3.0 King Triple Bypasses 3" 2.0 Fox bumps Wheels and Tires- 295/75/16 Toyo ATII XTREME SCS SR8 Dark Matte Bronze 16" Lighting- (2) 30" Combo light bars (4) Iggycorp diffused pods Tepui Ayer TRD Supercharger URD Mark III 3" Exhaust URD 4x4 Y Pipe URD CAI URD 2.85 Stealth Pulley Hurst Core Shifter with Hurst T URD Stage 3 clutch URD Lightweight flywheel URD Throw out bearing upgrade AEM Wideband AFR Gauge Speedhut Boost Gauge Craven Speed Flex Pod mount Weathertech Floor Liners BAMF Sliders Ultragauge sPod SE ARB CKMTA12 Hella Supertone horns Relentless Tailgate Reinforcement
    Yes they do. I've got a set sitting in the garage. Pretty sure my seering rack bushings are a l8ttle loose, my rack moves a hair to much for my liking
  12. Dec 27, 2016 at 6:54 AM
    #5692
    Torspd
    Tor
    The Great America!
    Coming soon.
    Perfect.
    And for those who haven't been following, or don't have YouTube.....
    https://youtu.be/NoBnwKu5g5U
    And
    https://youtu.be/y5ssRbr4bO0
    Too damn cool!
  13. Dec 27, 2016 at 7:44 AM
    #5693
    Biscuits
    Biscuits Thorny Crown of Entropy
    Swiggity swangin' biggity bangin'
    Am I correct in my assumption that the HalTech is a stand alone ECU?
    MrCrowntown likes this.
  14. Dec 27, 2016 at 8:23 AM
    #5694
    Torspd
    Tor
    The Great America!
  15. Dec 27, 2016 at 9:27 AM
    #5695
    Biscuits
  16. Dec 27, 2016 at 9:29 AM
    #5696
    yota243
    yota243 Well-Known Member
    E.J.
    north Alabama
    turbo 05 prerunner trd off road DC
    Bw s256 turbo with 3 in glass pack dumped pre axle raptor liner bed and top rails and fenderflares and rocker panels. Hunter side steps. Plasti-dipped upper fenders and emblems. satin black spray paint here and there inside and out. 5100's set to 1.75" up front . C channel front bumper. Maxxis bighorn 255/85/16
    hey don't let them lead you to the dark side. I need you in my group buy...
    Torspd[OP] likes this.
  17. Dec 27, 2016 at 9:38 AM
    #5697
    Biscuits
    LOL no worries! I don't have $3k and change to drop on something like that.
  18. Dec 27, 2016 at 9:41 AM
    #5698
    yota243
    E.J.
    north Alabama
    super thankful for your budget and/or lack of unlimited funds... also since me and you and that other guy are "yes's" and xpo and that other guy are "maybe's" I mean we only need like 5-7 more people and we will be in bitness :bananadead:
    shameless plug
    https://www.tacomaworld.com/threads/mapecu3-feeler-possible-group-buy-af.458556/
    XPOTRPR and Biscuits[QUOTED] like this.
  19. Dec 27, 2016 at 9:45 AM
    #5699
    VolcomTacoma
    Jeff
    NorCal
    Change that to a UCON GB and I'm in 100% :D
  20. Dec 27, 2016 at 9:47 AM
    #5700
    yota243
    E.J.
    north Alabama
    no group buy discount for ucon man... but you could buy 2 of these and help us out and still come out cheaper and have 2 units just sayin
