TORSPD: NEVR
Discussion in '2nd Gen. Builds (2005-2015)' started by Torspd, Feb 9, 2012.
  1. Jan 12, 2017 at 11:03 AM
    #5781
    Biscuits
    Biscuits Thorny Crown of Entropy
    Swiggity swangin' biggity bangin'
  2. Jan 12, 2017 at 11:10 AM
    #5782
    Torspd
    Torspd [OP] Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    I didn't see you.
    Biscuits and colinb17 like this.
  3. Jan 18, 2017 at 6:38 PM
    #5783
    obs ham
    obs ham Well-Known Member
    99 tacoma trd blower
    Wow amazing build
  4. Jan 18, 2017 at 6:39 PM
    #5784
    obs ham
    See who
  5. Jan 18, 2017 at 8:34 PM
    #5785
    Torspd
    Tor
    The Great America!
    Thanks mate.
    That earlier post was towards Biscuits.
  6. Jan 19, 2017 at 7:13 AM
    #5786
    HomerTaco
    HomerTaco
    HomerTaco
    HomerTaco
  7. Jan 19, 2017 at 7:26 AM
    #5787
    SMKYTXN
    SMKYTXN If it can't be overdone it's not worth doing Vendor
    Nathan
    Houston
    11, 4dr, TRD Sport, 6sp
    DCFB
    One of these days you're going to figure out the whole "quote" thing.
    Biscuits, colinb17 and HomerTaco like this.
  8. Jan 19, 2017 at 8:56 AM
    #5788
    Torspd
    Tor
    The Great America!
    Obvious is obvious. :p
    Biscuits likes this.
  9. Jan 20, 2017 at 9:35 AM
    #5789
    Torspd
    Tor
    The Great America!
    God Bless America!!! :oldglory:
    VolcomTacoma and yota243 like this.
  10. Jan 21, 2017 at 6:53 PM
    #5790
    Torspd
    Tor
    The Great America!
    Driving home yesterday, the strangest occurance happened. A seemingly insignificant bump, made for a concerning driving condition. Each random bump thereafter, repeated the odditiy. I'd lose throttle response. Any pedal position equated to a lack luster no-cceleration.
    In summary, I tried to leave later that evening and couldn't thanks to a shoddy wiring job, by D3 Performance, some years ago. When they re-wired the truck to have the ProEFI control the throttle body.
    Basically it came down to the plug being abused and worked loose to pry the wire end out of it. So then it wasn't fully clipped and retained into the plastic. The bumps would make for an intermittent throttle pedal connection.
    Here is where it easily slid out from.
    The protruding point of solder, was nearly going through the plastic into the adjacent wire.
    Corrected, and problem solved. Thankfully.
  11. Jan 21, 2017 at 8:00 PM
    #5791
    HomerTaco
    HomerTaco
    HomerTaco
    HomerTaco
    Glad it was a simple fix! :cool:
    Torspd[OP] and MrCrowntown like this.
  12. Jan 21, 2017 at 10:30 PM
    #5792
    ImplicitlyAlberta
    ImplicitlyAlberta VA6DCO
    David
    edmonton
    06 SR5 Trail Rated, 16 Tundra CM TRD
    TC Uni Uppers, TC race lowers, TC shock tower gusset/ secondary shock hoop, Modified Pelfrey rear shock relocate, ATO shackle flip,radflo hydro bumps front and rear, Radflo 2.0 CO/ 14" rear, Arb rear air locker, ARB front bump/m8000, Road armor rear bump/m8000, FJ TransCase/ Twin sticks....other shit.
    Simple fix for someone who has troubleshot more problems on this truck than anyone.
    I couldnt imagine where id start if i had an intermittent throttle over bumps issue.
    Lmao
    Good find Tor.
    Torspd[OP] and Nickel like this.
  13. Jan 22, 2017 at 9:26 AM
    #5793
    Torspd
    Tor
    The Great America!
    I went through the pedal itself first. Took it apart and inspected it internally. Man is that a simple device. Paid attention to the wires.
    There is a blue/white wire which comes off of the plug. Well during the removal of the ProEFI, that green wire in the picture above had stood out to me. Since it was "new" and I hadn't done it. After inspecting the TB, I decided to check there. Sure enough. The same blue/white wire cut and soldered to that green wire.... all in all, it took about 45 minutes to find and correct.
    This is why I like doing these things myself.
  14. Jan 23, 2017 at 6:16 AM
    #5794
    skyking3
    skyking3 Well-Known Member
    Tom
    2016 Silver Tacoma SR5 DCSB
    TRD cai, TRD cat back, JFR y pipe,Wilwood BBK,LEDs, Limited Homelink mirror,debadged,WeatherTechs,Dynamat Extreme sound deadening,sabm second snorkle to fender, Huper Optik ceramic tint, TRD Sema wheels, aerodynamic under body pan, OEM Audio Plus 500Q reference system, Depo faux pro headlights, real pro fog lights, OV tune, OEM aluminum filter housing, Mobtown IFS skid,TRD oil cap,TRD radiator cap, Osram Night Breaker 150 halogen headlamps, Fumoto valve,dashboard blackout,OEM tailgate power lock, MESO steering wheel logo, MESO two color dome light, TRD Pro coilovers, Artec LCA skids, Volk TE37 XT forged wheels, Roadmaster Active Suspension Garmin Minicam, Garmin minicam II
    Tor aka Mark,
    Around a week ago I found your build thread and could not stop reading until I finished all 290 pages. You really should consider writing a book and finding someone to help you edit it down. You also could consider writing a fictional book. Since you already have the spies now you only need a villain and a couple of gun fights and you could ride to the rescue in your super truck and save the world.
    On another subject, I have a third gen taco and have added a TRD cai and TRD cat back exhaust so far. I would like the TRD S/C but they don't make one and may not ever. They could possibly make a turbo in the future since they do have some experience with them. I do not have the patience of Job like you do so going your route is not an option for me. My next upgrade I am considering is the URD y-pipe. How much louder will it be and how much pollution do you smell as a result of this upgrade? Do you think it would affect my factory warranty since I only have 6k miles so far? My dream upgrade right now would be carbon fiber wheels. ESE Carbon will custom make a set for only $12000. This is better than the $15000 price last year so maybe in the next few years the price will come down enough for me. Where did you get your carbon fiber hood? Is it all carbon fiber or a combination of fiberglass? Thanks for you input.
    BTW, it took me around 240 pages to find out what an elevator engineer does.
    Nickel likes this.
  15. Jan 23, 2017 at 6:35 AM
    #5795
    Torspd
    Tor
    The Great America!
    :pccoffee: Make it an elevator gun battle, with mixes from The Rock's gun battle in GI Joe, and Johnny Yu's elevator fight in Ip Man 3, then we've got a Epic.
    While retaining the OEM headers, the y-pipe will not be obtrusive. I have not seen a 3rd gen's Y-pipe, so I cannot comment on any flow improvements to be had. That being said, I don't know if it is the same as a 2nd Gen's or not? Warranty is relative to dealership.
    My hood is a carbon/fiberglass combination. Purchased from VIS. The clear started flaking after some years, so I had it repainted to match the truck. Under close inspection, the weave is juuuuust visible.
    There should also be HRE wheels, however, they tend to keep prices high. There fore, 2 at a time from ESE. ;)
    HomerTaco likes this.
  16. Jan 23, 2017 at 6:43 AM
    #5796
    skyking3
    Tom
    You are a very compelling writer and I already like your plot. Go for it!
  17. Jan 23, 2017 at 6:46 AM
    #5797
    skyking3
    Tom
    BTW, the 3rd gen does not have headers since they are built into the head and are not replaceable. It stinks since I wanted to put headers on but found out it is not possible.
  18. Jan 23, 2017 at 6:58 AM
    #5798
    Torspd
    Tor
    The Great America!
    Are the cats formed into those as well?
  19. Jan 23, 2017 at 7:03 AM
    #5799
    yota243
    yota243 Well-Known Member
    E.J.
    north Alabama
    turbo 05 prerunner trd off road DC
    Bw s256 turbo with 3 in glass pack dumped pre axle raptor liner bed and top rails and fenderflares and rocker panels. Hunter side steps. Plasti-dipped upper fenders and emblems. satin black spray paint here and there inside and out. 5100's set to 1.75" up front . C channel front bumper. Maxxis bighorn 255/85/16
    what kind of sorcery is this?
    colinb17 likes this.
  20. Jan 23, 2017 at 7:06 AM
    #5800
    Lurkin
    Lurkin Well-Known Member
    Rod
    Pearland, TX
    09 PreRunner SR5 DC
    Cali-gov't dreamin',,, non-modifiable engines.
    greeneggsnspam likes this.
