TORSPD: NEVR
Discussion in '2nd Gen. Builds (2005-2015)' started by Torspd, Feb 9, 2012.
  1. Jan 24, 2017 at 7:45 AM
    #5821
    VolcomTacoma
    VolcomTacoma Well-Known Member
    Jeff
    NorCal
    2015 TRD Sport 4x4 6 Speed Supercharged
    Front- Camburg 4x4 Long Travel 2.5" King Coilovers 2.5" King Triple Bypasses Wheelers Superbumps Rear- DMZ SUA 16" 3.0 King Triple Bypasses 3" 2.0 Fox bumps Wheels and Tires- 295/75/16 Toyo ATII XTREME SCS SR8 Dark Matte Bronze 16" Lighting- (2) 30" Combo light bars (4) Iggycorp diffused pods Tepui Ayer TRD Supercharger URD Mark III 3" Exhaust URD 4x4 Y Pipe URD CAI URD 2.85 Stealth Pulley Hurst Core Shifter with Hurst T URD Stage 3 clutch URD Lightweight flywheel URD Throw out bearing upgrade AEM Wideband AFR Gauge Speedhut Boost Gauge Craven Speed Flex Pod mount Weathertech Floor Liners BAMF Sliders Ultragauge sPod SE ARB CKMTA12 Hella Supertone horns Relentless Tailgate Reinforcement
    Yes you will. Period. You are removing the very thing designed to try to get as much of that smell out of your exhaust system as possible before it gets out to the environment.
    You're the reason we have a hole in the ozone layer
    :stirthepot:
    Also this. I breathe deep in the mornings as a Bald eagle lands next to my exhaust to warm itself and gives me a nod before taking off again.
    Torspd[OP] likes this.
  2. Jan 24, 2017 at 8:02 AM
    #5822
    Torspd
    Torspd [OP] Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    Tor.
    Rear cats, not much really. All relative to each own's nose though. Front, definitely.
    With a stock catback, and stock headers, it should keep drone and rasp minimalized. However, your engine is different, and so are the headers. Therefore the acoustics will be different. Not to fair a comparison.
  3. Jan 24, 2017 at 8:02 AM
    #5823
    skyking3
    skyking3 Well-Known Member
    Tom
    2016 Silver Tacoma SR5 DCSB
    TRD cai, TRD cat back, JFR y pipe,Wilwood BBK,LEDs, Limited Homelink mirror,debadged,WeatherTechs,Dynamat Extreme sound deadening,sabm second snorkle to fender, Huper Optik ceramic tint, TRD Sema wheels, aerodynamic under body pan, OEM Audio Plus 500Q reference system, Depo faux pro headlights, real pro fog lights, OV tune, OEM aluminum filter housing, Mobtown IFS skid,TRD oil cap,TRD radiator cap, Osram Night Breaker 150 halogen headlamps, Fumoto valve,dashboard blackout,OEM tailgate power lock, MESO steering wheel logo, MESO two color dome light, TRD Pro coilovers, Artec LCA skids, Volk TE37 XT forged wheels, Roadmaster Active Suspension Garmin Minicam, Garmin minicam II
    There was a hole in the ozone layer 1000's of years ago and man had nothing to do with it. I am not a tree hugger but was just trying to do this upgrade without my wife finding out. Since I think that URD gives a discount to TW members I could just tell my wife that I got it on sale and I could not pass up a great deal. Maybe that would work.
  4. Jan 24, 2017 at 8:08 AM
    #5824
    VolcomTacoma
    Jeff
    NorCal
    Hook, line and sinker. LOL
    Do me a favor and just click my build and realize how facetious I was being :D
  5. Jan 24, 2017 at 8:24 AM
    #5825
    skyking3
    Tom
    Thanks, I appreciate that. My wife and I have been married for over 41 years and I would like to stay that way. I once said that I wanted to buy a motorcycle and she said no problem, but she would spend the same amount of money on anything that she wanted. Needless to say, i did not buy that motorcycle. I do have some MDK (mama don't know) money I could use but do not want to be busted over a lot more noise or smell. I have been a pilot for almost 50 years and like Goose once said, I have a need for speed.
    BTW, you have a great build. How hard is it to start with the light weight flywheel?
  6. Jan 24, 2017 at 9:18 AM
    #5826
    VolcomTacoma
    Jeff
    NorCal
    With the stage 3 clutch and the flywheel it took some getting used to, but clutch engagement is very crisp and I can feel the extra bit of acceleration from the flywheel. Clutch engagement translates to about half an inch of pedal movement now, so slipping takes much more fine control, but I'm used to it now and really enjoy it. No problems offroad either.
  7. Jan 24, 2017 at 10:43 AM
    #5827
    Torspd
    Tor
    The Great America!
    If for whatever the reason, there is always the option of adding in a resonator, to alter the tone. As close to the outlet flange of the y-pipe has the greatest effect.
    The 1GR with unequal length headers, and URD y-pipe, has a Nasty rasp in the 2k range. Many modders became proactive in the fight against the gargling rattle can rasp. A resonator where mentioned, was the answer. In conjunction with the muffler.
  8. Jan 24, 2017 at 11:01 AM
    #5828
    VolcomTacoma
    Jeff
    NorCal
    Have considered this myself a few times. Will probably add one in when I finally get around to installing headers and get the exhaust system welded up instead of just clamped.
  9. Feb 7, 2017 at 5:46 PM
    #5829
    MrCrowntown
    MrCrowntown Well-Known Member
    Alyn
    Ky
    06 Extended cab Prerunner 2.7
    Dirt King Mid travel with King 2.5 coilovers, Baja Kits chase SUA with 14in fox smoothies under custom hangars.
    Any recent dyno graphs?
  10. Feb 7, 2017 at 7:06 PM
    #5830
    Torspd
    Tor
    The Great America!
    Nothing new unfortunately. The mods of life have cut infront of the priority line.
    Just the last one, which I still haven't shared.
    Of recent, an internal component of my Aero Turbine muffler decided it missed Christmas. Now it jingles around with the persistance of a Salvation Army donation clerk.
    MrCrowntown, colinb17 and HomerTaco like this.
  11. Feb 7, 2017 at 7:10 PM
    #5831
    Torspd
    Tor
    The Great America!
    Then there is the E36 Bimmer of mine which has been taking time. Pryed the head from its grasp, to find that all of the exhaust valves are bent.
    Previous owner which had the engine over heat, had the head machined. Shop doing the work didn't account for the material taken off, and didn't get a head gasket thick enough. It was just baaaaarely too thin a gasket.
    MrCrowntown likes this.
  12. Feb 7, 2017 at 7:14 PM
    #5832
    yota243
    yota243 Well-Known Member
    E.J.
    north Alabama
    turbo 05 prerunner trd off road DC
    Bw s256 turbo with 3 in glass pack dumped pre axle raptor liner bed and top rails and fenderflares and rocker panels. Hunter side steps. Plasti-dipped upper fenders and emblems. satin black spray paint here and there inside and out. 5100's set to 1.75" up front . C channel front bumper. Maxxis bighorn 255/85/16
    Just grab some channel locks and straighten em out then put a thicker gasket on... Problem solved
  13. Feb 7, 2017 at 8:04 PM
    #5833
    Torspd
    Tor
    The Great America!
    Were it so simple. New valves on order. Need an oil pump nut, head gasket, and vanos repair parts.
  14. Feb 8, 2017 at 8:48 AM
    #5834
    MrCrowntown
    Alyn
    Ky
    Hey man, it can't be all choo choo everyday. Sometimes you gotta maintenance.
  15. Feb 8, 2017 at 10:38 AM
    #5835
    Torspd
    Tor
    The Great America!
    Other side project. Modded my lawnmower. A little fiddling necessary, but runs on vapor. :militarypress:
  16. Feb 8, 2017 at 10:57 AM
    #5836
    yota243
    E.J.
    north Alabama
    hydrogen vapor or propane vapor?
  17. Feb 8, 2017 at 11:07 AM
    #5837
    VolcomTacoma
    Jeff
    NorCal
    Turbo lawn mower. I like it.
  18. Feb 8, 2017 at 11:30 AM
    #5838
    Lurkin
    Lurkin Well-Known Member
    Rod
    Pearland, TX
    09 PreRunner SR5 DC
    yota243[QUOTED] likes this.
  19. Feb 8, 2017 at 12:03 PM
    #5839
    MrCrowntown
    Alyn
    Ky
    Probably nitrous vapor
    :fingerscrossed:
    yota243 likes this.
  20. Feb 8, 2017 at 12:22 PM
    #5840
    Torspd
    Tor
    The Great America!
    Petrol vapor
