TORSPD: NEVR
Discussion in '2nd Gen. Builds (2005-2015)' started by Torspd, Feb 9, 2012.
  1. Mar 1, 2017 at 3:45 PM
    #5961
    Torspd
    Torspd [OP] Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    What's up bro! Welcome to the Elite group. :cool:
  2. Mar 1, 2017 at 3:47 PM
    #5962
    Hacktacular
    Hacktacular Well-Known Member
    Robert
    2010 Tacoma X-Runner Turbo
    800cc Siemens/Deka Injectors URD Fuel Pump Upgrade Haltech Elite 2500 Custom Power Fab Precision Turbo 6676 @8 PSI 3" Custom Exhaust from turbo out
    What's up! Thanks for the invite to the thread.
  3. Mar 1, 2017 at 3:48 PM
    #5963
    MrCrowntown
    MrCrowntown Well-Known Member
    Alyn
    Ky
    06 Extended cab Prerunner 2.7
    Dirt King Mid travel with King 2.5 coilovers, Baja Kits chase SUA with 14in fox smoothies under custom hangars.
    Awh..
    I've only got the elite 1500... :pout:
  4. Mar 1, 2017 at 3:49 PM
    #5964
    yota243
    yota243 Well-Known Member
    E.J.
    north Alabama
    turbo 05 prerunner trd off road DC
    Bw s256 turbo with 3 in glass pack dumped pre axle raptor liner bed and top rails and fenderflares and rocker panels. Hunter side steps. Plasti-dipped upper fenders and emblems. satin black spray paint here and there inside and out. 5100's set to 1.75" up front . C channel front bumper. Maxxis bighorn 255/85/16
    Dude i realize u only have 13 post... But u have turbo in ur vehicle description, so i expect u to have a build page this time next week
  5. Mar 1, 2017 at 4:01 PM
    #5965
    Hacktacular
    Robert
    You must have a 4cyl?
    MrCrowntown[QUOTED] likes this.
  6. Mar 1, 2017 at 4:03 PM
    #5966
    MrCrowntown
    Alyn
    Ky
    Goin fully forged Turbo 2TR :D
    Hacktacular[QUOTED] and yota243 like this.
  7. Mar 1, 2017 at 4:06 PM
    #5967
    Hacktacular
    Robert
    One what?
    nice! That ought to get it done...
    yota243[QUOTED] likes this.
  8. Mar 1, 2017 at 4:07 PM
    #5968
    yota243
    E.J.
    north Alabama
    Sorry man, can u not tell that i mean build page... Haha get on it
  9. Mar 1, 2017 at 4:20 PM
    #5969
    MrCrowntown
    Alyn
    Ky
    It will be fun!
    So what are you in for? I'd love to see your build, mines not terribly exciting but it will be soon :anonymous:
    yota243 likes this.
  10. Mar 1, 2017 at 5:11 PM
    #5970
    Torspd
    Tor
    The Great America!
    MrCrowntown brought to our attention that the 2TR has the exact same shortblock of the 3RZ. Iron block, closed deck muscle. :benchpress: He's working the LCE to really push the limits of the 2TR. :gossip:
    Update on the coolant sensor. So with anything, there will always be a hiccup. Truck wouldn't get warm enough, due to idling so rich. My Haltech WRAF sensors are not comnected yet, so it didn't have any closed loop feedback. This, RICH. Interesting watching the coolant get no warmer than 110ºF because of that.
    I am however quite awesome, as I have a few backup plans. Not to worry. Within hopefully the next few days, I'll have some files for you guys.
    nfs257 and MrCrowntown like this.
  11. Mar 1, 2017 at 5:50 PM
    #5971
    Hacktacular
    Robert
    Hahahaha, quite awesome! So wait the engine didn't warm up because the sensor wasn't reading right? I cant see it not making temp because its too rich. that would be crazy.
    Please update us on this craziness! I suppose Ill get started on a build thread!
  12. Mar 1, 2017 at 6:13 PM
    #5972
    Torspd
    Tor
    The Great America!
    It honestly didn't make much sense to me. It is a cool day, and I had the hood open. The sensor's voltage capped out around 1.33 volts. The engine temp rose from 64ºF to 110º, but never got any hotter, by the time I decided to revert back to the OEM ecu.
    Plus, even poking the rear out of garage, that rich exhaust was starting to get to me.
    The whole process was around 5 minutes of idling only.
    I would rev it every now and then, and the coolant would drop a couple degrees before coming back up.
    Hacktacular likes this.
  13. Mar 1, 2017 at 6:17 PM
    #5973
    Torspd
    Tor
    The Great America!
    I am still not 100% certain that the scangauge was reading accurately though. Because before when the ProEFI controlled the same way, IAT's were not accurate through the OBDII. So that might have been the point the whole time.
    Despite how long I let the truck sit to cool down, with a fan on it, 1.5 hours, I didn't start it up right before the ecu swap, to see if the temps were the same.
    So I am still in speculation mode.
  14. Mar 1, 2017 at 6:18 PM
    #5974
    Torspd
    Tor
    The Great America!
    Now to relax and play some Witcher.
  15. Mar 1, 2017 at 6:36 PM
    #5975
    Lucario Runner
    Lucario Runner Resident Truck/SUV racer
    Robert
    San Antonio, TX or nearest race track
    06 Toyota 4Runner
    AFE stage II intake, APR X1, URD 70mm Throttle Valve (ported and knife edged), NST intake manifold spacer, URD spec U headers, Denso IKH20, URD fuel pump, APR fuel rail, URD Y pipe, URD spec u catback, lightweight water pump pulley, Greddy sandwich cooler plate, Earls oil cooler, IPT valve body, FJ TRD shocks, Cusco front and rear sway bars, Energy Suspension rear track rod bushings and rear link bushings, Carbotech pads, Stoptech ss brake lines, Stoptech slotted rotors, Motul 600 rbf, Limited Grill, Painted hatch cover by me, Painted valve covers by me, Cobra CB, TRD rad and oil cap, Escort 8500, Autometer oil psi and temp gauges, AEM wideband afr gauge, Flexpod, Pioneer 400w speakers.
    That is not halo wars 2 or gta 5 and I really must protest.....
  16. Mar 1, 2017 at 6:43 PM
    #5976
    TacoJova
    TacoJova Well-Known Member
    Central Oregon
    21 Ram TRX Sold 2015 White DCSB Offroad
    Supercharger Hybrid audio stage 3 and stage 2 rear with 2 image Dynamics IDQ10's and alpine amps Bilstein 5100 with OME 887 Dakars and Icon 2.0 in the rear URD SPEC U Headers URD Y Pipe Borla muffler 18" Magnaflow Resonator Morimoto fogs
    Hey @Torspd do you really have to lift the engine to install the URD headers?
  17. Mar 1, 2017 at 6:46 PM
    #5977
    Hacktacular
    Robert
    Nickel and yota243[QUOTED] like this.
  18. Mar 1, 2017 at 6:46 PM
    #5978
    Lucario Runner
    Robert
    06 Toyota 4Runner
    no, just take the exhaust studs out.
  19. Mar 1, 2017 at 6:46 PM
    #5979
    Hacktacular
    Robert
  20. Mar 1, 2017 at 6:49 PM
    #5980
    TacoJova
    Central Oregon
    Oh thank God I was getting scared from the kinda confusing instructions
