TORSPD: NEVR
Discussion in '2nd Gen. Builds (2005-2015)' started by Torspd, Feb 9, 2012.
  1. Mar 1, 2017 at 7:02 PM
    #5981
    Lucario Runner
    Lucario Runner Resident Truck/SUV racer
    Robert
    San Antonio, TX or nearest race track
    06 Toyota 4Runner
    AFE stage II intake, APR X1, URD 70mm Throttle Valve (ported and knife edged), NST intake manifold spacer, URD spec U headers, Denso IKH20, URD fuel pump, APR fuel rail, URD Y pipe, URD spec u catback, lightweight water pump pulley, Greddy sandwich cooler plate, Earls oil cooler, IPT valve body, FJ TRD shocks, Cusco front and rear sway bars, Energy Suspension rear track rod bushings and rear link bushings, Carbotech pads, Stoptech ss brake lines, Stoptech slotted rotors, Motul 600 rbf, Limited Grill, Painted hatch cover by me, Painted valve covers by me, Cobra CB, TRD rad and oil cap, Escort 8500, Autometer oil psi and temp gauges, AEM wideband afr gauge, Flexpod, Pioneer 400w speakers.
    You'll still need to disconnect the steering shaft though.
    Torspd[OP] likes this.
  2. Mar 1, 2017 at 7:15 PM
    #5982
    HomerTaco
    HomerTaco
    HomerTaco
    HomerTaco
  3. Mar 1, 2017 at 8:16 PM
    #5983
    TacoJova
    TacoJova Well-Known Member
    Central Oregon
    2025 Underground DCLB Sold 21 Ram TRX Sold 2015 White DCSB Offroad
    Stock for now
    Yeah I'm not too scared about that looks simple
  4. Mar 1, 2017 at 8:20 PM
    #5984
    TacoJova
    Central Oregon
    Stock for now
    Any tips you guys can give me? looks fairly easy once you take the tires and splash guards off but was wondering if you guys had trouble with anything.
  5. Mar 1, 2017 at 8:22 PM
    #5985
    Torspd
    Torspd [OP] Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    Just the studs coming out of the heads. Removed two or three closest to the firewall on the driver side. One or two on the passneger.
    Mark the coupling so that you line up the steering shaft back to where it was.
  6. Mar 1, 2017 at 8:24 PM
    #5986
    TacoJova
    Central Oregon
    Stock for now
    You guys don't happen to know if a 12 point socket will work with the Torx studs? or should I just buy a Torx socket?
  7. Mar 1, 2017 at 8:31 PM
    #5987
    Torspd
    Tor
    The Great America!
    I used a six sided socket. That might work, but always safer with the correct tool. Which I have now.
    MrCrowntown likes this.
  8. Mar 1, 2017 at 8:32 PM
    #5988
    MrCrowntown
    MrCrowntown Well-Known Member
    Alyn
    Ky
    06 Extended cab Prerunner 2.7
    Dirt King Mid travel with King 2.5 coilovers, Baja Kits chase SUA with 14in fox smoothies under custom hangars.
    buy torx. It's all about surface area
  9. Mar 2, 2017 at 7:21 AM
    #5989
    SconnieHailer
    SconnieHailer PutterClutch
    Marc
    West Central Wisconsin
    2012 TRD Off Road Double Cab V6 6Speed
    Drivers side sucks. Took me like 30 min of finagle time to get it to slip into that hole.
  10. Mar 4, 2017 at 8:15 AM
    #5990
    skyking3
    skyking3 Well-Known Member
    Tom
    2025 Tacoma TRD Sport Hybrid
    TTD billet oil cap, Weathertech tonneau cover ---All following mods were for my 3rd gen --TRD cai, TRD cat back, JFR y pipe,Wilwood BBK,LEDs, Limited Homelink mirror,debadged,WeatherTechs,Dynamat Extreme sound deadening,sabm second snorkle to fender, Huper Optik ceramic tint, TRD Sema wheels, aerodynamic under body pan, OEM Audio Plus 500Q reference system, Depo faux pro headlights, real pro fog lights, OV tune, OEM aluminum filter housing, Mobtown IFS skid,TRD oil cap,TRD radiator cap, Osram Night Breaker 150 halogen headlamps, Fumoto valve,dashboard blackout,OEM tailgate power lock, MESO steering wheel logo, MESO two color dome light, TRD Pro coilovers, Artec LCA skids, Volk TE37 XT forged wheels, Roadmaster Active Suspension Garmin Minicam, Garmin minicam II
    Tor
    A few weeks ago you were nice enough to answer some of my questions and I went ahead and bought the URD y pipe. There has been a definite improvement in power and gas mileage which was a nice benefit. There has been no rasp or any drone at highway speeds. Unfortunately, I got busted when my wife found out so I had to buy her some jewelry to make up for it. It was still worth it though.
    Now I have another question about another mod I am considering. I have read that a good port and polish job can add 10% HP and improve gas mileage as well. Since you have done this I wanted your thoughts on it. My truck has only 8k miles and plenty of warranty left but if is done right it should not cause any engine problems.
  11. Mar 4, 2017 at 8:23 AM
    #5991
    MrCrowntown
    Alyn
    Ky
    I would be curious how a port/polish will affect the Atkinson cycle.. hmm
  12. Mar 4, 2017 at 8:25 AM
    #5992
    Sacrifice
    Sacrifice Motorcycle Goon
    KS
    DCSB OR 4X4 LT
    Pelfreybilt Front Bumper,BAMF sliders, Airflow Snorkel,Mini D2S Retrofits, ADS Rear Shocks, Deaver U402 Leafsprings, 35s, AllPro +2LT
    It's not worth the hassle to disassemble an engine that is already running fine unless you truly want to build up the engine at the same time.
  13. Mar 4, 2017 at 8:27 AM
    #5993
    skyking3
    Tom
    I don't know which is why I was trying to draw upon the knowledge of people who know a lot more than I do.
  14. Mar 4, 2017 at 8:29 AM
    #5994
    skyking3
    Tom
    I may want to do that also like titanium valves etc.
  15. Mar 4, 2017 at 8:31 AM
    #5995
    Sacrifice
    KS
    DCSB OR 4X4 LT
    You won't see any benefit from those
  16. Mar 4, 2017 at 8:32 AM
    #5996
    MrCrowntown
    Alyn
    Ky
    I feel like if you stick to runners, and plenums, you could get away with a port/polish, but just stay away from combustion chambers. That is, of course, if you have the technical knowledge to successfully achieve your mod. You will need a flow bench, a sonic thickness gauge, carbide bits and polishing stones, and balls. I'm sure these heads are not cheap yet, and if you happened to break through a runner divider, or into a cooling passage, you'll be shit out of luck.
  17. Mar 4, 2017 at 8:38 AM
    #5997
    skyking3
    Tom
    I would never try it myself even though the youtube videos make it look so simple. I talked to 2 master techs at the Toyota dealer I go to and they recommended a guy in town who specializes in head work. There are also several places out of town that specialize in this.
  18. Mar 4, 2017 at 8:55 AM
    #5998
    MrCrowntown
    Alyn
    Ky
    Well, having worked as a Toyota tech, I would be careful what any 'master techs' tell you. They are usually much less than masters.
    I would steer clear of doing this until you are close to the end of your warantee. This engine doesn't have the track record that the other engines toyota offers has, and you may end up snowballing a problem into existance.. @Torspd will have his own answer, but this is my suggestion
  19. Mar 4, 2017 at 9:01 AM
    #5999
    skyking3
    Tom
    Thanks for your advise, especially since you were a toyota tech!
  20. Mar 4, 2017 at 9:03 AM
    #6000
    Gaunt596
    Gaunt596 Well-Known Member
    Matthew
    Central Maryland
    Id also highly reccomend getting ahold of a second engine to build with, that way when the built one blows up (and thats a definite when, not if) you still have a working motor to drop back in.
